--- ray/src/rt/devcomm.c 1989/02/02 10:41:19 1.1 +++ ray/src/rt/devcomm.c 1990/01/08 15:07:31 1.9 @@ -39,8 +39,7 @@ int comm_close(), comm_clear(), comm_paintr(), comm_er struct driver comm_driver, comm_default = { comm_close, comm_clear, comm_paintr, comm_getcur, - comm_comout, comm_comin, - MAXRES, MAXRES, 0 + comm_comout, comm_comin }; FILE *devin, *devout; @@ -49,33 +48,28 @@ int devchild; struct driver * -comm_init(argv) /* set up and execute driver */ -char *argv[]; +comm_init(dname, id) /* set up and execute driver */ +char *dname, *id; { char *devname; int p1[2], p2[2]; - - if ((devname = getpath(argv[0], DEVPATH)) == NULL) { - stderr_v(argv[0]); + char pin[16], pout[16]; + /* find driver program */ + if ((devname = getpath(dname, DEVPATH, 1)) == NULL) { + stderr_v(dname); stderr_v(": not found\n"); return(NULL); } + /* open communication pipes */ if (pipe(p1) == -1 || pipe(p2) == -1) goto syserr; - if ((devchild = vfork()) == 0) { + if ((devchild = vfork()) == 0) { /* fork driver process */ close(p1[1]); close(p2[0]); - if (p1[0] != 0) { - dup2(p1[0], 0); - close(p1[0]); - } - if (p2[1] != 1) { - dup2(p2[1], 1); - close(p2[1]); - } - execv(devname, argv); - stderr_v(devname); - stderr_v(": cannot execute\n"); + sprintf(pin, "%d", p1[0]); + sprintf(pout, "%d", p2[1]); + execl(devname, dname, pin, pout, id, 0); + perror(devname); _exit(127); } if (devchild == -1) @@ -87,14 +81,23 @@ char *argv[]; if ((devin = fdopen(p2[0], "r")) == NULL) goto syserr; bcopy(&comm_default, &comm_driver, sizeof(comm_driver)); + /* verify & get resolution */ + putw(COM_SENDM, devout); + fflush(devout); + if (getw(devin) != COM_RECVM) + return(NULL); + fread(&comm_driver.pixaspect, sizeof(comm_driver.pixaspect), 1, devin); + comm_driver.xsiz = getw(devin); + comm_driver.ysiz = getw(devin); + /* input handling */ signal(SIGIO, onsigio); - errvec = comm_errout; /* set error vector */ + /* set error vectors */ cmdvec = comm_comout; if (wrnvec != NULL) wrnvec = comm_comout; return(&comm_driver); syserr: - perror(argv[0]); + perror(dname); return(NULL); } @@ -104,8 +107,7 @@ comm_close() /* done with driver */ { int pid; - errvec = stderr_v; /* reset error vector */ - cmdvec = NULL; + cmdvec = NULL; /* reset error vectors */ if (wrnvec != NULL) wrnvec = stderr_v; signal(SIGIO, SIG_DFL); @@ -121,8 +123,8 @@ comm_clear(xres, yres) /* clear screen */ int xres, yres; { putc(COM_CLEAR, devout); - fwrite(&xres, sizeof(xres), 1, devout); - fwrite(&yres, sizeof(yres), 1, devout); + putw(xres, devout); + putw(yres, devout); fflush(devout); } @@ -137,10 +139,10 @@ int xmin, ymin, xmax, ymax; putc(COM_PAINTR, devout); fwrite(col, sizeof(COLOR), 1, devout); - fwrite(&xmin, sizeof(xmin), 1, devout); - fwrite(&ymin, sizeof(ymin), 1, devout); - fwrite(&xmax, sizeof(xmax), 1, devout); - fwrite(&ymax, sizeof(ymax), 1, devout); + putw(xmin, devout); + putw(ymin, devout); + putw(xmax, devout); + putw(ymax, devout); if (nrays - lastflush >= WFLUSH) { fflush(devout); lastflush = nrays; @@ -159,8 +161,8 @@ int *xp, *yp; if (getc(devin) != COM_GETCUR) reply_error("getcur"); c = getc(devin); - fread(xp, sizeof(*xp), 1, devin); - fread(yp, sizeof(*yp), 1, devin); + *xp = getw(devin); + *yp = getw(devin); return(c); } @@ -184,7 +186,8 @@ char *buf; if (getc(devin) != COM_COMIN) reply_error("comin"); mygets(buf, devin); - comm_driver.inpready = 0; + if (comm_driver.inpready > 0) + comm_driver.inpready--; }
