root/radiance/ray/src/rt/devmain.c
Revision: 1.10
Committed: Tue Mar 6 17:44:44 1990 UTC (35 years, 5 months ago) by greg
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devmain.c - main for independent drivers.
9 *
10 * Redefine your initialization routine to dinit.
11 *
12 * 10/25/89
13 */
14
15 #include <stdio.h>
16
17 #include "color.h"
18
19 #include "driver.h"
20
21 int (*wrnvec)(), (*errvec)(), (*cmdvec)(); /* error vectors, unused */
22
23 struct driver *dev = NULL; /* output device */
24
25 FILE *devin, *devout; /* communications channels */
26
27 char *progname; /* driver name */
28
29 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin(), r_flush();
30
31 int (*dev_func[NREQUESTS])() = { /* request handlers */
32 r_clear, r_paintr,
33 r_getcur, r_comout,
34 r_comin, r_flush
35 };
36
37
38 main(argc, argv) /* set up communications and main loop */
39 int argc;
40 char *argv[];
41 {
42 extern struct driver *dinit();
43 int com;
44 /* set up I/O */
45 progname = argv[0];
46 if (argc < 3) {
47 stderr_v("arg count\n");
48 quit(1);
49 }
50 devin = fdopen(atoi(argv[1]), "r");
51 devout = fdopen(atoi(argv[2]), "w");
52 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
53 stderr_v("connection failure\n");
54 quit(1);
55 }
56 /* open device */
57 if ((dev = dinit(argv[0], argv[3])) == NULL)
58 quit(1);
59 putw(COM_RECVM, devout); /* verify initialization */
60 fflush(devout);
61 /* loop on requests */
62 while ((com = getc(devin)) != EOF) {
63 if (com >= NREQUESTS || dev_func[com] == NULL) {
64 stderr_v("invalid request\n");
65 quit(1);
66 }
67 (*dev_func[com])(); /* process request */
68 }
69 quit(0); /* all done, clean up and exit */
70 }
71
72
73 quit(code) /* close device and exit */
74 int code;
75 {
76 if (dev != NULL)
77 (*dev->close)();
78 exit(code);
79 }
80
81
82 r_clear() /* clear screen */
83 {
84 int xres, yres;
85
86 xres = getw(devin);
87 yres = getw(devin);
88 (*dev->clear)(xres, yres);
89 }
90
91
92 r_paintr() /* paint a rectangle */
93 {
94 COLOR col;
95 int xmin, ymin, xmax, ymax;
96
97 fread((char *)col, sizeof(COLOR), 1, devin);
98 xmin = getw(devin); ymin = getw(devin);
99 xmax = getw(devin); ymax = getw(devin);
100 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
101 }
102
103
104 r_flush() /* flush output */
105 {
106 if (dev->flush != NULL)
107 (*dev->flush)();
108 putc(COM_FLUSH, devout);
109 fwrite((char *)&dev->pixaspect, sizeof(dev->pixaspect), 1, devout);
110 putw(dev->xsiz, devout);
111 putw(dev->ysiz, devout);
112 putw(dev->inpready, devout);
113 fflush(devout);
114 }
115
116
117 r_getcur() /* get and return cursor position */
118 {
119 int c;
120 int x, y;
121 /* get it if we can */
122 if (dev->getcur == NULL) {
123 c = ABORT;
124 x = y = 0;
125 } else
126 c = (*dev->getcur)(&x, &y);
127 /* reply */
128 putc(COM_GETCUR, devout);
129 putc(c, devout);
130 putw(x, devout);
131 putw(y, devout);
132 fflush(devout);
133 }
134
135
136 r_comout() /* print string to command line */
137 {
138 char str[256];
139
140 mygets(str, devin);
141 (*dev->comout)(str);
142 }
143
144
145 r_comin() /* read string from command line */
146 {
147 char buf[256], *prompt;
148 /* get prompt */
149 if (getc(devin)) {
150 mygets(buf, devin);
151 prompt = buf;
152 } else
153 prompt = NULL;
154 /* get string */
155 (*dev->comin)(buf, prompt);
156 /* reply */
157 putc(COM_COMIN, devout);
158 myputs(buf, devout);
159 putw(dev->inpready, devout);
160 fflush(devout);
161 }
162
163
164 mygets(s, fp) /* get string from file (with nul) */
165 register char *s;
166 register FILE *fp;
167 {
168 register int c;
169
170 while ((c = getc(fp)) != EOF)
171 if ((*s++ = c) == '\0')
172 return;
173 *s = '\0';
174 }
175
176
177 myputs(s, fp) /* put string to file (with nul) */
178 register char *s;
179 register FILE *fp;
180 {
181 do
182 putc(*s, fp);
183 while (*s++);
184 }
185
186
187 stderr_v(s) /* put string to stderr */
188 register char *s;
189 {
190 static int inline = 0;
191
192 if (!inline++) {
193 fputs(progname, stderr);
194 fputs(": ", stderr);
195 }
196 fputs(s, stderr);
197 if (*s && s[strlen(s)-1] == '\n') {
198 fflush(stderr);
199 inline = 0;
200 }
201 }
