root/radiance/ray/src/rt/devcomm.c
Revision: 1.13
Committed: Thu Feb 22 12:45:27 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.12: +4 -14 lines
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * devcomm.c - communication routines for separate drivers.
9 *
10 * 10/5/88
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "driver.h"
18
19 #ifndef DEVPATH
20 #define DEVPATH getenv("PATH") /* device search path */
21 #endif
22
23 #ifndef BSD
24 #define vfork fork
25 #endif
26
27 extern char *getpath(), *getenv();
28
29 int onsigio();
30
31 int comm_close(), comm_clear(), comm_paintr(), comm_errout(),
32 comm_getcur(), comm_comout(), comm_comin(), comm_flush();
33
34 struct driver comm_driver = {
35 comm_close, comm_clear, comm_paintr, comm_getcur,
36 comm_comout, comm_comin, comm_flush
37 };
38
39 FILE *devin, *devout;
40
41 int devchild;
42
43
44 struct driver *
45 comm_init(dname, id) /* set up and execute driver */
46 char *dname, *id;
47 {
48 char *devname;
49 int p1[2], p2[2];
50 char pin[16], pout[16];
51 /* find driver program */
52 if ((devname = getpath(dname, DEVPATH, 1)) == NULL) {
53 stderr_v(dname);
54 stderr_v(": not found\n");
55 return(NULL);
56 }
57 /* open communication pipes */
58 if (pipe(p1) == -1 || pipe(p2) == -1)
59 goto syserr;
60 if ((devchild = vfork()) == 0) { /* fork driver process */
61 close(p1[1]);
62 close(p2[0]);
63 sprintf(pin, "%d", p1[0]);
64 sprintf(pout, "%d", p2[1]);
65 execl(devname, dname, pin, pout, id, 0);
66 perror(devname);
67 _exit(127);
68 }
69 if (devchild == -1)
70 goto syserr;
71 close(p1[0]);
72 close(p2[1]);
73 if ((devout = fdopen(p1[1], "w")) == NULL)
74 goto syserr;
75 if ((devin = fdopen(p2[0], "r")) == NULL)
76 goto syserr;
77 /* verify & get resolution */
78 putw(COM_SENDM, devout);
79 fflush(devout);
80 if (getw(devin) != COM_RECVM)
81 return(NULL);
82 fread((char *)&comm_driver.pixaspect,
83 sizeof(comm_driver.pixaspect), 1, devin);
84 comm_driver.xsiz = getw(devin);
85 comm_driver.ysiz = getw(devin);
86 /* set error vectors */
87 cmdvec = comm_comout;
88 if (wrnvec != NULL)
89 wrnvec = comm_comout;
90 return(&comm_driver);
91 syserr:
92 perror(dname);
93 return(NULL);
94 }
95
96
97 static
98 comm_close() /* done with driver */
99 {
100 int pid;
101
102 cmdvec = NULL; /* reset error vectors */
103 if (wrnvec != NULL)
104 wrnvec = stderr_v;
105 fclose(devout);
106 fclose(devin);
107 while ((pid = wait(0)) != -1 && pid != devchild)
108 ;
109 }
110
111
112 static
113 comm_clear(xres, yres) /* clear screen */
114 int xres, yres;
115 {
116 putc(COM_CLEAR, devout);
117 putw(xres, devout);
118 putw(yres, devout);
119 fflush(devout);
120 }
121
122
123 static
124 comm_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
125 COLOR col;
126 int xmin, ymin, xmax, ymax;
127 {
128 putc(COM_PAINTR, devout);
129 fwrite((char *)col, sizeof(COLOR), 1, devout);
130 putw(xmin, devout);
131 putw(ymin, devout);
132 putw(xmax, devout);
133 putw(ymax, devout);
134 }
135
136
137 static
138 comm_flush() /* flush output to driver */
139 {
140 putc(COM_FLUSH, devout);
141 fflush(devout);
142 if (getc(devin) != COM_FLUSH)
143 reply_error("flush");
144 comm_driver.inpready = getw(devin);
145 }
146
147
148 static int
149 comm_getcur(xp, yp) /* get and return cursor position */
150 int *xp, *yp;
151 {
152 int c;
153
154 putc(COM_GETCUR, devout);
155 fflush(devout);
156 if (getc(devin) != COM_GETCUR)
157 reply_error("getcur");
158 c = getc(devin);
159 *xp = getw(devin);
160 *yp = getw(devin);
161 return(c);
162 }
163
164
165 static
166 comm_comout(str) /* print string to command line */
167 char *str;
168 {
169 putc(COM_COMOUT, devout);
170 myputs(str, devout);
171 fflush(devout);
172 }
173
174
175 static
176 comm_comin(buf, prompt) /* read string from command line */
177 char *buf;
178 char *prompt;
179 {
180 putc(COM_COMIN, devout);
181 if (prompt == NULL)
182 putc(0, devout);
183 else {
184 putc(1, devout);
185 myputs(prompt, devout);
186 }
187 fflush(devout);
188 if (getc(devin) != COM_COMIN)
189 reply_error("comin");
190 mygets(buf, devin);
191 comm_driver.inpready = getw(devin);
192 }
193
194
195 static
196 comm_errout(str) /* display an error message */
197 char *str;
198 {
199 comm_comout(str);
200 stderr_v(str); /* send to standard error also */
201 }
202
203
204 static
205 mygets(s, fp) /* get string from file (with nul) */
206 register char *s;
207 register FILE *fp;
208 {
209 register int c;
210
211 while ((c = getc(fp)) != EOF)
212 if ((*s++ = c) == '\0')
213 return;
214 *s = '\0';
215 }
216
217
218 static
219 myputs(s, fp) /* put string to file (with nul) */
220 register char *s;
221 register FILE *fp;
222 {
223 do
224 putc(*s, fp);
225 while (*s++);
226 }
227
228
229 static
230 reply_error(routine) /* what should we do here? */
231 char *routine;
232 {
233 stderr_v(routine);
234 stderr_v(": driver reply error\n");
235 quit(1);
236 }
