--- ray/src/rt/devcomm.c 2003/02/22 02:07:28 2.6
+++ ray/src/rt/devcomm.c 2014/07/08 18:25:00 2.17
@@ -1,5 +1,5 @@
#ifndef lint
-static const char RCSid[] = "$Id: devcomm.c,v 2.6 2003/02/22 02:07:28 greg Exp $";
+static const char RCSid[] = "$Id: devcomm.c,v 2.17 2014/07/08 18:25:00 greg Exp $";
#endif
* devcomm.c - communication routines for separate drivers.
@@ -7,93 +7,47 @@ static const char RCSid[] = "$Id: devcomm.c,v 2.6 2003
* External symbols declared in driver.h
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
-#include "standard.h"
+#include
+#ifndef _WIN32
+#include
+#endif
-#include "color.h"
+#include "paths.h"
+#include "platform.h"
+#include "standard.h"
#include "driver.h"
-#include "vfork.h"
#ifndef DEVPATH
#define DEVPATH getenv("PATH") /* device search path */
#endif
-static int comm_getcur();
-static void comm_close(), comm_clear(), comm_paintr(),
- comm_comin(), comm_comout(), comm_flush();
+FILE *devin, *devout;
+int devchild;
+static struct driver * final_connect(void);
+static void mygets(char *s, FILE *fp);
+static void myputs(char *s, FILE *fp);
+static void reply_error(char *routine);
+static void getstate(void);
+static dr_closef_t comm_close;
+static dr_clearf_t comm_clear;
+static dr_paintrf_t comm_paintr;
+static dr_getcurf_t comm_getcur;
+static dr_comoutf_t comm_comout;
+static dr_cominf_t comm_comin;
+static dr_flushf_t comm_flush;
struct driver comm_driver = {
comm_close, comm_clear, comm_paintr, comm_getcur,
comm_comout, comm_comin, comm_flush
-static void mygets(), myputs(), reply_error(), getstate();
-FILE *devin, *devout;
-int devchild;
-final_connect() /* verify and initialize connection */
+final_connect(void) /* verify and initialize connection */
putw(COM_SENDM, devout);
fflush(devout);
@@ -103,15 +57,19 @@ final_connect() /* verify and initialize connection
getstate();
/* set error vectors */
erract[COMMAND].pf = comm_comout;
+ /* doesn't work with raypcalls.c
if (erract[WARNING].pf != NULL)
erract[WARNING].pf = comm_comout;
return(&comm_driver);
struct driver *
-slave_init(dname, id) /* run rview in slave mode */
-char *dname, *id;
+slave_init( /* run rview in slave mode */
+ char *dname,
+ char *id
devchild = -1; /* we're the slave here */
devout = stdout; /* use standard input */
@@ -121,8 +79,10 @@ char *dname, *id;
struct driver *
-comm_init(dname, id) /* set up and execute driver */
-char *dname, *id;
+comm_init( /* set up and execute driver */
+ char *dname,
+ char *id
char *dvcname;
int p1[2], p2[2];
@@ -133,15 +93,16 @@ char *dname, *id;
eputs(": not found\n");
return(NULL);
+#ifdef RHAS_FORK_EXEC
/* open communication pipes */
if (pipe(p1) == -1 || pipe(p2) == -1)
goto syserr;
- if ((devchild = vfork()) == 0) { /* fork driver process */
+ if ((devchild = fork()) == 0) { /* fork driver process */
close(p1[1]);
close(p2[0]);
sprintf(pin, "%d", p1[0]);
sprintf(pout, "%d", p2[1]);
- execl(dvcname, dname, pin, pout, id, 0);
+ execl(dvcname, dname, pin, pout, id, NULL);
perror(dvcname);
_exit(127);
@@ -149,6 +110,12 @@ char *dname, *id;
goto syserr;
close(p1[0]);
close(p2[1]);
+ * Close write stream on exec to avoid multiprocessing deadlock.
