1 |
/* Copyright (c) 1993 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* data.c - routines dealing with interpolated data. |
9 |
10 |
* 6/4/86 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "color.h" |
16 |
17 |
#include "resolu.h" |
18 |
19 |
#include "data.h" |
20 |
21 |
/* picture memory usage before warning */ |
22 |
#ifndef PSIZWARN |
23 |
#ifdef BIGMEM |
24 |
#define PSIZWARN 3000000 |
25 |
#else |
26 |
#define PSIZWARN 1000000 |
27 |
#endif |
28 |
#endif |
29 |
30 |
#ifndef TABSIZ |
31 |
#define TABSIZ 97 /* table size (prime) */ |
32 |
#endif |
33 |
34 |
#define hash(s) (shash(s)%TABSIZ) |
35 |
36 |
37 |
extern char *fgetword(); |
38 |
39 |
extern char *getlibpath(); /* library search path */ |
40 |
41 |
static DATARRAY *dtab[TABSIZ]; /* data array list */ |
42 |
43 |
static DATARRAY *ptab[TABSIZ]; /* picture list */ |
44 |
45 |
46 |
DATARRAY * |
47 |
getdata(dname) /* get data array dname */ |
48 |
char *dname; |
49 |
50 |
char word[64]; |
51 |
char *dfname; |
52 |
FILE *fp; |
53 |
int asize; |
54 |
register int i, j; |
55 |
register DATARRAY *dp; |
56 |
/* look for array in list */ |
57 |
for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next) |
58 |
if (!strcmp(dname, dp->name)) |
59 |
return(dp); /* found! */ |
60 |
61 |
62 |
* If we haven't loaded the data already, we will look |
63 |
* for it in the directories specified by the library path. |
64 |
65 |
* The file has the following format: |
66 |
67 |
* N |
68 |
* beg0 end0 n0 |
69 |
* beg1 end1 n1 |
70 |
71 |
* begN endN nN |
72 |
* data, later dimensions changing faster |
73 |
74 |
75 |
* For irregularly spaced points, the following can be |
76 |
* substituted for begi endi ni: |
77 |
78 |
* 0 0 ni p0i p1i .. pni |
79 |
80 |
81 |
if ((dfname = getpath(dname, getlibpath(), R_OK)) == NULL) { |
82 |
sprintf(errmsg, "cannot find data file \"%s\"", dname); |
83 |
error(USER, errmsg); |
84 |
85 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL) |
86 |
goto memerr; |
87 |
88 |
dp->name = savestr(dname); |
89 |
90 |
if ((fp = fopen(dfname, "r")) == NULL) { |
91 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname); |
92 |
error(SYSTEM, errmsg); |
93 |
94 |
/* get dimensions */ |
95 |
if (fgetword(word, sizeof(word), fp) == NULL || !isint(word)) |
96 |
goto scanerr; |
97 |
dp->nd = atoi(word); |
98 |
if (dp->nd <= 0 || dp->nd > MAXDDIM) { |
99 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname); |
100 |
101 |
102 |
asize = 1; |
103 |
for (i = 0; i < dp->nd; i++) { |
104 |
if (fgetword(word, sizeof(word), fp) == NULL || !isflt(word)) |
105 |
goto scanerr; |
106 |
dp->dim[i].org = atof(word); |
107 |
108 |
goto scanerr; |
109 |
dp->dim[i].siz = atof(word); |
110 |
111 |
goto scanerr; |
112 |
dp->dim[i].ne = atoi(word); |
113 |
if (dp->dim[i].ne < 2) |
114 |
goto scanerr; |
115 |
asize *= dp->dim[i].ne; |
116 |
if ((dp->dim[i].siz -= dp->dim[i].org) == 0) { |
117 |
dp->dim[i].p = (double *)malloc(dp->dim[i].ne*sizeof(double)); |
118 |
if (dp->dim[i].p == NULL) |
119 |
goto memerr; |
120 |
for (j = 0; j < dp->dim[i].ne; j++) { |
121 |
if (fgetword(word, sizeof(word), fp) == NULL || |
122 |
!isflt(word)) |
123 |
goto scanerr; |
124 |
dp->dim[i].p[j] = atof(word); |
125 |
126 |
for (j = 1; j < dp->dim[i].ne-1; j++) |
127 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) != |
128 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1])) |
129 |
goto scanerr; |
130 |
dp->dim[i].org = dp->dim[i].p[0]; |
131 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1] |
132 |
- dp->dim[i].p[0]; |
133 |
} else |
134 |
dp->dim[i].p = NULL; |
135 |
136 |
