root/radiance/ray/src/rt/devcomm.c
Mon Sep 20 16:26:58 2004 UTC (20 years, 8 months ago) by greg
Changes since 2.12: +7 -1 lines
Diff to previous 2.12
Changes since 2.11: +67 -42 lines
Tue Nov 11 16:24:06 2003 UTC (21 years, 6 months ago) by greg
Changes since 2.10: +2 -4 lines
Mon Nov 10 16:52:25 2003 UTC (21 years, 6 months ago) by greg
Changes since 2.9: +3 -5 lines
Thu Jul 3 15:00:19 2003 UTC (21 years, 10 months ago) by greg
Wed Jul 2 01:15:20 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.7: +10 -1 lines
Fixed broken use of RHAS_FORK_EXEC
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.5: +77 -22 lines
Tue Nov 11 19:55:03 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.4: +10 -10 lines
Thu Nov 18 09:42:58 1993 UTC (31 years, 6 months ago) by greg
minor compiler warning fixes
Mon Apr 5 15:16:47 1993 UTC (32 years, 1 month ago) by greg
Changes since 2.2: +32 -26 lines
added slave_init() for slave mode of rview
Thu Mar 19 09:34:02 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.1: +2 -4 lines
added vfork.h include
Tue Nov 12 17:09:13 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.19
Thu Oct 18 13:33:09 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.18: +1 -3 lines
Diff to previous 1.18
changed 1 to X_OK in call to getpath()
Thu May 3 13:17:41 1990 UTC (35 years ago) by greg
Changes since 1.17: +2 -0 lines
Diff to previous 1.17
Added automatic flushing to dev_comout()
Wed Mar 21 09:46:55 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.16: +14 -7 lines
Diff to previous 1.16
Changed state mainenance calls
Mon Mar 12 11:08:44 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.15: +1 -3 lines
Diff to previous 1.15
fixed function predeclarations for fussy compilers
Tue Mar 6 17:44:37 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.14: +11 -5 lines
Diff to previous 1.14
Wed Feb 28 16:03:57 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.13: +0 -1 lines
Diff to previous 1.13
removed flush in comout (wise?)
Thu Feb 22 12:45:27 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.12: +4 -14 lines
Diff to previous 1.12
Thu Feb 22 11:46:13 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.11: +11 -15 lines
Diff to previous 1.11
Tue Jan 30 11:37:36 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.10: +8 -1 lines
Diff to previous 1.10
Fri Jan 19 00:00:08 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.9: +5 -4 lines
Diff to previous 1.9
Mon Jan 8 15:07:31 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.8
bug in passing of pixaspect
Mon Jan 8 13:37:54 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.7: +10 -10 lines
Diff to previous 1.7
Wed Nov 1 17:33:03 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.6: +25 -20 lines
Diff to previous 1.6
Thu Jul 27 22:25:12 1989 UTC (35 years, 9 months ago) by greg
Diff to previous 1.5
Changed getpath to check permissions
Wed Jun 7 13:22:54 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.4
Reduced WFLUSH, since change in direct calculation reduces rays
Fri Jun 2 17:21:24 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.3
Changed WFLUSH value and added output to flush so rview would
die with X-windows when the server was killed and rview iconified
Fri May 26 10:27:16 1989 UTC (36 years ago) by greg
Diff to previous 1.2
reinstated flush in command line output
Thu May 25 19:33:21 1989 UTC (36 years ago) by greg
Changes since 1.1: +2 -5 lines
eliminated duplication of standard error output and assoc. problems
Thu Feb 2 10:41:19 1989 UTC (36 years, 3 months ago) by greg
