root/radiance/ray/src/rt/data.h
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.6: +1 -4 lines
Sat Jun 7 00:54:58 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.5: +12 -9 lines
Removed NOPROTO sections.
Changes since 2.4: +2 -57 lines
Changes since 2.3: +73 -7 lines
Thu Feb 15 18:46:56 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.2: +10 -8 lines
made pictures use RGBE storage r.t. float
reduced MAXDDIM to 5
Fri Jun 30 16:07:42 1995 UTC (28 years, 10 months ago) by greg
Changes since 2.1: +1 -2 lines
Diff to previous 2.1
added comments to data files using new fgetval() function
Tue Nov 12 17:09:06 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3
Thu May 23 08:14:55 1991 UTC (33 years ago) by greg
Diff to previous 1.2
changed MAXDIM to MAXDDIM to avoid conflict
Tue Apr 3 17:24:33 1990 UTC (34 years, 1 month ago) by greg
Diff to previous 1.1
Added capability for unevenly spaced points
Thu Feb 2 10:41:13 1989 UTC (35 years, 3 months ago) by greg
