root/radiance/ray/src/rt/devmain.c
Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Diff to previous 2.4 , to selected 1.3
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 2.3: +1 -56 lines
Diff to previous 2.3 , to selected 1.3
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.2: +59 -5 lines
Diff to previous 2.2 , to selected 1.3
Tue Nov 11 20:02:59 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.1: +5 -7 lines
Diff to previous 2.1 , to selected 1.3
Tue Nov 12 17:09:01 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.13: +0 -0 lines
Diff to previous 1.13 , to selected 1.3
Thu Aug 2 13:40:23 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.12: +3 -1 lines
Diff to previous 1.12 , to selected 1.3
minor cosmetics for stderr_v()
Thu Mar 22 20:58:09 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.11 , to selected 1.3
changed "inline" to "midline" for future compiler compatibility
Wed Mar 21 09:46:57 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.10: +12 -5 lines
Diff to previous 1.10 , to selected 1.3
Changed state mainenance calls
Tue Mar 6 17:44:44 1990 UTC (35 years, 2 months ago) by greg
Diff to previous 1.9 , to selected 1.3
Thu Feb 22 12:45:25 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.8: +4 -11 lines
Diff to previous 1.8 , to selected 1.3
Thu Feb 22 11:46:24 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.7: +10 -5 lines
Diff to previous 1.7 , to selected 1.3
Tue Jan 30 11:37:52 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.6: +8 -2 lines
Diff to previous 1.6 , to selected 1.3
Fri Jan 19 00:00:33 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 1.3
Mon Jan 8 15:07:30 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.4 , to selected 1.3
bug in passing of pixaspect
Mon Jan 8 13:38:18 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.3: +1 -45 lines
Diff to previous 1.3
Revision 1.3 - (view) (download) (annotate) - [selected]
Wed Nov 1 16:12:22 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.2: +44 -6 lines
Diff to previous 1.2
Added ability to call repaint in detached drivers
Wed Oct 25 16:49:45 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.1: +5 -4 lines
Diff to previous 1.1 , to selected 1.3
removed superfluous error messages and added nrays variable
Wed Oct 25 15:37:42 1989 UTC (35 years, 6 months ago) by greg
Diff to selected 1.3
