1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: devcomm.c,v 2.13 2004/09/20 16:26:58 greg Exp $"; |
3 |
#endif |
4 |
5 |
* devcomm.c - communication routines for separate drivers. |
6 |
7 |
* External symbols declared in driver.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <sys/types.h> |
13 |
#include <sys/wait.h> /* XXX platform specific */ |
14 |
15 |
#include "platform.h" |
16 |
#include "standard.h" |
17 |
#include "driver.h" |
18 |
19 |
#ifndef DEVPATH |
20 |
#define DEVPATH getenv("PATH") /* device search path */ |
21 |
#endif |
22 |
23 |
FILE *devin, *devout; |
24 |
int devchild; |
25 |
26 |
static struct driver * final_connect(void); |
27 |
static void mygets(char *s, FILE *fp); |
28 |
static void myputs(char *s, FILE *fp); |
29 |
static void reply_error(char *routine); |
30 |
static void getstate(void); |
31 |
32 |
static dr_closef_t comm_close; |
33 |
static dr_clearf_t comm_clear; |
34 |
static dr_paintrf_t comm_paintr; |
35 |
static dr_getcurf_t comm_getcur; |
36 |
static dr_comoutf_t comm_comout; |
37 |
static dr_cominf_t comm_comin; |
38 |
static dr_flushf_t comm_flush; |
39 |
40 |
struct driver comm_driver = { |
41 |
comm_close, comm_clear, comm_paintr, comm_getcur, |
42 |
comm_comout, comm_comin, comm_flush |
43 |
44 |
45 |
46 |
static struct driver * |
47 |
final_connect(void) /* verify and initialize connection */ |
48 |
49 |
putw(COM_SENDM, devout); |
50 |
fflush(devout); |
51 |
if (getw(devin) != COM_RECVM) |
52 |
return(NULL); |
53 |
/* get driver parameters */ |
54 |
getstate(); |
55 |
/* set error vectors */ |
56 |
erract[COMMAND].pf = comm_comout; |
57 |
if (erract[WARNING].pf != NULL) |
58 |
erract[WARNING].pf = comm_comout; |
59 |
return(&comm_driver); |
60 |
61 |
62 |
63 |
extern struct driver * |
64 |
slave_init( /* run rview in slave mode */ |
65 |
char *dname, |
66 |
char *id |
67 |
68 |
69 |
devchild = -1; /* we're the slave here */ |
70 |
devout = stdout; /* use standard input */ |
71 |
devin = stdin; /* and standard output */ |
72 |
return(final_connect()); /* verify initialization */ |
73 |
74 |
75 |
76 |
77 |
comm_init( /* set up and execute driver */ |
78 |
char *dname, |
79 |
char *id |
80 |
81 |
82 |
char *dvcname; |
83 |
int p1[2], p2[2]; |
84 |
char pin[16], pout[16]; |
85 |
/* find driver program */ |
86 |
if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) { |
87 |
eputs(dname); |
88 |
eputs(": not found\n"); |
89 |
return(NULL); |
90 |
91 |
#ifdef RHAS_FORK_EXEC |
92 |
/* open communication pipes */ |
93 |
if (pipe(p1) == -1 || pipe(p2) == -1) |
94 |
goto syserr; |
95 |
if ((devchild = fork()) == 0) { /* fork driver process */ |
96 |
close(p1[1]); |
97 |
close(p2[0]); |
98 |
sprintf(pin, "%d", p1[0]); |
99 |
sprintf(pout, "%d", p2[1]); |
100 |
execl(dvcname, dname, pin, pout, id, NULL); |
101 |
perror(dvcname); |
102 |
_exit(127); |
103 |
104 |
if (devchild == -1) |
105 |
goto syserr; |
106 |
close(p1[0]); |
107 |
close(p2[1]); |
108 |
109 |
* Close write stream on exec to avoid multiprocessing deadlock. |
110 |
* No use in read stream without it, so set flag there as well. |
111 |
112 |
fcntl(p1[1], F_SETFD, FD_CLOEXEC); |
113 |
fcntl(p2[0], F_SETFD, FD_CLOEXEC); |
114 |
if ((devout = fdopen(p1[1], "w")) == NULL) |
115 |
goto syserr; |
116 |
if ((devin = fdopen(p2[0], "r")) == NULL) |
117 |
goto syserr; |
118 |
119 |
syserr: |
120 |
perror(dname); |
121 |
return(NULL); |
122 |
123 |
#else /* ! RHAS_FORK_EXEC */ |
124 |
125 |
eputs(dname); |
