root/radiance/ray/src/rt/devcomm.c
Revision: 2.12
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.11: +67 -42 lines
2 static const char RCSid[] = "$Id: devcomm.c,v 2.11 2003/11/11 16:24:06 greg Exp $";
5 * devcomm.c - communication routines for separate drivers.
6 *
7 * External symbols declared in driver.h
8 */
9
10 #include "copyright.h"
11
12 #include <sys/types.h>
13 #include <sys/wait.h> /* XXX platform specific */
14
15 #include "platform.h"
16 #include "standard.h"
17 #include "driver.h"
18
19 #ifndef DEVPATH
20 #define DEVPATH getenv("PATH") /* device search path */
21 #endif
22
23 FILE *devin, *devout;
24 int devchild;
25
26 static struct driver * final_connect(void);
27 static void mygets(char *s, FILE *fp);
28 static void myputs(char *s, FILE *fp);
29 static void reply_error(char *routine);
30 static void getstate(void);
31
32 static dr_closef_t comm_close;
33 static dr_clearf_t comm_clear;
34 static dr_paintrf_t comm_paintr;
35 static dr_getcurf_t comm_getcur;
36 static dr_comoutf_t comm_comout;
37 static dr_cominf_t comm_comin;
38 static dr_flushf_t comm_flush;
39
40 struct driver comm_driver = {
41 comm_close, comm_clear, comm_paintr, comm_getcur,
42 comm_comout, comm_comin, comm_flush
43 };
44
45
46 static struct driver *
47 final_connect(void) /* verify and initialize connection */
48 {
49 putw(COM_SENDM, devout);
50 fflush(devout);
51 if (getw(devin) != COM_RECVM)
52 return(NULL);
53 /* get driver parameters */
54 getstate();
55 /* set error vectors */
56 erract[COMMAND].pf = comm_comout;
57 if (erract[WARNING].pf != NULL)
58 erract[WARNING].pf = comm_comout;
59 return(&comm_driver);
60 }
61
62
63 extern struct driver *
64 slave_init( /* run rview in slave mode */
65 char *dname,
66 char *id
67 )
68 {
69 devchild = -1; /* we're the slave here */
70 devout = stdout; /* use standard input */
71 devin = stdin; /* and standard output */
72 return(final_connect()); /* verify initialization */
73 }
74
75
76 extern struct driver *
77 comm_init( /* set up and execute driver */
78 char *dname,
79 char *id
80 )
81 {
82 char *dvcname;
83 int p1[2], p2[2];
84 char pin[16], pout[16];
85 /* find driver program */
86 if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) {
87 eputs(dname);
88 eputs(": not found\n");
89 return(NULL);
90 }
91 #ifdef RHAS_FORK_EXEC
92 /* open communication pipes */
93 if (pipe(p1) == -1 || pipe(p2) == -1)
94 goto syserr;
95 if ((devchild = fork()) == 0) { /* fork driver process */
96 close(p1[1]);
97 close(p2[0]);
98 sprintf(pin, "%d", p1[0]);
99 sprintf(pout, "%d", p2[1]);
100 execl(dvcname, dname, pin, pout, id, 0);
101 perror(dvcname);
102 _exit(127);
103 }
104 if (devchild == -1)
105 goto syserr;
106 close(p1[0]);
107 close(p2[1]);
108 if ((devout = fdopen(p1[1], "w")) == NULL)
109 goto syserr;
110 if ((devin = fdopen(p2[0], "r")) == NULL)
111 goto syserr;
112 return(final_connect()); /* verify initialization */
113 syserr:
114 perror(dname);
115 return(NULL);
116
117 #else /* ! RHAS_FORK_EXEC */
118
119 eputs(dname);
120 eputs(": no fork/exec\n");
121 return(NULL);
122
123 #endif /* ! RHAS_FORK_EXEC */
124 }
125
126
127 static void
128 comm_close(void) /* done with driver */
129 {
130 int pid;
131
132 erract[COMMAND].pf = NULL; /* reset error vectors */
133 if (erract[WARNING].pf != NULL)
134 erract[WARNING].pf = wputs;
135 fclose(devout);
136 fclose(devin);
137 if (devchild < 0)
138 return;
139 while ((pid = wait(0)) != -1 && pid != devchild)
140 ;
141 }
142
143
144 static void
145 comm_clear( /* clear screen */
146 int xres,
147 int yres
148 )
149 {
150 putc(COM_CLEAR, devout);
151 putw(xres, devout);
152 putw(yres, devout);
153 fflush(devout);
154 }
155
156
157 static void
158 comm_paintr( /* paint a rectangle */
159 COLOR col,
160 int xmin,
161 int ymin,
162 int xmax,
163 int ymax
164 )
165 {
166 putc(COM_PAINTR, devout);
167 fwrite((char *)col, sizeof(COLOR), 1, devout);
168 putw(xmin, devout);
169 putw(ymin, devout);
170 putw(xmax, devout);
171 putw(ymax, devout);
172 }
173
174
175 static void
176 comm_flush(void) /* flush output to driver */
177 {
178 putc(COM_FLUSH, devout);
179 fflush(devout);
180 if (getc(devin) != COM_FLUSH)
181 reply_error("flush");
182 getstate();
183 }
184
185
186 static int
187 comm_getcur( /* get and return cursor position */
188 int *xp,
189 int *yp
190 )
191 {
192 int c;
193
194 putc(COM_GETCUR, devout);
195 fflush(devout);
196 if (getc(devin) != COM_GETCUR)
197 reply_error("getcur");
198 c = getc(devin);
199 *xp = getw(devin);
200 *yp = getw(devin);
201 return(c);
202 }
203
204
205 static void
206 comm_comout( /* print string to command line */
207 char *str
208 )
209 {
210 putc(COM_COMOUT, devout);
211 myputs(str, devout);
212 if (str[strlen(str)-1] == '\n')
213 fflush(devout);
214 }
215
216
217 static void
218 comm_comin( /* read string from command line */
219 char *buf,
220 char *prompt
221 )
222 {
223 putc(COM_COMIN, devout);
224 if (prompt == NULL)
225 putc(0, devout);
226 else {
227 putc(1, devout);
228 myputs(prompt, devout);
229 }
230 fflush(devout);
231 if (getc(devin) != COM_COMIN)
232 reply_error("comin");
233 mygets(buf, devin);
234 getstate();
235 }
236
237
238 static void
239 mygets( /* get string from file (with nul) */
240 register char *s,
241 register FILE *fp
242 )
243 {
244 register int c;
245
246 while ((c = getc(fp)) != EOF)
247 if ((*s++ = c) == '\0')
248 return;
249 *s = '\0';
250 }
251
252
253 static void
254 myputs( /* put string to file (with nul) */
255 register char *s,
256 register FILE *fp
257 )
258 {
259 do
260 putc(*s, fp);
261 while (*s++);
262 }
263
264
265 static void
266 reply_error( /* what should we do here? */
267 char *routine
268 )
269 {
270 eputs(routine);
271 eputs(": driver reply error\n");
272 quit(1);
273 }
274
275
276 static void
277 getstate(void) /* get driver state variables */
278 {
279 fread((char *)&comm_driver.pixaspect,
280 sizeof(comm_driver.pixaspect), 1, devin);
281 comm_driver.xsiz = getw(devin);
282 comm_driver.ysiz = getw(devin);
283 comm_driver.inpready = getw(devin);
284 }
