| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: devcomm.c,v 2.14 2008/05/01 15:50:28 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* devcomm.c - communication routines for separate drivers.
| 6 |
| 7 |
* External symbols declared in driver.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <sys/types.h>
| 13 |
#include <sys/wait.h> /* XXX platform specific */
| 14 |
| 15 |
#include "platform.h"
| 16 |
#include "standard.h"
| 17 |
#include "driver.h"
| 18 |
| 19 |
#ifndef DEVPATH
| 20 |
#define DEVPATH getenv("PATH") /* device search path */
| 21 |
#endif
| 22 |
| 23 |
FILE *devin, *devout;
| 24 |
int devchild;
| 25 |
| 26 |
static struct driver * final_connect(void);
| 27 |
static void mygets(char *s, FILE *fp);
| 28 |
static void myputs(char *s, FILE *fp);
| 29 |
static void reply_error(char *routine);
| 30 |
static void getstate(void);
| 31 |
| 32 |
static dr_closef_t comm_close;
| 33 |
static dr_clearf_t comm_clear;
| 34 |
static dr_paintrf_t comm_paintr;
| 35 |
static dr_getcurf_t comm_getcur;
| 36 |
static dr_comoutf_t comm_comout;
| 37 |
static dr_cominf_t comm_comin;
| 38 |
static dr_flushf_t comm_flush;
| 39 |
| 40 |
struct driver comm_driver = {
| 41 |
comm_close, comm_clear, comm_paintr, comm_getcur,
| 42 |
comm_comout, comm_comin, comm_flush
| 43 |
| 44 |
| 45 |
| 46 |
| 47 |
final_connect(void) /* verify and initialize connection */
| 48 |
| 49 |
putw(COM_SENDM, devout);
| 50 |
fflush(devout);
| 51 |
if (getw(devin) != COM_RECVM)
| 52 |
return(NULL);
| 53 |
/* get driver parameters */
| 54 |
getstate();
| 55 |
/* set error vectors */
| 56 |
erract[COMMAND].pf = comm_comout;
| 57 |
/* doesn't work with raypcalls.c
| 58 |
if (erract[WARNING].pf != NULL)
| 59 |
erract[WARNING].pf = comm_comout;
| 60 |
| 61 |
return(&comm_driver);
| 62 |
| 63 |
| 64 |
| 65 |
extern struct driver *
| 66 |
slave_init( /* run rview in slave mode */
| 67 |
char *dname,
| 68 |
char *id
| 69 |
| 70 |
| 71 |
devchild = -1; /* we're the slave here */
| 72 |
devout = stdout; /* use standard input */
| 73 |
devin = stdin; /* and standard output */
| 74 |
return(final_connect()); /* verify initialization */
| 75 |
| 76 |
| 77 |
| 78 |
| 79 |
comm_init( /* set up and execute driver */
| 80 |
char *dname,
| 81 |
char *id
| 82 |
| 83 |
| 84 |
char *dvcname;
| 85 |
int p1[2], p2[2];
| 86 |
char pin[16], pout[16];
| 87 |
/* find driver program */
| 88 |
if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) {
| 89 |
eputs(dname);
| 90 |
eputs(": not found\n");
| 91 |
return(NULL);
| 92 |
| 93 |
#ifdef RHAS_FORK_EXEC
| 94 |
/* open communication pipes */
| 95 |
if (pipe(p1) == -1 || pipe(p2) == -1)
| 96 |
goto syserr;
| 97 |
if ((devchild = fork()) == 0) { /* fork driver process */
| 98 |
close(p1[1]);
| 99 |
close(p2[0]);
| 100 |
sprintf(pin, "%d", p1[0]);
| 101 |
sprintf(pout, "%d", p2[1]);
| 102 |
execl(dvcname, dname, pin, pout, id, NULL);
| 103 |
perror(dvcname);
| 104 |
_exit(127);
| 105 |
| 106 |
if (devchild == -1)
| 107 |
goto syserr;
| 108 |
close(p1[0]);
| 109 |
close(p2[1]);
| 110 |
| 111 |
* Close write stream on exec to avoid multiprocessing deadlock.
| 112 |
* No use in read stream without it, so set flag there as well.