if ((dp->arr = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL) |
137 |
goto memerr; |
138 |
139 |
for (i = 0; i < asize; i++) { |
140 |
141 |
goto scanerr; |
142 |
dp->arr[i] = atof(word); |
143 |
144 |
fclose(fp); |
145 |
i = hash(dname); |
146 |
dp->next = dtab[i]; |
147 |
return(dtab[i] = dp); |
148 |
149 |
memerr: |
150 |
error(SYSTEM, "out of memory in getdata"); |
151 |
scanerr: |
152 |
sprintf(errmsg, "%s in data file \"%s\"", |
153 |
feof(fp) ? "unexpected EOF" : "bad format", dfname); |
154 |
155 |
156 |
157 |
158 |
static |
159 |
headaspect(s, iap) /* check string for aspect ratio */ |
160 |
char *s; |
161 |
double *iap; |
162 |
163 |
if (isaspect(s)) |
164 |
*iap *= aspectval(s); |
165 |
166 |
167 |
168 |
DATARRAY * |
169 |
getpict(pname) /* get picture pname */ |
170 |
char *pname; |
171 |
172 |
double inpaspect; |
173 |
char *pfname; |
174 |
FILE *fp; |
175 |
COLOR *scanin; |
176 |
int sl, ns; |
177 |
RESOLU inpres; |
178 |
FLOAT loc[2]; |
179 |
int y; |
180 |
register int x, i; |
181 |
register DATARRAY *pp; |
182 |
183 |
for (pp = ptab[hash(pname)]; pp != NULL; pp = pp->next) |
184 |
if (!strcmp(pname, pp->name)) |
185 |
return(pp); /* found! */ |
186 |
187 |
if ((pfname = getpath(pname, getlibpath(), R_OK)) == NULL) { |
188 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname); |
189 |
190 |
191 |
if ((pp = (DATARRAY *)calloc(3, sizeof(DATARRAY))) == NULL) |
192 |
goto memerr; |
193 |
194 |
pp[0].name = |
195 |
pp[1].name = |
196 |
pp[2].name = savestr(pname); |
197 |
198 |
if ((fp = fopen(pfname, "r")) == NULL) { |
199 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname); |
200 |
201 |
202 |
#ifdef MSDOS |
203 |
setmode(fileno(fp), O_BINARY); |
204 |
#endif |
205 |
206 |
inpaspect = 1.0; |
207 |
getheader(fp, headaspect, &inpaspect); |
208 |
if (!fgetsresolu(&inpres, fp)) |
209 |
goto readerr; |
210 |
#if PSIZWARN |
211 |
/* check memory usage */ |
212 |
i = 3*sizeof(DATATYPE)*inpres.xr*inpres.yr; |
213 |
if (i > PSIZWARN) { |
214 |
sprintf(errmsg, "picture file \"%s\" using %d bytes of memory", |
215 |
pname, i); |
216 |
error(WARNING, errmsg); |
217 |
218 |
#endif |
219 |
for (i = 0; i < 3; i++) { |
220 |
pp[i].nd = 2; |
221 |
pp[i].dim[0].ne = inpres.yr; |
222 |
pp[i].dim[1].ne = inpres.xr; |
223 |
pp[i].dim[0].org = |
224 |
pp[i].dim[1].org = 0.0; |
225 |
if (inpres.xr <= inpres.yr*inpaspect) { |
226 |
pp[i].dim[0].siz = inpaspect * |
227 |
(double)inpres.yr/inpres.xr; |
228 |
pp[i].dim[1].siz = 1.0; |
229 |
} else { |
230 |
pp[i].dim[0].siz = 1.0; |
231 |
pp[i].dim[1].siz = (double)inpres.xr/inpres.yr / |
232 |
inpaspect; |
233 |
234 |
pp[i].dim[0].p = pp[i].dim[1].p = NULL; |
235 |
pp[i].arr = (DATATYPE *) |
236 |
malloc(inpres.xr*inpres.yr*sizeof(DATATYPE)); |
237 |
if (pp[i].arr == NULL) |
238 |
goto memerr; |
239 |
240 |
/* load picture */ |
241 |
sl = scanlen(&inpres); |
242 |
ns = numscans(&inpres); |
243 |
if ((scanin = (COLOR *)malloc(sl*sizeof(COLOR))) == NULL) |
244 |
goto memerr; |
245 |
for (y = 0; y < ns; y++) { |
246 |
if (freadscan(scanin, sl, fp) < 0) |
247 |
goto readerr; |
248 |
for (x = 0; x < sl; x++) { |
249 |
pix2loc(loc, &inpres, x, y); |
250 |
i = (int)(loc[1]*inpres.yr)*inpres.xr + |
251 |
(int)(loc[0]*inpres.xr); |
252 |
pp[0].arr[i] = colval(scanin[x],RED); |
253 |
pp[1].arr[i] = colval(scanin[x],GRN); |
254 |
pp[2].arr[i] = colval(scanin[x],BLU); |
255 |
256 |
257 |
free((char *)scanin); |
258 |
fclose(fp); |
259 |
i = hash(pname); |
260 |
pp[0].next = |
261 |
pp[1].next = |
262 |
pp[2].next = ptab[i]; |
263 |
return(ptab[i] = pp); |
264 |
265 |
memerr: |
266 |
error(SYSTEM, "out of memory in getpict"); |
267 |
readerr: |
