--- ray/src/rt/devcomm.c 1992/03/19 09:34:02 2.2 +++ ray/src/rt/devcomm.c 1993/04/05 15:16:47 2.3 @@ -22,11 +22,7 @@ static char SCCSid[] = "$SunId$ LBL"; #define DEVPATH getenv("PATH") /* device search path */ #endif -#ifndef DELAY -#define DELAY 20 /* seconds to wait for response */ -#endif - -static int comm_close(), comm_clear(), comm_paintr(), comm_errout(), +static int comm_close(), comm_clear(), comm_paintr(), comm_getcur(), comm_comout(), comm_comin(), comm_flush(); struct driver comm_driver = { @@ -39,7 +35,35 @@ FILE *devin, *devout; int devchild; +static struct driver * +final_connect() /* verify and initialize connection */ +{ + putw(COM_SENDM, devout); + fflush(devout); + if (getw(devin) != COM_RECVM) + return(NULL); + /* get driver parameters */ + getstate(); + /* set error vectors */ + cmdvec = comm_comout; + if (wrnvec != NULL) + wrnvec = comm_comout; + return(&comm_driver); +} + + struct driver * +slave_init(dname, id) /* run rview in slave mode */ +char *dname, *id; +{ + devchild = -1; /* we're the slave here */ + devout = stdout; /* use standard input */ + devin = stdin; /* and standard output */ + return(final_connect()); /* verify initialization */ +} + + +struct driver * comm_init(dname, id) /* set up and execute driver */ char *dname, *id; { @@ -72,18 +96,7 @@ char *dname, *id; goto syserr; if ((devin = fdopen(p2[0], "r")) == NULL) goto syserr; - /* verify initialization */ - putw(COM_SENDM, devout); - fflush(devout); - if (getw(devin) != COM_RECVM) - return(NULL); - /* get driver parameters */ - getstate(); - /* set error vectors */ - cmdvec = comm_comout; - if (wrnvec != NULL) - wrnvec = comm_comout; - return(&comm_driver); + return(final_connect()); /* verify initialization */ syserr: perror(dname); return(NULL); @@ -100,6 +113,8 @@ comm_close() /* done with driver */ wrnvec = stderr_v; fclose(devout); fclose(devin); + if (devchild < 0) + return; while ((pid = wait(0)) != -1 && pid != devchild) ; } @@ -186,15 +201,6 @@ char *prompt; reply_error("comin"); mygets(buf, devin); getstate(); -} - - -static -comm_errout(str) /* display an error message */ -char *str; -{ - comm_comout(str); - stderr_v(str); /* send to standard error also */ }
