--- ray/src/rt/devmain.c 1990/03/06 17:44:44 1.10 +++ ray/src/rt/devmain.c 2023/02/09 21:54:11 2.6 @@ -1,25 +1,20 @@ -/* Copyright (c) 1989 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: devmain.c,v 2.6 2023/02/09 21:54:11 greg Exp $"; #endif - /* * devmain.c - main for independent drivers. * * Redefine your initialization routine to dinit. - * - * 10/25/89 */ -#include +#include "copyright.h" +#include "standard.h" + #include "color.h" #include "driver.h" -int (*wrnvec)(), (*errvec)(), (*cmdvec)(); /* error vectors, unused */ - struct driver *dev = NULL; /* output device */ FILE *devin, *devout; /* communications channels */ @@ -44,24 +39,25 @@ char *argv[]; /* set up I/O */ progname = argv[0]; if (argc < 3) { - stderr_v("arg count\n"); + eputs("arg count\n"); quit(1); } devin = fdopen(atoi(argv[1]), "r"); devout = fdopen(atoi(argv[2]), "w"); if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) { - stderr_v("connection failure\n"); + eputs("connection failure\n"); quit(1); } /* open device */ if ((dev = dinit(argv[0], argv[3])) == NULL) quit(1); putw(COM_RECVM, devout); /* verify initialization */ + sendstate(); fflush(devout); /* loop on requests */ while ((com = getc(devin)) != EOF) { if (com >= NREQUESTS || dev_func[com] == NULL) { - stderr_v("invalid request\n"); + eputs("invalid request\n"); quit(1); } (*dev_func[com])(); /* process request */ @@ -70,6 +66,7 @@ char *argv[]; } +void quit(code) /* close device and exit */ int code; { @@ -94,7 +91,7 @@ r_paintr() /* paint a rectangle */ COLOR col; int xmin, ymin, xmax, ymax; - fread((char *)col, sizeof(COLOR), 1, devin); + getbinary((char *)col, sizeof(COLOR), 1, devin); xmin = getw(devin); ymin = getw(devin); xmax = getw(devin); ymax = getw(devin); (*dev->paintr)(col, xmin, ymin, xmax, ymax); @@ -106,10 +103,7 @@ r_flush() /* flush output */ if (dev->flush != NULL) (*dev->flush)(); putc(COM_FLUSH, devout); - fwrite((char *)&dev->pixaspect, sizeof(dev->pixaspect), 1, devout); - putw(dev->xsiz, devout); - putw(dev->ysiz, devout); - putw(dev->inpready, devout); + sendstate(); fflush(devout); } @@ -133,6 +127,27 @@ r_getcur() /* get and return cursor position */ } +void +mygets(char *s, FILE *fp) /* get string from file (with nul) */ +{ + int c; + + while ((c = getc(fp)) != EOF) + if ((*s++ = c) == '\0') + return; + *s = '\0'; +} + + +void +myputs(const char *s, FILE *fp) /* put string to file (with nul) */ +{ + do + putc(*s, fp); + while (*s++); +} + + r_comout() /* print string to command line */ { char str[256]; @@ -156,46 +171,34 @@ r_comin() /* read string from command line */ /* reply */ putc(COM_COMIN, devout); myputs(buf, devout); - putw(dev->inpready, devout); + sendstate(); fflush(devout); } -mygets(s, fp) /* get string from file (with nul) */ -register char *s; -register FILE *fp; +void +eputs(const char *s) /* put string to stderr */ { - register int c; + static int midline = 0; - while ((c = getc(fp)) != EOF) - if ((*s++ = c) == '\0') - return; - *s = '\0'; -} - - -myputs(s, fp) /* put string to file (with nul) */ -register char *s; -register FILE *fp; -{ - do - putc(*s, fp); - while (*s++); -} - - -stderr_v(s) /* put string to stderr */ -register char *s; -{ - static int inline = 0; - - if (!inline++) { + if (!*s) + return; + if (!midline++) { fputs(progname, stderr); fputs(": ", stderr); } fputs(s, stderr); - if (*s && s[strlen(s)-1] == '\n') { + if (s[strlen(s)-1] == '\n') { fflush(stderr); - inline = 0; + midline = 0; } +} + + +sendstate() /* send driver state variables */ +{ + putbinary(&dev->pixaspect, sizeof(dev->pixaspect), 1, devout); + putw(dev->xsiz, devout); + putw(dev->ysiz, devout); + putw(dev->inpready, devout); }
