root/radiance/ray/src/rt/devmain.c
Revision: 1.3
Committed: Wed Nov 1 16:12:22 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.2: +44 -6 lines
Added ability to call repaint in detached drivers
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devmain.c - main for independent drivers.
9 *
10 * Redefine your initialization routine to dinit.
11 *
12 * 10/25/89
13 */
14
15 #include <stdio.h>
16
17 #include <signal.h>
18
19 #include "color.h"
20
21 #include "driver.h"
22
23 int (*wrnvec)(), (*errvec)(), (*cmdvec)(); /* error vectors, unused */
24
25 long nrays = 0; /* fake it */
26
27 struct driver *dev = NULL; /* output device */
28
29 FILE *devin, *devout; /* communications channels */
30
31 int notified = 0; /* notified parent of input? */
32
33 char *progname; /* driver name */
34
35 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin(), r_mycomin();
36
37 int (*dev_func[NREQUESTS])() = { /* request handlers */
38 r_clear, r_paintr,
39 r_getcur, r_comout, r_comin
40 };
41
42 char mybuf[512] = "";
43
44 char *mybufp();
45
46
47 main(argc, argv) /* set up communications and main loop */
48 int argc;
49 char *argv[];
50 {
51 extern struct driver *dinit();
52 int com;
53 /* set up I/O */
54 progname = argv[0];
55 if (argc < 3) {
56 stderr_v("arg count\n");
57 quit(1);
58 }
59 devin = fdopen(atoi(argv[1]), "r");
60 devout = fdopen(atoi(argv[2]), "w");
61 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
62 stderr_v("connection failure\n");
63 quit(1);
64 }
65 /* open device */
66 if ((dev = dinit(argv[0], argv[3])) == NULL)
67 quit(1);
68 putw(COM_RECVM, devout); /* verify initialization */
69 putw(dev->xsiz, devout);
70 putw(dev->ysiz, devout);
71 fflush(devout);
72 /* loop on requests */
73 while ((com = getc(devin)) != EOF) {
74 if (com >= NREQUESTS || dev_func[com] == NULL) {
75 stderr_v("invalid request\n");
76 quit(1);
77 }
78 (*dev_func[com])(); /* process request */
79 }
80 quit(0); /* all done, clean up and exit */
81 }
82
83
84 quit(code) /* close device and exit */
85 int code;
86 {
87 if (dev != NULL)
88 (*dev->close)();
89 exit(code);
90 }
91
92
93 r_clear() /* clear screen */
94 {
95 int xres, yres;
96
97 xres = getw(devin);
98 yres = getw(devin);
99 (*dev->clear)(xres, yres);
100 }
101
102
103 r_paintr() /* paint a rectangle */
104 {
105 COLOR col;
106 int xmin, ymin, xmax, ymax;
107
108 nrays += 5; /* pretend */
109 fread(col, sizeof(COLOR), 1, devin);
110 xmin = getw(devin); ymin = getw(devin);
111 xmax = getw(devin); ymax = getw(devin);
112 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
113 /* check for input */
114 if (!notified && dev->inpready > 0) {
115 notified = 1;
116 kill(getppid(), SIGIO);
117 }
118 }
119
120
121 r_getcur() /* get and return cursor position */
122 {
123 int c;
124 int x, y;
125 /* get it if we can */
126 if (dev->getcur == NULL) {
127 c = ABORT;
128 x = y = 0;
129 } else
130 c = (*dev->getcur)(&x, &y);
131 /* reply */
132 putc(COM_GETCUR, devout);
133 putc(c, devout);
134 putw(x, devout);
135 putw(y, devout);
136 fflush(devout);
137 }
138
139
140 r_comout() /* print string to command line */
141 {
142 char str[256];
143
144 mygets(str, devin);
145 (*dev->comout)(str);
146 }
147
148
149 r_comin() /* read string from command line */
150 {
151 char buf[256];
152 /* get string */
153 (*dev->comin)(buf);
154 /* reply */
155 putc(COM_COMIN, devout);
156 myputs(buf, devout);
157 fflush(devout);
158 /* reset notify */
159 notified = 0;
160 }
161
162
163 mygets(s, fp) /* get string from file (with nul) */
164 register char *s;
165 register FILE *fp;
166 {
167 register int c;
168
169 while ((c = getc(fp)) != EOF)
170 if ((*s++ = c) == '\0')
171 return;
172 *s = '\0';
173 }
174
175
176 myputs(s, fp) /* put string to file (with nul) */
177 register char *s;
178 register FILE *fp;
179 {
180 do
181 putc(*s, fp);
182 while (*s++);
183 }
184
185
186 r_mycomin() /* get command from my buffer */
187 {
188 register char *cp;
189 /* get next command */
190 for (cp = mybuf; *cp != '\n'; cp++)
191 ;
192 *cp++ = '\0';
193 (*dev->comout)(mybuf); /* echo my command */
194 /* send it as reply */
195 putc(COM_COMIN, devout);
196 myputs(mybuf, devout);
197 fflush(devout);
198 /* get next command */
199 (*dev->comout)("\n");
200 strcpy(mybuf, cp);
201 if (mybuf[0])
202 kill(getppid(), SIGIO); /* signal more */
203 else
204 dev_func[COM_COMIN] = r_comin; /* else reset */
205 }
206
207
208 stderr_v(s) /* put string to stderr */
209 register char *s;
210 {
211 static int inline = 0;
212
213 if (!inline++) {
214 fputs(progname, stderr);
215 fputs(": ", stderr);
216 }
217 fputs(s, stderr);
218 if (*s && s[strlen(s)-1] == '\n') {
219 fflush(stderr);
220 inline = 0;
221 }
222 }
223
224
225 char *
226 mybufp() /* return buffer for my command */
227 {
228 if (dev_func[COM_COMIN] != r_mycomin) {
229 dev_func[COM_COMIN] = r_mycomin;
230 kill(getppid(), SIGIO);
231 }
232 return(mybuf+strlen(mybuf));
233 }
234
235
236 repaint(xmin, ymin, xmax, ymax) /* repaint section of display */
237 int xmin, ymin, xmax, ymax;
238 {
239 sprintf(mybufp(), "repaint %d %d %d %d\n",
240 xmin, ymin, xmax, ymax);
241 }
