1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: data.c,v 2.30 2013/08/07 05:10:09 greg Exp $"; |
3 |
#endif |
4 |
5 |
* data.c - routines dealing with interpolated data. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <time.h> |
11 |
12 |
#include "platform.h" |
13 |
#include "paths.h" |
14 |
#include "standard.h" |
15 |
#include "color.h" |
16 |
#include "resolu.h" |
17 |
#include "view.h" |
18 |
#include "data.h" |
19 |
20 |
/* picture memory usage before warning */ |
21 |
#ifndef PSIZWARN |
22 |
#ifdef SMLMEM |
23 |
#define PSIZWARN 3000000 |
24 |
#else |
25 |
#define PSIZWARN 10000000 |
26 |
#endif |
27 |
#endif |
28 |
29 |
#ifndef TABSIZ |
30 |
#define TABSIZ 97 /* table size (prime) */ |
31 |
#endif |
32 |
33 |
#define hash(s) (shash(s)%TABSIZ) |
34 |
35 |
36 |
static DATARRAY *dtab[TABSIZ]; /* data array list */ |
37 |
38 |
static gethfunc headaspect; |
39 |
40 |
41 |
DATARRAY * |
42 |
getdata( /* get data array dname */ |
43 |
char *dname |
44 |
45 |
46 |
char *dfname; |
47 |
FILE *fp; |
48 |
int asize=0; |
49 |
int i, j; |
50 |
DATARRAY *dp; |
51 |
/* look for array in list */ |
52 |
for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next) |
53 |
if (!strcmp(dname, dp->name)) |
54 |
return(dp); /* found! */ |
55 |
56 |
* If we haven't loaded the data already, we will look |
57 |
* for it in the directories specified by the library path. |
58 |
59 |
* The file has the following format: |
60 |
61 |
* N |
62 |
* beg0 end0 n0 |
63 |
* beg1 end1 n1 |
64 |
65 |
* begN endN nN |
66 |
* data, later dimensions changing faster |
67 |
68 |
69 |
* For irregularly spaced points, the following can be |
70 |
* substituted for begi endi ni: |
71 |
72 |
* 0 0 ni p0i p1i .. pni |
73 |
74 |
75 |
if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) { |
76 |
sprintf(errmsg, "cannot find data file \"%s\"", dname); |
77 |
error(USER, errmsg); |
78 |
79 |
if ((fp = fopen(dfname, "r")) == NULL) { |
80 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname); |
81 |
error(SYSTEM, errmsg); |
82 |
83 |
/* get dimensions */ |
84 |
if (fgetval(fp, 'i', (char *)&asize) <= 0) |
85 |
goto scanerr; |
86 |
if ((asize <= 0) | (asize > MAXDDIM)) { |
87 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname); |
88 |
89 |
90 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL) |
91 |
goto memerr; |
92 |
dp->name = savestr(dname); |
93 |
dp->type = DATATY; |
94 |
dp->nd = asize; |
95 |
asize = 1; |
96 |
for (i = 0; i < dp->nd; i++) { |
97 |
if (fgetval(fp, DATATY, (char *)&dp->dim[i].org) <= 0) |
98 |
goto scanerr; |
99 |
if (fgetval(fp, DATATY, (char *)&dp->dim[i].siz) <= 0) |
100 |
goto scanerr; |
101 |
if (fgetval(fp, 'i', (char *)&dp->dim[i].ne) <= 0) |
102 |
goto scanerr; |
103 |
if (dp->dim[i].ne < 2) |
104 |
goto scanerr; |
105 |
asize *= dp->dim[i].ne; |
106 |
if ((dp->dim[i].siz -= dp->dim[i].org) == 0) { |
107 |
dp->dim[i].p = (DATATYPE *) |
108 |
malloc(dp->dim[i].ne*sizeof(DATATYPE)); |
109 |
if (dp->dim[i].p == NULL) |
110 |
goto memerr; |
111 |
for (j = 0; j < dp->dim[i].ne; j++) |
112 |
if (fgetval(fp, DATATY, |
113 |
(char *)&dp->dim[i].p[j]) <= 0) |
114 |
goto scanerr; |
115 |
for (j = 1; j < dp->dim[i].ne-1; j++) |
116 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) != |
117 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1])) |
118 |
