1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: devcomm.c,v 2.18 2016/03/06 01:13:17 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* devcomm.c - communication routines for separate drivers. |
6 |
7 |
* External symbols declared in driver.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <sys/types.h> |
13 |
#if !defined(_WIN32) && !defined(_WIN64) |
14 |
#include <sys/wait.h> |
15 |
#endif |
16 |
17 |
#include "paths.h" |
18 |
#include "platform.h" |
19 |
#include "standard.h" |
20 |
#include "driver.h" |
21 |
22 |
#ifndef DEVPATH |
23 |
#define DEVPATH getenv("PATH") /* device search path */ |
24 |
#endif |
25 |
26 |
FILE *devin, *devout; |
27 |
int devchild; |
28 |
29 |
static struct driver * final_connect(void); |
30 |
static void mygets(char *s, FILE *fp); |
31 |
static void myputs(char *s, FILE *fp); |
32 |
static void reply_error(char *routine); |
33 |
static void getstate(void); |
34 |
35 |
static dr_closef_t comm_close; |
36 |
static dr_clearf_t comm_clear; |
37 |
static dr_paintrf_t comm_paintr; |
38 |
static dr_getcurf_t comm_getcur; |
39 |
static dr_comoutf_t comm_comout; |
40 |
static dr_cominf_t comm_comin; |
41 |
static dr_flushf_t comm_flush; |
42 |
43 |
struct driver comm_driver = { |
44 |
comm_close, comm_clear, comm_paintr, comm_getcur, |
45 |
comm_comout, comm_comin, comm_flush |
46 |
47 |
48 |
49 |
static struct driver * |
50 |
final_connect(void) /* verify and initialize connection */ |
51 |
52 |
putw(COM_SENDM, devout); |
53 |
fflush(devout); |
54 |
if (getw(devin) != COM_RECVM) |
55 |
return(NULL); |
56 |
/* get driver parameters */ |
57 |
getstate(); |
58 |
/* set error vectors */ |
59 |
erract[COMMAND].pf = comm_comout; |
60 |
/* doesn't work with raypcalls.c |
61 |
if (erract[WARNING].pf != NULL) |
62 |
erract[WARNING].pf = comm_comout; |
63 |
64 |
return(&comm_driver); |
65 |
66 |
67 |
68 |
struct driver * |
69 |
slave_init( /* run rview in slave mode */ |
70 |
char *dname, |
71 |
char *id |
72 |
73 |
74 |
devchild = -1; /* we're the slave here */ |
75 |
devout = stdout; /* use standard input */ |
76 |
devin = stdin; /* and standard output */ |
77 |
return(final_connect()); /* verify initialization */ |
78 |
79 |
80 |
81 |
struct driver * |
82 |
comm_init( /* set up and execute driver */ |
83 |
char *dname, |
84 |
char *id |
85 |
86 |
87 |
char *dvcname; |
88 |
int p1[2], p2[2]; |
89 |
char pin[16], pout[16]; |
90 |
/* find driver program */ |
91 |
if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) { |
92 |
eputs(dname); |
93 |
eputs(": not found\n"); |
94 |
return(NULL); |
95 |
96 |
#ifdef RHAS_FORK_EXEC |
97 |
/* open communication pipes */ |
98 |
if (pipe(p1) == -1 || pipe(p2) == -1) |
99 |
goto syserr; |
100 |
if ((devchild = fork()) == 0) { /* fork driver process */ |
101 |
close(p1[1]); |
102 |
close(p2[0]); |
103 |
sprintf(pin, "%d", p1[0]); |
104 |
sprintf(pout, "%d", p2[1]); |
105 |
execl(dvcname, dname, pin, pout, id, NULL); |
106 |
perror(dvcname); |
107 |
_exit(127); |
108 |
109 |
if (devchild == -1) |
110 |
goto syserr; |
111 |
close(p1[0]); |
112 |
close(p2[1]); |
113 |
114 |
* Close write stream on exec to avoid multiprocessing deadlock. |
115 |
* No use in read stream without it, so set flag there as well. |
116 |
117 |
fcntl(p1[1], F_SETFD, FD_CLOEXEC); |
118 |
fcntl(p2[0], F_SETFD, FD_CLOEXEC); |
119 |
if ((devout = fdopen(p1[1], "w")) == NULL) |
120 |
goto syserr; |
121 |
if ((devin = fdopen(p2[0], "r")) == NULL) |
122 |
goto syserr; |
123 |
124 |
syserr: |
125 |
perror(dname); |
126 |
