--- ray/src/rt/devcomm.c 1990/03/12 11:08:44 1.16 +++ ray/src/rt/devcomm.c 2003/07/02 01:15:20 2.8 @@ -1,61 +1,84 @@ -/* Copyright (c) 1988 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: devcomm.c,v 2.8 2003/07/02 01:15:20 greg Exp $"; #endif - /* * devcomm.c - communication routines for separate drivers. * - * 10/5/88 + * External symbols declared in driver.h */ +#include "copyright.h" + #include "standard.h" #include "color.h" #include "driver.h" +#include "vfork.h" + #ifndef DEVPATH #define DEVPATH getenv("PATH") /* device search path */ #endif -#ifndef DELAY -#define DELAY 20 /* seconds to wait for response */ -#endif +static int comm_getcur(); +static void comm_close(), comm_clear(), comm_paintr(), + comm_comin(), comm_comout(), comm_flush(); -#ifndef BSD -#define vfork fork -#endif - -extern char *getpath(), *getenv(); - -static int comm_close(), comm_clear(), comm_paintr(), comm_errout(), - comm_getcur(), comm_comout(), comm_comin(), comm_flush(); - struct driver comm_driver = { comm_close, comm_clear, comm_paintr, comm_getcur, comm_comout, comm_comin, comm_flush }; +static void mygets(), myputs(), reply_error(), getstate(); + FILE *devin, *devout; int devchild; +static struct driver * +final_connect() /* verify and initialize connection */ +{ + putw(COM_SENDM, devout); + fflush(devout); + if (getw(devin) != COM_RECVM) + return(NULL); + /* get driver parameters */ + getstate(); + /* set error vectors */ + erract[COMMAND].pf = comm_comout; + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = comm_comout; + return(&comm_driver); +} + + struct driver * +slave_init(dname, id) /* run rview in slave mode */ +char *dname, *id; +{ + devchild = -1; /* we're the slave here */ + devout = stdout; /* use standard input */ + devin = stdin; /* and standard output */ + return(final_connect()); /* verify initialization */ +} + + +struct driver * comm_init(dname, id) /* set up and execute driver */ char *dname, *id; { - char *devname; + char *dvcname; int p1[2], p2[2]; char pin[16], pout[16]; /* find driver program */ - if ((devname = getpath(dname, DEVPATH, 1)) == NULL) { - stderr_v(dname); - stderr_v(": not found\n"); + if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) { + eputs(dname); + eputs(": not found\n"); return(NULL); } +#ifdef RHAS_FORK_EXEC /* open communication pipes */ if (pipe(p1) == -1 || pipe(p2) == -1) goto syserr; @@ -64,8 +87,8 @@ char *dname, *id; close(p2[0]); sprintf(pin, "%d", p1[0]); sprintf(pout, "%d", p2[1]); - execl(devname, dname, pin, pout, id, 0); - perror(devname); + execl(dvcname, dname, pin, pout, id, 0); + perror(dvcname); _exit(127); } if (devchild == -1) @@ -76,40 +99,39 @@ char *dname, *id; goto syserr; if ((devin = fdopen(p2[0], "r")) == NULL) goto syserr; - /* verify initialization */ - putw(COM_SENDM, devout); - fflush(devout); - if (getw(devin) != COM_RECVM) - return(NULL); - /* get driver parameters */ - comm_flush(); - /* set error vectors */ - cmdvec = comm_comout; - if (wrnvec != NULL) - wrnvec = comm_comout; - return(&comm_driver); + return(final_connect()); /* verify initialization */ syserr: perror(dname); return(NULL); + +#else /* ! RHAS_FORK_EXEC */ + + eputs(dname); + eputs(": no fork/exec\n"); + return(NULL); + +#endif /* ! RHAS_FORK_EXEC */ } -static +static void comm_close() /* done with driver */ { int pid; - cmdvec = NULL; /* reset error vectors */ - if (wrnvec != NULL) - wrnvec = stderr_v; + erract[COMMAND].pf = NULL; /* reset error vectors */ + if (erract[WARNING].pf != NULL) + erract[WARNING].pf = wputs; fclose(devout); fclose(devin); + if (devchild < 0) + return; while ((pid = wait(0)) != -1 && pid != devchild) ; } -static +static void comm_clear(xres, yres) /* clear screen */ int xres, yres; { @@ -120,7 +142,7 @@ int xres, yres; } -static +static void comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */ COLOR col; int xmin, ymin, xmax, ymax; @@ -134,18 +156,14 @@ int xmin, ymin, xmax, ymax; } -static +static void comm_flush() /* flush output to driver */ { putc(COM_FLUSH, devout); fflush(devout); if (getc(devin) != COM_FLUSH) reply_error("flush"); - fread((char *)&comm_driver.pixaspect, - sizeof(comm_driver.pixaspect), 1, devin); - comm_driver.xsiz = getw(devin); - comm_driver.ysiz = getw(devin); - comm_driver.inpready = getw(devin); + getstate(); } @@ -166,16 +184,18 @@ int *xp, *yp; } -static +static void comm_comout(str) /* print string to command line */ char *str; { putc(COM_COMOUT, devout); myputs(str, devout); + if (str[strlen(str)-1] == '\n') + fflush(devout); } -static +static void comm_comin(buf, prompt) /* read string from command line */ char *buf; char *prompt; @@ -191,20 +211,11 @@ char *prompt; if (getc(devin) != COM_COMIN) reply_error("comin"); mygets(buf, devin); - comm_driver.inpready = getw(devin); + getstate(); } -static -comm_errout(str) /* display an error message */ -char *str; -{ - comm_comout(str); - stderr_v(str); /* send to standard error also */ -} - - -static +static void mygets(s, fp) /* get string from file (with nul) */ register char *s; register FILE *fp; @@ -218,7 +229,7 @@ register FILE *fp; } -static +static void myputs(s, fp) /* put string to file (with nul) */ register char *s; register FILE *fp; @@ -229,11 +240,22 @@ register FILE *fp; } -static +static void reply_error(routine) /* what should we do here? */ char *routine; { - stderr_v(routine); - stderr_v(": driver reply error\n"); + eputs(routine); + eputs(": driver reply error\n"); quit(1); +} + + +static void +getstate() /* get driver state variables */ +{ + fread((char *)&comm_driver.pixaspect, + sizeof(comm_driver.pixaspect), 1, devin); + comm_driver.xsiz = getw(devin); + comm_driver.ysiz = getw(devin); + comm_driver.inpready = getw(devin); }
