root/radiance/ray/src/rt/devcomm.c
Revision: 2.6
Committed: Sat Feb 22 02:07:28 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.5: +77 -22 lines
5 * devcomm.c - communication routines for separate drivers.
6 *
7 * External symbols declared in driver.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include "standard.h"
68
69 #include "color.h"
70
71 #include "driver.h"
72
73 #include "vfork.h"
74
75 #ifndef DEVPATH
76 #define DEVPATH getenv("PATH") /* device search path */
77 #endif
78
79 static int comm_getcur();
80 static void comm_close(), comm_clear(), comm_paintr(),
81 comm_comin(), comm_comout(), comm_flush();
82
83 struct driver comm_driver = {
84 comm_close, comm_clear, comm_paintr, comm_getcur,
85 comm_comout, comm_comin, comm_flush
86 };
87
88 static void mygets(), myputs(), reply_error(), getstate();
89
90 FILE *devin, *devout;
91
92 int devchild;
93
94
95 static struct driver *
96 final_connect() /* verify and initialize connection */
97 {
98 putw(COM_SENDM, devout);
99 fflush(devout);
100 if (getw(devin) != COM_RECVM)
101 return(NULL);
102 /* get driver parameters */
103 getstate();
104 /* set error vectors */
105 erract[COMMAND].pf = comm_comout;
106 if (erract[WARNING].pf != NULL)
107 erract[WARNING].pf = comm_comout;
108 return(&comm_driver);
109 }
110
111
112 struct driver *
113 slave_init(dname, id) /* run rview in slave mode */
114 char *dname, *id;
115 {
116 devchild = -1; /* we're the slave here */
117 devout = stdout; /* use standard input */
118 devin = stdin; /* and standard output */
119 return(final_connect()); /* verify initialization */
120 }
121
122
123 struct driver *
124 comm_init(dname, id) /* set up and execute driver */
125 char *dname, *id;
126 {
127 char *dvcname;
128 int p1[2], p2[2];
129 char pin[16], pout[16];
130 /* find driver program */
131 if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) {
132 eputs(dname);
133 eputs(": not found\n");
134 return(NULL);
135 }
136 /* open communication pipes */
137 if (pipe(p1) == -1 || pipe(p2) == -1)
138 goto syserr;
139 if ((devchild = vfork()) == 0) { /* fork driver process */
140 close(p1[1]);
141 close(p2[0]);
142 sprintf(pin, "%d", p1[0]);
143 sprintf(pout, "%d", p2[1]);
144 execl(dvcname, dname, pin, pout, id, 0);
145 perror(dvcname);
146 _exit(127);
147 }
148 if (devchild == -1)
149 goto syserr;
150 close(p1[0]);
151 close(p2[1]);
152 if ((devout = fdopen(p1[1], "w")) == NULL)
153 goto syserr;
154 if ((devin = fdopen(p2[0], "r")) == NULL)
155 goto syserr;
156 return(final_connect()); /* verify initialization */
157 syserr:
158 perror(dname);
159 return(NULL);
160 }
161
162
163 static void
164 comm_close() /* done with driver */
165 {
166 int pid;
167
168 erract[COMMAND].pf = NULL; /* reset error vectors */
169 if (erract[WARNING].pf != NULL)
170 erract[WARNING].pf = wputs;
171 fclose(devout);
172 fclose(devin);
173 if (devchild < 0)
174 return;
175 while ((pid = wait(0)) != -1 && pid != devchild)
176 ;
177 }
178
179
180 static void
181 comm_clear(xres, yres) /* clear screen */
182 int xres, yres;
183 {
184 putc(COM_CLEAR, devout);
185 putw(xres, devout);
186 putw(yres, devout);
187 fflush(devout);
188 }
189
190
191 static void
192 comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
193 COLOR col;
194 int xmin, ymin, xmax, ymax;
195 {
196 putc(COM_PAINTR, devout);
197 fwrite((char *)col, sizeof(COLOR), 1, devout);
198 putw(xmin, devout);
199 putw(ymin, devout);
200 putw(xmax, devout);
201 putw(ymax, devout);
202 }
203
204
205 static void
206 comm_flush() /* flush output to driver */
207 {
208 putc(COM_FLUSH, devout);
209 fflush(devout);
210 if (getc(devin) != COM_FLUSH)
211 reply_error("flush");
212 getstate();
213 }
214
215
216 static int
217 comm_getcur(xp, yp) /* get and return cursor position */
218 int *xp, *yp;
219 {
220 int c;
221
222 putc(COM_GETCUR, devout);
223 fflush(devout);
224 if (getc(devin) != COM_GETCUR)
225 reply_error("getcur");
226 c = getc(devin);
227 *xp = getw(devin);
228 *yp = getw(devin);
229 return(c);
230 }
231
232
233 static void
234 comm_comout(str) /* print string to command line */
235 char *str;
236 {
237 putc(COM_COMOUT, devout);
238 myputs(str, devout);
239 if (str[strlen(str)-1] == '\n')
240 fflush(devout);
241 }
242
243
244 static void
245 comm_comin(buf, prompt) /* read string from command line */
246 char *buf;
247 char *prompt;
248 {
249 putc(COM_COMIN, devout);
250 if (prompt == NULL)
251 putc(0, devout);
252 else {
253 putc(1, devout);
254 myputs(prompt, devout);
255 }
256 fflush(devout);
257 if (getc(devin) != COM_COMIN)
258 reply_error("comin");
259 mygets(buf, devin);
260 getstate();
261 }
262
263
264 static void
265 mygets(s, fp) /* get string from file (with nul) */
266 register char *s;
267 register FILE *fp;
268 {
269 register int c;
270
271 while ((c = getc(fp)) != EOF)
272 if ((*s++ = c) == '\0')
273 return;
274 *s = '\0';
275 }
276
277
278 static void
279 myputs(s, fp) /* put string to file (with nul) */
280 register char *s;
281 register FILE *fp;
282 {
283 do
284 putc(*s, fp);
285 while (*s++);
286 }
287
288
289 static void
290 reply_error(routine) /* what should we do here? */
291 char *routine;
292 {
293 eputs(routine);
294 eputs(": driver reply error\n");
295 quit(1);
296 }
297
298
299 static void
300 getstate() /* get driver state variables */
301 {
302 fread((char *)&comm_driver.pixaspect,
303 sizeof(comm_driver.pixaspect), 1, devin);
304 comm_driver.xsiz = getw(devin);
305 comm_driver.ysiz = getw(devin);
306 comm_driver.inpready = getw(devin);
307 }
