root/radiance/ray/src/rt/devcomm.c
Revision: 1.15
Committed: Tue Mar 6 17:44:37 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.14: +11 -5 lines
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devcomm.c - communication routines for separate drivers.
9 *
10 * 10/5/88
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "driver.h"
18
19 #ifndef DEVPATH
20 #define DEVPATH getenv("PATH") /* device search path */
21 #endif
22
23 #ifndef DELAY
24 #define DELAY 20 /* seconds to wait for response */
25 #endif
26
27 #ifndef BSD
28 #define vfork fork
29 #endif
30
31 extern char *getpath(), *getenv();
32
33 int onsigio();
34
35 int comm_close(), comm_clear(), comm_paintr(), comm_errout(),
36 comm_getcur(), comm_comout(), comm_comin(), comm_flush();
37
38 struct driver comm_driver = {
39 comm_close, comm_clear, comm_paintr, comm_getcur,
40 comm_comout, comm_comin, comm_flush
41 };
42
43 FILE *devin, *devout;
44
45 int devchild;
46
47
48 struct driver *
49 comm_init(dname, id) /* set up and execute driver */
50 char *dname, *id;
51 {
52 char *devname;
53 int p1[2], p2[2];
54 char pin[16], pout[16];
55 /* find driver program */
56 if ((devname = getpath(dname, DEVPATH, 1)) == NULL) {
57 stderr_v(dname);
58 stderr_v(": not found\n");
59 return(NULL);
60 }
61 /* open communication pipes */
62 if (pipe(p1) == -1 || pipe(p2) == -1)
63 goto syserr;
64 if ((devchild = vfork()) == 0) { /* fork driver process */
65 close(p1[1]);
66 close(p2[0]);
67 sprintf(pin, "%d", p1[0]);
68 sprintf(pout, "%d", p2[1]);
69 execl(devname, dname, pin, pout, id, 0);
70 perror(devname);
71 _exit(127);
72 }
73 if (devchild == -1)
74 goto syserr;
75 close(p1[0]);
76 close(p2[1]);
77 if ((devout = fdopen(p1[1], "w")) == NULL)
78 goto syserr;
79 if ((devin = fdopen(p2[0], "r")) == NULL)
80 goto syserr;
81 /* verify initialization */
82 putw(COM_SENDM, devout);
83 fflush(devout);
84 if (getw(devin) != COM_RECVM)
85 return(NULL);
86 /* get driver parameters */
87 comm_flush();
88 /* set error vectors */
89 cmdvec = comm_comout;
90 if (wrnvec != NULL)
91 wrnvec = comm_comout;
92 return(&comm_driver);
93 syserr:
94 perror(dname);
95 return(NULL);
96 }
97
98
99 static
100 comm_close() /* done with driver */
101 {
102 int pid;
103
104 cmdvec = NULL; /* reset error vectors */
105 if (wrnvec != NULL)
106 wrnvec = stderr_v;
107 fclose(devout);
108 fclose(devin);
109 while ((pid = wait(0)) != -1 && pid != devchild)
110 ;
111 }
112
113
114 static
115 comm_clear(xres, yres) /* clear screen */
116 int xres, yres;
117 {
118 putc(COM_CLEAR, devout);
119 putw(xres, devout);
120 putw(yres, devout);
121 fflush(devout);
122 }
123
124
125 static
126 comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
127 COLOR col;
128 int xmin, ymin, xmax, ymax;
129 {
130 putc(COM_PAINTR, devout);
131 fwrite((char *)col, sizeof(COLOR), 1, devout);
132 putw(xmin, devout);
133 putw(ymin, devout);
134 putw(xmax, devout);
135 putw(ymax, devout);
136 }
137
138
139 static
140 comm_flush() /* flush output to driver */
141 {
142 putc(COM_FLUSH, devout);
143 fflush(devout);
144 if (getc(devin) != COM_FLUSH)
145 reply_error("flush");
146 fread((char *)&comm_driver.pixaspect,
147 sizeof(comm_driver.pixaspect), 1, devin);
148 comm_driver.xsiz = getw(devin);
149 comm_driver.ysiz = getw(devin);
150 comm_driver.inpready = getw(devin);
151 }
152
153
154 static int
155 comm_getcur(xp, yp) /* get and return cursor position */
156 int *xp, *yp;
157 {
158 int c;
159
160 putc(COM_GETCUR, devout);
161 fflush(devout);
162 if (getc(devin) != COM_GETCUR)
163 reply_error("getcur");
164 c = getc(devin);
165 *xp = getw(devin);
166 *yp = getw(devin);
167 return(c);
168 }
169
170
171 static
172 comm_comout(str) /* print string to command line */
173 char *str;
174 {
175 putc(COM_COMOUT, devout);
176 myputs(str, devout);
177 }
178
179
180 static
181 comm_comin(buf, prompt) /* read string from command line */
182 char *buf;
183 char *prompt;
184 {
185 putc(COM_COMIN, devout);
186 if (prompt == NULL)
187 putc(0, devout);
188 else {
189 putc(1, devout);
190 myputs(prompt, devout);
191 }
192 fflush(devout);
193 if (getc(devin) != COM_COMIN)
194 reply_error("comin");
195 mygets(buf, devin);
196 comm_driver.inpready = getw(devin);
197 }
198
199
200 static
201 comm_errout(str) /* display an error message */
202 char *str;
203 {
204 comm_comout(str);
205 stderr_v(str); /* send to standard error also */
206 }
207
208
209 static
210 mygets(s, fp) /* get string from file (with nul) */
211 register char *s;
212 register FILE *fp;
213 {
214 register int c;
215
216 while ((c = getc(fp)) != EOF)
217 if ((*s++ = c) == '\0')
218 return;
219 *s = '\0';
220 }
221
222
223 static
224 myputs(s, fp) /* put string to file (with nul) */
225 register char *s;
226 register FILE *fp;
227 {
228 do
229 putc(*s, fp);
230 while (*s++);
231 }
232
233
234 static
235 reply_error(routine) /* what should we do here? */
236 char *routine;
237 {
238 stderr_v(routine);
239 stderr_v(": driver reply error\n");
240 quit(1);
241 }