126 |
eputs(": no fork/exec\n"); |
127 |
return(NULL); |
128 |
129 |
#endif /* ! RHAS_FORK_EXEC */ |
130 |
131 |
132 |
133 |
static void |
134 |
comm_close(void) /* done with driver */ |
135 |
136 |
int pid; |
137 |
138 |
erract[COMMAND].pf = NULL; /* reset error vectors */ |
139 |
140 |
erract[WARNING].pf = wputs; |
141 |
fclose(devout); |
142 |
fclose(devin); |
143 |
if (devchild < 0) |
144 |
return; |
145 |
while ((pid = wait(0)) != -1 && pid != devchild) |
146 |
147 |
148 |
149 |
150 |
static void |
151 |
comm_clear( /* clear screen */ |
152 |
int xres, |
153 |
int yres |
154 |
155 |
156 |
putc(COM_CLEAR, devout); |
157 |
putw(xres, devout); |
158 |
putw(yres, devout); |
159 |
fflush(devout); |
160 |
161 |
162 |
163 |
static void |
164 |
comm_paintr( /* paint a rectangle */ |
165 |
COLOR col, |
166 |
int xmin, |
167 |
int ymin, |
168 |
int xmax, |
169 |
int ymax |
170 |
171 |
172 |
putc(COM_PAINTR, devout); |
173 |
fwrite((char *)col, sizeof(COLOR), 1, devout); |
174 |
putw(xmin, devout); |
175 |
putw(ymin, devout); |
176 |
putw(xmax, devout); |
177 |
putw(ymax, devout); |
178 |
179 |
180 |
181 |
static void |
182 |
comm_flush(void) /* flush output to driver */ |
183 |
184 |
putc(COM_FLUSH, devout); |
185 |
fflush(devout); |
186 |
if (getc(devin) != COM_FLUSH) |
187 |
reply_error("flush"); |
188 |
getstate(); |
189 |
190 |
191 |
192 |
static int |
193 |
comm_getcur( /* get and return cursor position */ |
194 |
int *xp, |
195 |
int *yp |
196 |
197 |
198 |
int c; |
199 |
200 |
putc(COM_GETCUR, devout); |
201 |
fflush(devout); |
202 |
if (getc(devin) != COM_GETCUR) |
203 |
reply_error("getcur"); |
204 |
c = getc(devin); |
205 |
*xp = getw(devin); |
206 |
*yp = getw(devin); |
207 |
return(c); |
208 |
209 |
210 |
211 |
static void |
212 |
comm_comout( /* print string to command line */ |
213 |
char *str |
214 |
215 |
216 |
putc(COM_COMOUT, devout); |
217 |
myputs(str, devout); |
218 |
if (str[strlen(str)-1] == '\n') |
219 |
fflush(devout); |
220 |
221 |
222 |
223 |
static void |
224 |
comm_comin( /* read string from command line */ |
225 |
char *buf, |
226 |
char *prompt |
227 |
228 |
229 |
putc(COM_COMIN, devout); |
230 |
if (prompt == NULL) |
231 |
putc(0, devout); |
232 |
else { |
233 |
putc(1, devout); |
234 |
myputs(prompt, devout); |
235 |
236 |
fflush(devout); |
237 |
if (getc(devin) != COM_COMIN) |
238 |
reply_error("comin"); |
239 |
mygets(buf, devin); |
240 |
getstate(); |
241 |
242 |
243 |
244 |
static void |
245 |
mygets( /* get string from file (with nul) */ |
246 |
register char *s, |
247 |
register FILE *fp |
248 |
249 |
250 |
register int c; |
251 |
252 |
while ((c = getc(fp)) != EOF) |
253 |
if ((*s++ = c) == '\0') |
254 |
return; |
255 |
*s = '\0'; |
256 |
257 |
258 |
259 |
static void |
260 |
myputs( /* put string to file (with nul) */ |
261 |
register char *s, |
262 |
register FILE *fp |
263 |
264 |
265 |
do |
266 |
putc(*s, fp); |
267 |
while (*s++); |
268 |
269 |
270 |
271 |
static void |
272 |
reply_error( /* what should we do here? */ |
273 |
char *routine |
274 |
275 |
276 |
eputs(routine); |
277 |
eputs(": driver reply error\n"); |
278 |
quit(1); |
279 |
280 |
281 |
282 |
static void |
283 |
getstate(void) /* get driver state variables */ |
284 |
285 |
fread((char *)&comm_driver.pixaspect, |
286 |
sizeof(comm_driver.pixaspect), 1, devin); |
287 |
comm_driver.xsiz = getw(devin); |
288 |
comm_driver.ysiz = getw(devin); |
289 |
comm_driver.inpready = getw(devin); |
290 |
