Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor compiler warning fixes
added slave_init() for slave mode of rview
added vfork.h include
changed 1 to X_OK in call to getpath()
Added automatic flushing to dev_comout()
Changed state mainenance calls
fixed function predeclarations for fussy compilers
removed flush in comout (wise?)
bug in passing of pixaspect
Changed getpath to check permissions
Reduced WFLUSH, since change in direct calculation reduces rays
Changed WFLUSH value and added output to flush so rview would die with X-windows when the server was killed and rview iconified
reinstated flush in command line output
eliminated duplication of standard error output and assoc. problems