+ * No use in read stream without it, so set flag there as well.
+ fcntl(p1[1], F_SETFD, FD_CLOEXEC);
+ fcntl(p2[0], F_SETFD, FD_CLOEXEC);
if ((devout = fdopen(p1[1], "w")) == NULL)
goto syserr;
if ((devin = fdopen(p2[0], "r")) == NULL)
@@ -157,11 +124,19 @@ char *dname, *id;
syserr:
perror(dname);
return(NULL);
+#else /* ! RHAS_FORK_EXEC */
+ eputs(dname);
+ eputs(": no fork/exec\n");
+ return(NULL);
+#endif /* ! RHAS_FORK_EXEC */
static void
-comm_close() /* done with driver */
+comm_close(void) /* done with driver */
int pid;
@@ -172,14 +147,18 @@ comm_close() /* done with driver */
fclose(devin);
if (devchild < 0)
return;
+#ifndef _WIN32
while ((pid = wait(0)) != -1 && pid != devchild)
+#endif
static void
-comm_clear(xres, yres) /* clear screen */
-int xres, yres;
+comm_clear( /* clear screen */
+ int xres,
+ int yres
putc(COM_CLEAR, devout);
putw(xres, devout);
@@ -189,9 +168,13 @@ int xres, yres;
static void
-comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
-COLOR col;
-int xmin, ymin, xmax, ymax;
+comm_paintr( /* paint a rectangle */
+ COLOR col,
+ int xmin,
+ int ymin,
+ int xmax,
+ int ymax
putc(COM_PAINTR, devout);
fwrite((char *)col, sizeof(COLOR), 1, devout);
@@ -203,7 +186,7 @@ int xmin, ymin, xmax, ymax;
static void
-comm_flush() /* flush output to driver */
+comm_flush(void) /* flush output to driver */
putc(COM_FLUSH, devout);
fflush(devout);
@@ -214,8 +197,10 @@ comm_flush() /* flush output to driver */
static int
-comm_getcur(xp, yp) /* get and return cursor position */
-int *xp, *yp;
+comm_getcur( /* get and return cursor position */
+ int *xp,
+ int *yp
int c;
@@ -231,8 +216,9 @@ int *xp, *yp;
static void
-comm_comout(str) /* print string to command line */
-char *str;
+comm_comout( /* print string to command line */
+ char *str
putc(COM_COMOUT, devout);
myputs(str, devout);
@@ -242,9 +228,10 @@ char *str;
static void
-comm_comin(buf, prompt) /* read string from command line */
-char *buf;
-char *prompt;
+comm_comin( /* read string from command line */
+ char *buf,
+ char *prompt
putc(COM_COMIN, devout);
if (prompt == NULL)
@@ -262,11 +249,12 @@ char *prompt;
static void
-mygets(s, fp) /* get string from file (with nul) */
-register char *s;
-register FILE *fp;
+mygets( /* get string from file (with nul) */
+ char *s,
+ FILE *fp
- register int c;
+ int c;
while ((c = getc(fp)) != EOF)
if ((*s++ = c) == '\0')
@@ -276,9 +264,10 @@ register FILE *fp;
static void
-myputs(s, fp) /* put string to file (with nul) */
-register char *s;
-register FILE *fp;
+myputs( /* put string to file (with nul) */
+ char *s,
+ FILE *fp
do
putc(*s, fp);
@@ -287,8 +276,9 @@ register FILE *fp;
static void
-reply_error(routine) /* what should we do here? */
-char *routine;
+reply_error( /* what should we do here? */
+ char *routine
eputs(routine);
eputs(": driver reply error\n");
@@ -297,7 +287,7 @@ char *routine;
static void
-getstate() /* get driver state variables */
+getstate(void) /* get driver state variables */
fread((char *)&comm_driver.pixaspect,
sizeof(comm_driver.pixaspect), 1, devin);
