root/Development/ray/src/rt/devmain.c
Revision: 1.2
Committed: Wed Oct 25 16:49:45 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.1: +5 -4 lines
removed superfluous error messages and added nrays variable
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devmain.c - main for independent drivers.
9 *
10 * Redefine your initialization routine to dinit.
11 *
12 * 10/25/89
13 */
14
15 #include <stdio.h>
16
17 #include <signal.h>
18
19 #include "color.h"
20
21 #include "driver.h"
22
23 int (*wrnvec)(), (*errvec)(), (*cmdvec)(); /* error vectors, unused */
24
25 long nrays = 0; /* fake it */
26
27 struct driver *dev = NULL; /* output device */
28
29 FILE *devin, *devout; /* communications channels */
30
31 int notified = 0; /* notified parent of input? */
32
33 char *progname; /* driver name */
34
35 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin();
36
37 int (*dev_func[NREQUESTS])() = { /* request handlers */
38 r_clear, r_paintr,
39 r_getcur, r_comout, r_comin
40 };
41
42
43 main(argc, argv) /* set up communications and main loop */
44 int argc;
45 char *argv[];
46 {
47 extern struct driver *dinit();
48 int com;
49 /* set up I/O */
50 progname = argv[0];
51 if (argc < 3) {
52 stderr_v("arg count\n");
53 quit(1);
54 }
55 devin = fdopen(atoi(argv[1]), "r");
56 devout = fdopen(atoi(argv[2]), "w");
57 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
58 stderr_v("connection failure\n");
59 quit(1);
60 }
61 /* open device */
62 if ((dev = dinit(argv[0], argv[3])) == NULL)
63 quit(1);
64 putw(COM_RECVM, devout); /* verify initialization */
65 putw(dev->xsiz, devout);
66 putw(dev->ysiz, devout);
67 fflush(devout);
68 /* loop on requests */
69 while ((com = getc(devin)) != EOF) {
70 if (com >= NREQUESTS || dev_func[com] == NULL) {
71 stderr_v("invalid request\n");
72 quit(1);
73 }
74 (*dev_func[com])(); /* process request */
75 }
76 quit(0); /* all done, clean up and exit */
77 }
78
79
80 quit(code) /* close device and exit */
81 int code;
82 {
83 if (dev != NULL)
84 (*dev->close)();
85 exit(code);
86 }
87
88
89 r_clear() /* clear screen */
90 {
91 int xres, yres;
92
93 xres = getw(devin);
94 yres = getw(devin);
95 (*dev->clear)(xres, yres);
96 }
97
98
99 r_paintr() /* paint a rectangle */
100 {
101 COLOR col;
102 int xmin, ymin, xmax, ymax;
103
104 nrays += 5; /* pretend */
105 fread(col, sizeof(COLOR), 1, devin);
106 xmin = getw(devin); ymin = getw(devin);
107 xmax = getw(devin); ymax = getw(devin);
108 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
109 /* check for input */
110 if (dev->inpready > notified) {
111 kill(getppid(), SIGIO);
112 notified = dev->inpready;
113 }
114 }
115
116
117 r_getcur() /* get and return cursor position */
118 {
119 int c;
120 int x, y;
121 /* get it if we can */
122 if (dev->getcur == NULL) {
123 c = ABORT;
124 x = y = 0;
125 } else
126 c = (*dev->getcur)(&x, &y);
127 /* reply */
128 putc(COM_GETCUR, devout);
129 putc(c, devout);
130 putw(x, devout);
131 putw(y, devout);
132 fflush(devout);
133 }
134
135
136 r_comout() /* print string to command line */
137 {
138 char str[256];
139
140 mygets(str, devin);
141 (*dev->comout)(str);
142 }
143
144
145 r_comin() /* read string from command line */
146 {
147 char buf[256];
148 /* get string */
149 (*dev->comin)(buf);
150 /* reply */
151 putc(COM_COMIN, devout);
152 myputs(buf, devout);
153 fflush(devout);
154 /* reset notify */
155 notified = 0;
156 }
157
158
159 mygets(s, fp) /* get string from file (with nul) */
160 register char *s;
161 register FILE *fp;
162 {
163 register int c;
164
165 while ((c = getc(fp)) != EOF)
166 if ((*s++ = c) == '\0')
167 return;
168 *s = '\0';
169 }
170
171
172 myputs(s, fp) /* put string to file (with nul) */
173 register char *s;
174 register FILE *fp;
175 {
176 do
177 putc(*s, fp);
178 while (*s++);
179 }
180
181
182 repaint(xmin, ymin, xmax, ymax) /* repaint section of display */
183 int xmin, ymin, xmax, ymax;
184 {
185 /* no can do! */
186 }
187
188
189 stderr_v(s) /* put string to stderr */
190 register char *s;
191 {
192 static int inline = 0;
193
194 if (!inline++) {
195 fputs(progname, stderr);
196 fputs(": ", stderr);
197 }
198 fputs(s, stderr);
199 if (*s && s[strlen(s)-1] == '\n') {
200 fflush(stderr);
201 inline = 0;
202 }
203 }
