root/radiance/ray/src/rt/devcomm.c
Revision: 2.4
Committed: Thu Nov 18 09:42:58 1993 UTC (30 years, 7 months ago) by greg
minor compiler warning fixes
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devcomm.c - communication routines for separate drivers.
9 *
10 * 10/5/88
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "driver.h"
18
19 #include "vfork.h"
20
21 #ifndef DEVPATH
22 #define DEVPATH getenv("PATH") /* device search path */
23 #endif
24
25 static int comm_close(), comm_clear(), comm_paintr(),
26 comm_getcur(), comm_comout(), comm_comin(), comm_flush();
27
28 struct driver comm_driver = {
29 comm_close, comm_clear, comm_paintr, comm_getcur,
30 comm_comout, comm_comin, comm_flush
31 };
32
33 static int mygets(), myputs(), reply_error(), getstate();
34
35 FILE *devin, *devout;
36
37 int devchild;
38
39
40 static struct driver *
41 final_connect() /* verify and initialize connection */
42 {
43 putw(COM_SENDM, devout);
44 fflush(devout);
45 if (getw(devin) != COM_RECVM)
46 return(NULL);
47 /* get driver parameters */
48 getstate();
49 /* set error vectors */
50 cmdvec = comm_comout;
51 if (wrnvec != NULL)
52 wrnvec = comm_comout;
53 return(&comm_driver);
54 }
55
56
57 struct driver *
58 slave_init(dname, id) /* run rview in slave mode */
59 char *dname, *id;
60 {
61 devchild = -1; /* we're the slave here */
62 devout = stdout; /* use standard input */
63 devin = stdin; /* and standard output */
64 return(final_connect()); /* verify initialization */
65 }
66
67
68 struct driver *
69 comm_init(dname, id) /* set up and execute driver */
70 char *dname, *id;
71 {
72 char *devname;
73 int p1[2], p2[2];
74 char pin[16], pout[16];
75 /* find driver program */
76 if ((devname = getpath(dname, DEVPATH, X_OK)) == NULL) {
77 stderr_v(dname);
78 stderr_v(": not found\n");
79 return(NULL);
80 }
81 /* open communication pipes */
82 if (pipe(p1) == -1 || pipe(p2) == -1)
83 goto syserr;
84 if ((devchild = vfork()) == 0) { /* fork driver process */
85 close(p1[1]);
86 close(p2[0]);
87 sprintf(pin, "%d", p1[0]);
88 sprintf(pout, "%d", p2[1]);
89 execl(devname, dname, pin, pout, id, 0);
90 perror(devname);
91 _exit(127);
92 }
93 if (devchild == -1)
94 goto syserr;
95 close(p1[0]);
96 close(p2[1]);
97 if ((devout = fdopen(p1[1], "w")) == NULL)
98 goto syserr;
99 if ((devin = fdopen(p2[0], "r")) == NULL)
100 goto syserr;
101 return(final_connect()); /* verify initialization */
102 syserr:
103 perror(dname);
104 return(NULL);
105 }
106
107
108 static
109 comm_close() /* done with driver */
110 {
111 int pid;
112
113 cmdvec = NULL; /* reset error vectors */
114 if (wrnvec != NULL)
115 wrnvec = stderr_v;
116 fclose(devout);
117 fclose(devin);
118 if (devchild < 0)
119 return;
120 while ((pid = wait(0)) != -1 && pid != devchild)
121 ;
122 }
123
124
125 static
126 comm_clear(xres, yres) /* clear screen */
127 int xres, yres;
128 {
129 putc(COM_CLEAR, devout);
130 putw(xres, devout);
131 putw(yres, devout);
132 fflush(devout);
133 }
134
135
136 static
137 comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
138 COLOR col;
139 int xmin, ymin, xmax, ymax;
140 {
141 putc(COM_PAINTR, devout);
142 fwrite((char *)col, sizeof(COLOR), 1, devout);
143 putw(xmin, devout);
144 putw(ymin, devout);
145 putw(xmax, devout);
146 putw(ymax, devout);
147 }
148
149
150 static
151 comm_flush() /* flush output to driver */
152 {
153 putc(COM_FLUSH, devout);
154 fflush(devout);
155 if (getc(devin) != COM_FLUSH)
156 reply_error("flush");
157 getstate();
158 }
159
160
161 static int
162 comm_getcur(xp, yp) /* get and return cursor position */
163 int *xp, *yp;
164 {
165 int c;
166
167 putc(COM_GETCUR, devout);
168 fflush(devout);
169 if (getc(devin) != COM_GETCUR)
170 reply_error("getcur");
171 c = getc(devin);
172 *xp = getw(devin);
173 *yp = getw(devin);
174 return(c);
175 }
176
177
178 static
179 comm_comout(str) /* print string to command line */
180 char *str;
181 {
182 putc(COM_COMOUT, devout);
183 myputs(str, devout);
184 if (str[strlen(str)-1] == '\n')
185 fflush(devout);
186 }
187
188
189 static
190 comm_comin(buf, prompt) /* read string from command line */
191 char *buf;
192 char *prompt;
193 {
194 putc(COM_COMIN, devout);
195 if (prompt == NULL)
196 putc(0, devout);
197 else {
198 putc(1, devout);
199 myputs(prompt, devout);
200 }
201 fflush(devout);
202 if (getc(devin) != COM_COMIN)
203 reply_error("comin");
204 mygets(buf, devin);
205 getstate();
206 }
207
208
209 static
210 mygets(s, fp) /* get string from file (with nul) */
211 register char *s;
212 register FILE *fp;
213 {
214 register int c;
215
216 while ((c = getc(fp)) != EOF)
217 if ((*s++ = c) == '\0')
218 return;
219 *s = '\0';
220 }
221
222
223 static
224 myputs(s, fp) /* put string to file (with nul) */
225 register char *s;
226 register FILE *fp;
227 {
228 do
229 putc(*s, fp);
230 while (*s++);
231 }
232
233
234 static
235 reply_error(routine) /* what should we do here? */
236 char *routine;
237 {
238 stderr_v(routine);
239 stderr_v(": driver reply error\n");
240 quit(1);
241 }
242
243
244 static
245 getstate() /* get driver state variables */
246 {
247 fread((char *)&comm_driver.pixaspect,
248 sizeof(comm_driver.pixaspect), 1, devin);
249 comm_driver.xsiz = getw(devin);
250 comm_driver.ysiz = getw(devin);
251 comm_driver.inpready = getw(devin);
252 }