268 |
sprintf(errmsg, "bad picture file \"%s\"", pfname); |
269 |
270 |
271 |
272 |
273 |
freedata(dname) /* free memory associated with dname */ |
274 |
char *dname; |
275 |
276 |
DATARRAY head; |
277 |
int hval, nents; |
278 |
register DATARRAY *dp, *dpl; |
279 |
register int i; |
280 |
281 |
if (dname == NULL) { /* free all if NULL */ |
282 |
hval = 0; nents = TABSIZ; |
283 |
} else { |
284 |
hval = hash(dname); nents = 1; |
285 |
286 |
while (nents--) { |
287 |
head.next = dtab[hval]; |
288 |
dpl = &head; |
289 |
while ((dp = dpl->next) != NULL) |
290 |
if (dname == NULL || !strcmp(dname, dp->name)) { |
291 |
dpl->next = dp->next; |
292 |
free((char *)dp->arr); |
293 |
for (i = 0; i < dp->nd; i++) |
294 |
if (dp->dim[i].p != NULL) |
295 |
free((char *)dp->dim[i].p); |
296 |
freestr(dp->name); |
297 |
free((char *)dp); |
298 |
} else |
299 |
dpl = dp; |
300 |
dtab[hval++] = head.next; |
301 |
302 |
303 |
304 |
305 |
freepict(pname) /* free memory associated with pname */ |
306 |
char *pname; |
307 |
308 |
DATARRAY head; |
309 |
int hval, nents; |
310 |
register DATARRAY *pp, *ppl; |
311 |
312 |
if (pname == NULL) { /* free all if NULL */ |
313 |
314 |
} else { |
315 |
hval = hash(pname); nents = 1; |
316 |
317 |
while (nents--) { |
318 |
head.next = ptab[hval]; |
319 |
ppl = &head; |
320 |
while ((pp = ppl->next) != NULL) |
321 |
if (pname == NULL || !strcmp(pname, pp->name)) { |
322 |
ppl->next = pp->next; |
323 |
free((char *)pp[0].arr); |
324 |
free((char *)pp[1].arr); |
325 |
free((char *)pp[2].arr); |
326 |
freestr(pp[0].name); |
327 |
free((char *)pp); |
328 |
} else |
329 |
ppl = pp; |
330 |
ptab[hval++] = head.next; |
331 |
332 |
333 |
334 |
335 |
double |
336 |
datavalue(dp, pt) /* interpolate data value at a point */ |
337 |
338 |
double *pt; |
339 |
340 |
DATARRAY sd; |
341 |
int asize; |
342 |
int lower, upper; |
343 |
register int i; |
344 |
double x, y, y0, y1; |
345 |
/* set up dimensions for recursion */ |
346 |
sd.nd = dp->nd - 1; |
347 |
asize = 1; |
348 |
for (i = 0; i < sd.nd; i++) { |
349 |
sd.dim[i].org = dp->dim[i+1].org; |
350 |
sd.dim[i].siz = dp->dim[i+1].siz; |
351 |
sd.dim[i].p = dp->dim[i+1].p; |
352 |
asize *= sd.dim[i].ne = dp->dim[i+1].ne; |
353 |
354 |
/* get independent variable */ |
355 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */ |
356 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; |
357 |
x = x * (dp->dim[0].ne - 1); |
358 |
i = x; |
359 |
if (i < 0) |
360 |
i = 0; |
361 |
else if (i > dp->dim[0].ne - 2) |
362 |
i = dp->dim[0].ne - 2; |
363 |
} else { /* unevenly spaced points */ |
364 |
if (dp->dim[0].siz > 0.0) { |
365 |
lower = 0; |
366 |
upper = dp->dim[0].ne; |
367 |
} else { |
368 |
lower = dp->dim[0].ne; |
369 |
upper = 0; |
370 |
371 |
do { |
372 |
i = (lower + upper) >> 1; |
373 |
if (pt[0] >= dp->dim[0].p[i]) |
374 |
lower = i; |
375 |
else |
376 |
upper = i; |
377 |
} while (i != (lower + upper) >> 1); |
378 |
379 |
380 |
x = i + (pt[0] - dp->dim[0].p[i]) / |
381 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]); |
382 |
383 |
/* get dependent variable */ |
384 |
if (dp->nd == 1) { |
385 |
y0 = dp->arr[i]; |
386 |
y1 = dp->arr[i+1]; |
387 |
} else { |
388 |
sd.arr = &dp->arr[i*asize]; |
389 |
y0 = datavalue(&sd, pt+1); |
390 |
sd.arr = &dp->arr[(i+1)*asize]; |
391 |
y1 = datavalue(&sd, pt+1); |
392 |
393 |
394 |
* Extrapolate as far as one division, then |
395 |
* taper off harmonically to zero. |
396 |
397 |
if (x > i+2) |
398 |
y = (2*y1-y0)/(x-i-1); |
399 |
else if (x < i-1) |
400 |
y = (2*y0-y1)/(i-x); |
401 |
else |
402 |
y = y0*((i+1)-x) + y1*(x-i); |
403 |
404 |
return(y); |
405 |