| 113 |
| 114 |
fcntl(p1[1], F_SETFD, FD_CLOEXEC);
| 115 |
fcntl(p2[0], F_SETFD, FD_CLOEXEC);
| 116 |
if ((devout = fdopen(p1[1], "w")) == NULL)
| 117 |
goto syserr;
| 118 |
if ((devin = fdopen(p2[0], "r")) == NULL)
| 119 |
goto syserr;
| 120 |
| 121 |
syserr:
| 122 |
perror(dname);
| 123 |
return(NULL);
| 124 |
| 125 |
#else /* ! RHAS_FORK_EXEC */
| 126 |
| 127 |
eputs(dname);
| 128 |
eputs(": no fork/exec\n");
| 129 |
return(NULL);
| 130 |
| 131 |
#endif /* ! RHAS_FORK_EXEC */
| 132 |
| 133 |
| 134 |
| 135 |
static void
| 136 |
comm_close(void) /* done with driver */
| 137 |
| 138 |
int pid;
| 139 |
| 140 |
erract[COMMAND].pf = NULL; /* reset error vectors */
| 141 |
| 142 |
erract[WARNING].pf = wputs;
| 143 |
fclose(devout);
| 144 |
fclose(devin);
| 145 |
if (devchild < 0)
| 146 |
return;
| 147 |
while ((pid = wait(0)) != -1 && pid != devchild)
| 148 |
| 149 |
| 150 |
| 151 |
| 152 |
static void
| 153 |
comm_clear( /* clear screen */
| 154 |
int xres,
| 155 |
int yres
| 156 |
| 157 |
| 158 |
putc(COM_CLEAR, devout);
| 159 |
putw(xres, devout);
| 160 |
putw(yres, devout);
| 161 |
fflush(devout);
| 162 |
| 163 |
| 164 |
| 165 |
static void
| 166 |
comm_paintr( /* paint a rectangle */
| 167 |
COLOR col,
| 168 |
int xmin,
| 169 |
int ymin,
| 170 |
int xmax,
| 171 |
int ymax
| 172 |
| 173 |
| 174 |
putc(COM_PAINTR, devout);
| 175 |
fwrite((char *)col, sizeof(COLOR), 1, devout);
| 176 |
putw(xmin, devout);
| 177 |
putw(ymin, devout);
| 178 |
putw(xmax, devout);
| 179 |
putw(ymax, devout);
| 180 |
| 181 |
| 182 |
| 183 |
static void
| 184 |
comm_flush(void) /* flush output to driver */
| 185 |
| 186 |
putc(COM_FLUSH, devout);
| 187 |
fflush(devout);
| 188 |
if (getc(devin) != COM_FLUSH)
| 189 |
reply_error("flush");
| 190 |
getstate();
| 191 |
| 192 |
| 193 |
| 194 |
static int
| 195 |
comm_getcur( /* get and return cursor position */
| 196 |
int *xp,
| 197 |
int *yp
| 198 |
| 199 |
| 200 |
int c;
| 201 |
| 202 |
putc(COM_GETCUR, devout);
| 203 |
fflush(devout);
| 204 |
if (getc(devin) != COM_GETCUR)
| 205 |
reply_error("getcur");
| 206 |
c = getc(devin);
| 207 |
*xp = getw(devin);
| 208 |
*yp = getw(devin);
| 209 |
return(c);
| 210 |
| 211 |
| 212 |
| 213 |
static void
| 214 |
comm_comout( /* print string to command line */
| 215 |
char *str
| 216 |
| 217 |
| 218 |
putc(COM_COMOUT, devout);
| 219 |
myputs(str, devout);
| 220 |
if (str[strlen(str)-1] == '\n')
| 221 |
fflush(devout);
| 222 |
| 223 |
| 224 |
| 225 |
static void
| 226 |
comm_comin( /* read string from command line */
| 227 |
char *buf,
| 228 |
char *prompt
| 229 |
| 230 |
| 231 |
putc(COM_COMIN, devout);
| 232 |
if (prompt == NULL)
| 233 |
putc(0, devout);
| 234 |
else {
| 235 |
putc(1, devout);
| 236 |
myputs(prompt, devout);
| 237 |
| 238 |
fflush(devout);
| 239 |
if (getc(devin) != COM_COMIN)
| 240 |
reply_error("comin");
| 241 |
mygets(buf, devin);
| 242 |
getstate();
| 243 |
| 244 |
| 245 |
| 246 |
static void
| 247 |
mygets( /* get string from file (with nul) */
| 248 |
register char *s,
| 249 |
register FILE *fp
| 250 |
| 251 |
| 252 |
register int c;
| 253 |
| 254 |
while ((c = getc(fp)) != EOF)
| 255 |
if ((*s++ = c) == '\0')
| 256 |
return;
| 257 |
*s = '\0';
| 258 |
| 259 |
| 260 |
| 261 |
static void
| 262 |
myputs( /* put string to file (with nul) */
| 263 |
register char *s,
| 264 |
register FILE *fp
| 265 |
| 266 |
| 267 |
do
| 268 |
putc(*s, fp);
| 269 |
while (*s++);
| 270 |
| 271 |
| 272 |
| 273 |
static void
| 274 |
reply_error( /* what should we do here? */
| 275 |
char *routine
| 276 |
| 277 |
| 278 |
eputs(routine);
| 279 |
eputs(": driver reply error\n");
| 280 |
quit(1);
| 281 |
| 282 |
| 283 |
| 284 |
static void
| 285 |
getstate(void) /* get driver state variables */
| 286 |
| 287 |
fread((char *)&comm_driver.pixaspect,
| 288 |
sizeof(comm_driver.pixaspect), 1, devin);
| 289 |
comm_driver.xsiz = getw(devin);
| 290 |
comm_driver.ysiz = getw(devin);
| 291 |
comm_driver.inpready = getw(devin);
| 292 |
