root/radiance/ray/src/rt/devcomm.c
Revision: 1.12
Committed: Thu Feb 22 11:46:13 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.11: +11 -15 lines
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devcomm.c - communication routines for separate drivers.
9 *
10 * 10/5/88
11 */
12
13 #include "standard.h"
14
15 #include <signal.h>
16
17 #include "color.h"
18
19 #include "driver.h"
20
21 #ifndef DEVPATH
22 #define DEVPATH getenv("PATH") /* device search path */
23 #endif
24
25 #ifndef BSD
26 #define vfork fork
27 #endif
28
29 extern char *getpath(), *getenv();
30
31 int onsigio();
32
33 int comm_close(), comm_clear(), comm_paintr(), comm_errout(),
34 comm_getcur(), comm_comout(), comm_comin(), comm_flush();
35
36 struct driver comm_driver = {
37 comm_close, comm_clear, comm_paintr, comm_getcur,
38 comm_comout, comm_comin, comm_flush
39 };
40
41 FILE *devin, *devout;
42
43 int devchild;
44
45
46 struct driver *
47 comm_init(dname, id) /* set up and execute driver */
48 char *dname, *id;
49 {
50 char *devname;
51 int p1[2], p2[2];
52 char pin[16], pout[16];
53 /* find driver program */
54 if ((devname = getpath(dname, DEVPATH, 1)) == NULL) {
55 stderr_v(dname);
56 stderr_v(": not found\n");
57 return(NULL);
58 }
59 /* open communication pipes */
60 if (pipe(p1) == -1 || pipe(p2) == -1)
61 goto syserr;
62 if ((devchild = vfork()) == 0) { /* fork driver process */
63 close(p1[1]);
64 close(p2[0]);
65 sprintf(pin, "%d", p1[0]);
66 sprintf(pout, "%d", p2[1]);
67 execl(devname, dname, pin, pout, id, 0);
68 perror(devname);
69 _exit(127);
70 }
71 if (devchild == -1)
72 goto syserr;
73 close(p1[0]);
74 close(p2[1]);
75 if ((devout = fdopen(p1[1], "w")) == NULL)
76 goto syserr;
77 if ((devin = fdopen(p2[0], "r")) == NULL)
78 goto syserr;
79 /* verify & get resolution */
80 putw(COM_SENDM, devout);
81 fflush(devout);
82 if (getw(devin) != COM_RECVM)
83 return(NULL);
84 fread((char *)&comm_driver.pixaspect,
85 sizeof(comm_driver.pixaspect), 1, devin);
86 comm_driver.xsiz = getw(devin);
87 comm_driver.ysiz = getw(devin);
88 /* input handling */
89 signal(SIGIO, onsigio);
90 /* set error vectors */
91 cmdvec = comm_comout;
92 if (wrnvec != NULL)
93 wrnvec = comm_comout;
94 return(&comm_driver);
95 syserr:
96 perror(dname);
97 return(NULL);
98 }
99
100
101 static
102 comm_close() /* done with driver */
103 {
104 int pid;
105
106 cmdvec = NULL; /* reset error vectors */
107 if (wrnvec != NULL)
108 wrnvec = stderr_v;
109 signal(SIGIO, SIG_DFL);
110 fclose(devout);
111 fclose(devin);
112 while ((pid = wait(0)) != -1 && pid != devchild)
113 ;
114 }
115
116
117 static
118 comm_clear(xres, yres) /* clear screen */
119 int xres, yres;
120 {
121 putc(COM_CLEAR, devout);
122 putw(xres, devout);
123 putw(yres, devout);
124 fflush(devout);
125 }
126
127
128 static
129 comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
130 COLOR col;
131 int xmin, ymin, xmax, ymax;
132 {
133 putc(COM_PAINTR, devout);
134 fwrite((char *)col, sizeof(COLOR), 1, devout);
135 putw(xmin, devout);
136 putw(ymin, devout);
137 putw(xmax, devout);
138 putw(ymax, devout);
139 }
140
141
142 static
143 comm_flush() /* flush output to driver */
144 {
145 putc(COM_FLUSH, devout);
146 fflush(devout);
147 }
148
149
150 static int
151 comm_getcur(xp, yp) /* get and return cursor position */
152 int *xp, *yp;
153 {
154 int c;
155
156 putc(COM_GETCUR, devout);
157 fflush(devout);
158 if (getc(devin) != COM_GETCUR)
159 reply_error("getcur");
160 c = getc(devin);
161 *xp = getw(devin);
162 *yp = getw(devin);
163 return(c);
164 }
165
166
167 static
168 comm_comout(str) /* print string to command line */
169 char *str;
170 {
171 putc(COM_COMOUT, devout);
172 myputs(str, devout);
173 fflush(devout);
174 }
175
176
177 static
178 comm_comin(buf, prompt) /* read string from command line */
179 char *buf;
180 char *prompt;
181 {
182 putc(COM_COMIN, devout);
183 if (prompt == NULL)
184 putc(0, devout);
185 else {
186 putc(1, devout);
187 myputs(prompt, devout);
188 }
189 fflush(devout);
190 if (getc(devin) != COM_COMIN)
191 reply_error("comin");
192 mygets(buf, devin);
193 if (comm_driver.inpready > 0)
194 comm_driver.inpready--;
195 }
196
197
198 static
199 comm_errout(str) /* display an error message */
200 char *str;
201 {
202 comm_comout(str);
203 stderr_v(str); /* send to standard error also */
204 }
205
206
207 static
208 mygets(s, fp) /* get string from file (with nul) */
209 register char *s;
210 register FILE *fp;
211 {
212 register int c;
213
214 while ((c = getc(fp)) != EOF)
215 if ((*s++ = c) == '\0')
216 return;
217 *s = '\0';
218 }
219
220
221 static
222 myputs(s, fp) /* put string to file (with nul) */
223 register char *s;
224 register FILE *fp;
225 {
226 do
227 putc(*s, fp);
228 while (*s++);
229 }
230
231
232 static
233 reply_error(routine) /* what should we do here? */
234 char *routine;
235 {
236 stderr_v(routine);
237 stderr_v(": driver reply error\n");
238 quit(1);
239 }
240
241
242 static
243 onsigio() /* input ready */
244 {
245 comm_driver.inpready++;
246 }