return(NULL); |
127 |
128 |
#else /* ! RHAS_FORK_EXEC */ |
129 |
130 |
eputs(dname); |
131 |
eputs(": no fork/exec\n"); |
132 |
return(NULL); |
133 |
134 |
#endif /* ! RHAS_FORK_EXEC */ |
135 |
136 |
137 |
138 |
static void |
139 |
comm_close(void) /* done with driver */ |
140 |
141 |
int pid; |
142 |
143 |
erract[COMMAND].pf = NULL; /* reset error vectors */ |
144 |
145 |
erract[WARNING].pf = wputs; |
146 |
fclose(devout); |
147 |
fclose(devin); |
148 |
if (devchild < 0) |
149 |
return; |
150 |
151 |
while ((pid = wait(0)) != -1 && pid != devchild) |
152 |
153 |
#endif |
154 |
155 |
156 |
157 |
static void |
158 |
comm_clear( /* clear screen */ |
159 |
int xres, |
160 |
int yres |
161 |
162 |
163 |
putc(COM_CLEAR, devout); |
164 |
putw(xres, devout); |
165 |
putw(yres, devout); |
166 |
fflush(devout); |
167 |
168 |
169 |
170 |
static void |
171 |
comm_paintr( /* paint a rectangle */ |
172 |
COLOR col, |
173 |
int xmin, |
174 |
int ymin, |
175 |
int xmax, |
176 |
int ymax |
177 |
178 |
179 |
putc(COM_PAINTR, devout); |
180 |
putbinary(col, sizeof(COLOR), 1, devout); |
181 |
putw(xmin, devout); |
182 |
putw(ymin, devout); |
183 |
putw(xmax, devout); |
184 |
putw(ymax, devout); |
185 |
186 |
187 |
188 |
static void |
189 |
comm_flush(void) /* flush output to driver */ |
190 |
191 |
putc(COM_FLUSH, devout); |
192 |
fflush(devout); |
193 |
if (getc(devin) != COM_FLUSH) |
194 |
reply_error("flush"); |
195 |
getstate(); |
196 |
197 |
198 |
199 |
static int |
200 |
comm_getcur( /* get and return cursor position */ |
201 |
int *xp, |
202 |
int *yp |
203 |
204 |
205 |
int c; |
206 |
207 |
putc(COM_GETCUR, devout); |
208 |
fflush(devout); |
209 |
if (getc(devin) != COM_GETCUR) |
210 |
reply_error("getcur"); |
211 |
c = getc(devin); |
212 |
*xp = getw(devin); |
213 |
*yp = getw(devin); |
214 |
return(c); |
215 |
216 |
217 |
218 |
static void |
219 |
comm_comout( /* print string to command line */ |
220 |
char *str |
221 |
222 |
223 |
putc(COM_COMOUT, devout); |
224 |
myputs(str, devout); |
225 |
if (str[strlen(str)-1] == '\n') |
226 |
fflush(devout); |
227 |
228 |
229 |
230 |
static void |
231 |
comm_comin( /* read string from command line */ |
232 |
char *buf, |
233 |
char *prompt |
234 |
235 |
236 |
putc(COM_COMIN, devout); |
237 |
if (prompt == NULL) |
238 |
putc(0, devout); |
239 |
else { |
240 |
putc(1, devout); |
241 |
myputs(prompt, devout); |
242 |
243 |
fflush(devout); |
244 |
if (getc(devin) != COM_COMIN) |
245 |
reply_error("comin"); |
246 |
mygets(buf, devin); |
247 |
getstate(); |
248 |
249 |
250 |
251 |
static void |
252 |
mygets( /* get string from file (with nul) */ |
253 |
char *s, |
254 |
FILE *fp |
255 |
256 |
257 |
int c; |
258 |
259 |
while ((c = getc(fp)) != EOF) |
260 |
if ((*s++ = c) == '\0') |
261 |
return; |
262 |
*s = '\0'; |
263 |
264 |
265 |
266 |
static void |
267 |
myputs( /* put string to file (with nul) */ |
268 |
char *s, |
269 |
FILE *fp |
270 |
271 |
272 |
do |
273 |
putc(*s, fp); |
274 |
while (*s++); |
275 |
276 |
277 |
278 |
static void |
279 |
reply_error( /* what should we do here? */ |
280 |
char *routine |
281 |
282 |
283 |
eputs(routine); |
284 |
eputs(": driver reply error\n"); |
285 |
quit(1); |
286 |
287 |
288 |
289 |
static void |
290 |
getstate(void) /* get driver state variables */ |
291 |
292 |
getbinary((char *)&comm_driver.pixaspect, |
293 |
sizeof(comm_driver.pixaspect), 1, devin); |
294 |
comm_driver.xsiz = getw(devin); |
295 |
comm_driver.ysiz = getw(devin); |
296 |
comm_driver.inpready = getw(devin); |
297 |
