1 |
/* Copyright (c) 1988 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* devcomm.c - communication routines for separate drivers. |
9 |
10 |
* 10/5/88 |
11 |
12 |
13 |
#include <stdio.h> |
14 |
15 |
#include <signal.h> |
16 |
17 |
#include "color.h" |
18 |
19 |
#include "driver.h" |
20 |
21 |
#ifndef DEVPATH |
22 |
#define DEVPATH getenv("PATH") /* device search path */ |
23 |
#endif |
24 |
25 |
#ifndef BSD |
26 |
#define vfork fork |
27 |
#endif |
28 |
29 |
#ifndef WFLUSH |
30 |
#define WFLUSH 30 /* flush after this many rays */ |
31 |
#endif |
32 |
33 |
extern char *getpath(), *getenv(); |
34 |
35 |
int onsigio(); |
36 |
37 |
int comm_close(), comm_clear(), comm_paintr(), comm_errout(), |
38 |
comm_getcur(), comm_comout(), comm_comin(); |
39 |
40 |
struct driver comm_driver, comm_default = { |
41 |
comm_close, comm_clear, comm_paintr, comm_getcur, |
42 |
comm_comout, comm_comin, |
43 |
MAXRES, MAXRES, 0 |
44 |
45 |
46 |
FILE *devin, *devout; |
47 |
48 |
int devchild; |
49 |
50 |
51 |
struct driver * |
52 |
comm_init(argv) /* set up and execute driver */ |
53 |
char *argv[]; |
54 |
55 |
char *devname; |
56 |
int p1[2], p2[2]; |
57 |
58 |
if ((devname = getpath(argv[0], DEVPATH)) == NULL) { |
59 |
stderr_v(argv[0]); |
60 |
stderr_v(": not found\n"); |
61 |
return(NULL); |
62 |
63 |
if (pipe(p1) == -1 || pipe(p2) == -1) |
64 |
goto syserr; |
65 |
if ((devchild = vfork()) == 0) { |
66 |
close(p1[1]); |
67 |
close(p2[0]); |
68 |
if (p1[0] != 0) { |
69 |
dup2(p1[0], 0); |
70 |
close(p1[0]); |
71 |
72 |
if (p2[1] != 1) { |
73 |
dup2(p2[1], 1); |
74 |
close(p2[1]); |
75 |
76 |
execv(devname, argv); |
77 |
stderr_v(devname); |
78 |
stderr_v(": cannot execute\n"); |
79 |
_exit(127); |
80 |
81 |
if (devchild == -1) |
82 |
goto syserr; |
83 |
close(p1[0]); |
84 |
close(p2[1]); |
85 |
if ((devout = fdopen(p1[1], "w")) == NULL) |
86 |
goto syserr; |
87 |
if ((devin = fdopen(p2[0], "r")) == NULL) |
88 |
goto syserr; |
89 |
bcopy(&comm_default, &comm_driver, sizeof(comm_driver)); |
90 |
signal(SIGIO, onsigio); |
91 |
cmdvec = comm_comout; /* set error vectors */ |
92 |
if (wrnvec != NULL) |
93 |
wrnvec = comm_comout; |
94 |
return(&comm_driver); |
95 |
syserr: |
96 |
perror(argv[0]); |
97 |
return(NULL); |
98 |
99 |
100 |
101 |
static |
102 |
comm_close() /* done with driver */ |
103 |
104 |
int pid; |
105 |
106 |
cmdvec = NULL; /* reset error vectors */ |
107 |
108 |
wrnvec = stderr_v; |
109 |
signal(SIGIO, SIG_DFL); |
110 |
fclose(devout); |
111 |
fclose(devin); |
112 |
while ((pid = wait(0)) != -1 && pid != devchild) |
113 |
114 |
115 |
116 |
117 |
static |
118 |
comm_clear(xres, yres) /* clear screen */ |
119 |
int xres, yres; |
120 |
121 |
putc(COM_CLEAR, devout); |
122 |
fwrite(&xres, sizeof(xres), 1, devout); |
123 |
fwrite(&yres, sizeof(yres), 1, devout); |
124 |
fflush(devout); |
125 |
126 |
127 |
128 |
static |
129 |
comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */ |
130 |
COLOR col; |
131 |
int xmin, ymin, xmax, ymax; |
132 |
133 |
extern long nrays; /* number of rays traced */ |
134 |
static long lastflush = 0; /* ray count at last flush */ |
135 |
136 |
putc(COM_PAINTR, devout); |
137 |
fwrite(col, sizeof(COLOR), 1, devout); |
138 |
fwrite(&xmin, sizeof(xmin), 1, devout); |
139 |
fwrite(&ymin, sizeof(ymin), 1, devout); |
140 |
fwrite(&xmax, sizeof(xmax), 1, devout); |
141 |
fwrite(&ymax, sizeof(ymax), 1, devout); |
142 |
if (nrays - lastflush >= WFLUSH) { |
143 |
fflush(devout); |
144 |
lastflush = nrays; |
145 |
146 |
147 |
148 |
149 |
static int |
150 |
comm_getcur(xp, yp) /* get and return cursor position */ |
151 |
int *xp, *yp; |
152 |
153 |
int c; |
154 |
155 |
putc(COM_GETCUR, devout); |
156 |
fflush(devout); |
157 |
if (getc(devin) != COM_GETCUR) |
158 |
reply_error("getcur"); |
159 |
c = getc(devin); |
160 |
fread(xp, sizeof(*xp), 1, devin); |
161 |
fread(yp, sizeof(*yp), 1, devin); |
162 |
return(c); |
163 |
164 |
165 |
166 |
static |
167 |
comm_comout(str) /* print string to command line */ |
168 |
char *str; |
169 |
170 |
putc(COM_COMOUT, devout); |
171 |
myputs(str, devout); |
172 |
fflush(devout); |
173 |
174 |
175 |
176 |
static |
177 |
comm_comin(buf) /* read string from command line */ |
178 |
char *buf; |
179 |
180 |
putc(COM_COMIN, devout); |
181 |
fflush(devout); |
182 |
if (getc(devin) != COM_COMIN) |
183 |
reply_error("comin"); |
184 |
mygets(buf, devin); |
185 |
comm_driver.inpready = 0; |
186 |
187 |
188 |
189 |
static |
190 |
comm_errout(str) /* display an error message */ |
191 |
char *str; |
192 |
193 |
comm_comout(str); |
194 |
stderr_v(str); /* send to standard error also */ |
195 |
196 |
197 |
198 |
static |
199 |
mygets(s, fp) /* get string from file (with nul) */ |
200 |
register char *s; |
201 |
register FILE *fp; |
202 |
203 |
register int c; |
204 |
205 |
while ((c = getc(fp)) != EOF) |
206 |
if ((*s++ = c) == '\0') |
207 |
return; |
208 |
*s = '\0'; |
209 |
210 |
211 |
212 |
static |
213 |
myputs(s, fp) /* put string to file (with nul) */ |
214 |
register char *s; |
215 |
216 |
217 |
do |
218 |
putc(*s, fp); |
219 |
while (*s++); |
220 |
221 |
222 |
223 |
static |
224 |
reply_error(routine) /* what should we do here? */ |
225 |
char *routine; |
226 |
227 |
stderr_v(routine); |
228 |
stderr_v(": driver reply error\n"); |
229 |
quit(1); |
230 |
231 |
232 |
233 |
static |
234 |
onsigio() /* input ready */ |
235 |
236 |
comm_driver.inpready++; |
237 |
