root/radiance/ray/src/rt/devmain.c
Revision: 1.1
Committed: Wed Oct 25 15:37:42 1989 UTC (34 years, 7 months ago) by greg
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devmain.c - main for independent drivers.
9 *
10 * Redefine your initialization routine to dinit.
11 *
12 * 10/25/89
13 */
14
15 #include <stdio.h>
16
17 #include <signal.h>
18
19 #include "color.h"
20
21 #include "driver.h"
22
23 int (*wrnvec)(), (*errvec)(), (*cmdvec)(); /* error vectors, unused */
24
25 struct driver *dev = NULL; /* output device */
26
27 FILE *devin, *devout; /* communications channels */
28
29 int notified = 0; /* notified parent of input? */
30
31 char *progname; /* driver name */
32
33 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin();
34
35 int (*dev_func[NREQUESTS])() = { /* request handlers */
36 r_clear, r_paintr,
37 r_getcur, r_comout, r_comin
38 };
39
40
41 main(argc, argv) /* set up communications and main loop */
42 int argc;
43 char *argv[];
44 {
45 extern struct driver *dinit();
46 int com;
47 /* set up I/O */
48 progname = argv[0];
49 if (argc < 3) {
50 stderr_v("arg count\n");
51 quit(1);
52 }
53 devin = fdopen(atoi(argv[1]), "r");
54 devout = fdopen(atoi(argv[2]), "w");
55 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
56 stderr_v("connection failure\n");
57 quit(1);
58 }
59 /* open device */
60 if ((dev = dinit(argv[0], argv[3])) == NULL) {
61 stderr_v("initialization failure\n");
62 quit(1);
63 }
64 putw(COM_RECVM, devout); /* verify initialization */
65 putw(dev->xsiz, devout);
66 putw(dev->ysiz, devout);
67 fflush(devout);
68 /* loop on requests */
69 while ((com = getc(devin)) != EOF) {
70 if (com >= NREQUESTS || dev_func[com] == NULL) {
71 stderr_v("invalid request\n");
72 quit(1);
73 }
74 (*dev_func[com])(); /* process request */
75 }
76 quit(0); /* all done, clean up and exit */
77 }
78
79
80 quit(code) /* close device and exit */
81 int code;
82 {
83 if (dev != NULL)
84 (*dev->close)();
85 exit(code);
86 }
87
88
89 r_clear() /* clear screen */
90 {
91 int xres, yres;
92
93 xres = getw(devin);
94 yres = getw(devin);
95 (*dev->clear)(xres, yres);
96 }
97
98
99 r_paintr() /* paint a rectangle */
100 {
101 COLOR col;
102 int xmin, ymin, xmax, ymax;
103
104 fread(col, sizeof(COLOR), 1, devin);
105 xmin = getw(devin); ymin = getw(devin);
106 xmax = getw(devin); ymax = getw(devin);
107 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
108 /* check for input */
109 if (dev->inpready > notified) {
110 kill(getppid(), SIGIO);
111 notified = dev->inpready;
112 }
113 }
114
115
116 r_getcur() /* get and return cursor position */
117 {
118 int c;
119 int x, y;
120 /* get it if we can */
121 if (dev->getcur == NULL) {
122 c = ABORT;
123 x = y = 0;
124 } else
125 c = (*dev->getcur)(&x, &y);
126 /* reply */
127 putc(COM_GETCUR, devout);
128 putc(c, devout);
129 putw(x, devout);
130 putw(y, devout);
131 fflush(devout);
132 }
133
134
135 r_comout() /* print string to command line */
136 {
137 char str[256];
138
139 mygets(str, devin);
140 (*dev->comout)(str);
141 }
142
143
144 r_comin() /* read string from command line */
145 {
146 char buf[256];
147 /* get string */
148 (*dev->comin)(buf);
149 /* reply */
150 putc(COM_COMIN, devout);
151 myputs(buf, devout);
152 fflush(devout);
153 /* reset notify */
154 notified = 0;
155 }
156
157
158 mygets(s, fp) /* get string from file (with nul) */
159 register char *s;
160 register FILE *fp;
161 {
162 register int c;
163
164 while ((c = getc(fp)) != EOF)
165 if ((*s++ = c) == '\0')
166 return;
167 *s = '\0';
168 }
169
170
171 myputs(s, fp) /* put string to file (with nul) */
172 register char *s;
173 register FILE *fp;
174 {
175 do
176 putc(*s, fp);
177 while (*s++);
178 }
179
180
181 repaint(xmin, ymin, xmax, ymax) /* repaint section of display */
182 int xmin, ymin, xmax, ymax;
183 {
184 stderr_v("repaint called!\n"); /* no can do! */
185 }
186
187
188 stderr_v(s) /* put string to stderr */
189 register char *s;
190 {
191 static int inline = 0;
192
193 if (!inline++) {
194 fputs(progname, stderr);
195 fputs(": ", stderr);
196 }
197 fputs(s, stderr);
198 if (*s && s[strlen(s)-1] == '\n') {
199 fflush(stderr);
200 inline = 0;
201 }
202 }
