--- ray/src/rt/devcomm.c 2003/07/03 15:00:19 2.9 +++ ray/src/rt/devcomm.c 2004/09/20 16:26:58 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: devcomm.c,v 2.9 2003/07/03 15:00:19 greg Exp $"; +static const char RCSid[] = "$Id: devcomm.c,v 2.13 2004/09/20 16:26:58 greg Exp $"; #endif /* * devcomm.c - communication routines for separate drivers. @@ -9,38 +9,42 @@ static const char RCSid[] = "$Id: devcomm.c,v 2.9 2003 #include "copyright.h" -#include "platform.h" +#include +#include /* XXX platform specific */ +#include "platform.h" #include "standard.h" - -#include "color.h" - #include "driver.h" -#include "vfork.h" - #ifndef DEVPATH #define DEVPATH getenv("PATH") /* device search path */ #endif -static int comm_getcur(); -static void comm_close(), comm_clear(), comm_paintr(), - comm_comin(), comm_comout(), comm_flush(); +FILE *devin, *devout; +int devchild; +static struct driver * final_connect(void); +static void mygets(char *s, FILE *fp); +static void myputs(char *s, FILE *fp); +static void reply_error(char *routine); +static void getstate(void); + +static dr_closef_t comm_close; +static dr_clearf_t comm_clear; +static dr_paintrf_t comm_paintr; +static dr_getcurf_t comm_getcur; +static dr_comoutf_t comm_comout; +static dr_cominf_t comm_comin; +static dr_flushf_t comm_flush; + struct driver comm_driver = { comm_close, comm_clear, comm_paintr, comm_getcur, comm_comout, comm_comin, comm_flush }; -static void mygets(), myputs(), reply_error(), getstate(); -FILE *devin, *devout; - -int devchild; - - static struct driver * -final_connect() /* verify and initialize connection */ +final_connect(void) /* verify and initialize connection */ { putw(COM_SENDM, devout); fflush(devout); @@ -56,9 +60,11 @@ final_connect() /* verify and initialize connection } -struct driver * -slave_init(dname, id) /* run rview in slave mode */ -char *dname, *id; +extern struct driver * +slave_init( /* run rview in slave mode */ + char *dname, + char *id +) { devchild = -1; /* we're the slave here */ devout = stdout; /* use standard input */ @@ -67,9 +73,11 @@ char *dname, *id; } -struct driver * -comm_init(dname, id) /* set up and execute driver */ -char *dname, *id; +extern struct driver * +comm_init( /* set up and execute driver */ + char *dname, + char *id +) { char *dvcname; int p1[2], p2[2]; @@ -84,7 +92,7 @@ char *dname, *id; /* open communication pipes */ if (pipe(p1) == -1 || pipe(p2) == -1) goto syserr; - if ((devchild = vfork()) == 0) { /* fork driver process */ + if ((devchild = fork()) == 0) { /* fork driver process */ close(p1[1]); close(p2[0]); sprintf(pin, "%d", p1[0]); @@ -97,6 +105,12 @@ char *dname, *id; goto syserr; close(p1[0]); close(p2[1]); + /* + * Close write stream on exec to avoid multiprocessing deadlock. + * No use in read stream without it, so set flag there as well. + */ + fcntl(p1[1], F_SETFD, FD_CLOEXEC); + fcntl(p2[0], F_SETFD, FD_CLOEXEC); if ((devout = fdopen(p1[1], "w")) == NULL) goto syserr; if ((devin = fdopen(p2[0], "r")) == NULL) @@ -117,7 +131,7 @@ syserr: static void -comm_close() /* done with driver */ +comm_close(void) /* done with driver */ { int pid; @@ -134,8 +148,10 @@ comm_close() /* done with driver */ static void -comm_clear(xres, yres) /* clear screen */ -int xres, yres; +comm_clear( /* clear screen */ + int xres, + int yres +) { putc(COM_CLEAR, devout); putw(xres, devout); @@ -145,9 +161,13 @@ int xres, yres; static void -comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */ -COLOR col; -int xmin, ymin, xmax, ymax; +comm_paintr( /* paint a rectangle */ + COLOR col, + int xmin, + int ymin, + int xmax, + int ymax +) { putc(COM_PAINTR, devout); fwrite((char *)col, sizeof(COLOR), 1, devout); @@ -159,7 +179,7 @@ int xmin, ymin, xmax, ymax; static void -comm_flush() /* flush output to driver */ +comm_flush(void) /* flush output to driver */ { putc(COM_FLUSH, devout); fflush(devout); @@ -170,8 +190,10 @@ comm_flush() /* flush output to driver */ static int -comm_getcur(xp, yp) /* get and return cursor position */ -int *xp, *yp; +comm_getcur( /* get and return cursor position */ + int *xp, + int *yp +) { int c; @@ -187,8 +209,9 @@ int *xp, *yp; static void -comm_comout(str) /* print string to command line */ -char *str; +comm_comout( /* print string to command line */ + char *str +) { putc(COM_COMOUT, devout); myputs(str, devout); @@ -198,9 +221,10 @@ char *str; static void -comm_comin(buf, prompt) /* read string from command line */ -char *buf; -char *prompt; +comm_comin( /* read string from command line */ + char *buf, + char *prompt +) { putc(COM_COMIN, devout); if (prompt == NULL) @@ -218,9 +242,10 @@ char *prompt; static void -mygets(s, fp) /* get string from file (with nul) */ -register char *s; -register FILE *fp; +mygets( /* get string from file (with nul) */ + register char *s, + register FILE *fp +) { register int c; @@ -232,9 +257,10 @@ register FILE *fp; static void -myputs(s, fp) /* put string to file (with nul) */ -register char *s; -register FILE *fp; +myputs( /* put string to file (with nul) */ + register char *s, + register FILE *fp +) { do putc(*s, fp); @@ -243,8 +269,9 @@ register FILE *fp; static void -reply_error(routine) /* what should we do here? */ -char *routine; +reply_error( /* what should we do here? */ + char *routine +) { eputs(routine); eputs(": driver reply error\n"); @@ -253,7 +280,7 @@ char *routine; static void -getstate() /* get driver state variables */ +getstate(void) /* get driver state variables */ { fread((char *)&comm_driver.pixaspect, sizeof(comm_driver.pixaspect), 1, devin);