goto scanerr; |
119 |
dp->dim[i].org = dp->dim[i].p[0]; |
120 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1] |
121 |
- dp->dim[i].p[0]; |
122 |
} else |
123 |
dp->dim[i].p = NULL; |
124 |
125 |
if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL) |
126 |
goto memerr; |
127 |
128 |
for (i = 0; i < asize; i++) |
129 |
if (fgetval(fp, DATATY, (char *)&dp->arr.d[i]) <= 0) |
130 |
goto scanerr; |
131 |
fclose(fp); |
132 |
i = hash(dname); |
133 |
dp->next = dtab[i]; |
134 |
return(dtab[i] = dp); |
135 |
136 |
memerr: |
137 |
error(SYSTEM, "out of memory in getdata"); |
138 |
scanerr: |
139 |
sprintf(errmsg, "%s in data file \"%s\"", |
140 |
feof(fp) ? "unexpected EOF" : "bad format", dfname); |
141 |
142 |
return NULL; /* pro forma return */ |
143 |
144 |
145 |
146 |
static int |
147 |
headaspect( /* check string for aspect ratio */ |
148 |
char *s, |
149 |
void *iap |
150 |
151 |
152 |
char fmt[32]; |
153 |
154 |
if (isaspect(s)) |
155 |
*(double*)iap *= aspectval(s); |
156 |
else if (formatval(fmt, s) && !globmatch(PICFMT, fmt)) |
157 |
*(double*)iap = 0.0; |
158 |
return(0); |
159 |
160 |
161 |
162 |
DATARRAY * |
163 |
getpict( /* get picture pname */ |
164 |
char *pname |
165 |
166 |
167 |
double inpaspect; |
168 |
char *pfname; |
169 |
FILE *fp; |
170 |
COLR *scanin; |
171 |
int sl, ns; |
172 |
RESOLU inpres; |
173 |
RREAL loc[2]; |
174 |
int y; |
175 |
int x, i; |
176 |
DATARRAY *pp; |
177 |
178 |
for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next) |
179 |
if (!strcmp(pname, pp->name)) |
180 |
return(pp); /* found! */ |
181 |
182 |
if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) { |
183 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname); |
184 |
185 |
186 |
if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL) |
187 |
goto memerr; |
188 |
189 |
pp[0].name = savestr(pname); |
190 |
191 |
if ((fp = fopen(pfname, "r")) == NULL) { |
192 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname); |
193 |
194 |
195 |
SET_FILE_BINARY(fp); |
196 |
197 |
inpaspect = 1.0; |
198 |
getheader(fp, headaspect, &inpaspect); |
199 |
if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp)) |
200 |
goto readerr; |
201 |
pp[0].nd = 2; |
202 |
pp[0].dim[0].ne = inpres.yr; |
203 |
pp[0].dim[1].ne = inpres.xr; |
204 |
pp[0].dim[0].org = |
205 |
pp[0].dim[1].org = 0.0; |
206 |
if (inpres.xr <= inpres.yr*inpaspect) { |
207 |
pp[0].dim[0].siz = inpaspect * |
208 |
(double)inpres.yr/inpres.xr; |
209 |
pp[0].dim[1].siz = 1.0; |
210 |
} else { |
211 |
pp[0].dim[0].siz = 1.0; |
212 |
pp[0].dim[1].siz = (double)inpres.xr/inpres.yr / |
213 |
inpaspect; |
214 |
215 |
pp[0].dim[0].p = pp[0].dim[1].p = NULL; |
216 |
sl = scanlen(&inpres); /* allocate array */ |
217 |
ns = numscans(&inpres); |
218 |
i = ns*sl*sizeof(COLR); |
219 |
#if PSIZWARN |
220 |
if (i > PSIZWARN) { /* memory warning */ |
221 |
sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory", |
222 |
pname, i*(1.0/(1024*1024))); |
223 |
error(WARNING, errmsg); |
224 |
225 |
#endif |
226 |
if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL) |
227 |
goto memerr; |
228 |
/* load picture */ |
229 |
if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL) |
230 |
goto memerr; |
231 |
for (y = 0; y < ns; y++) { |
232 |
if (freadcolrs(scanin, sl, fp) < 0) |
233 |
goto readerr; |
234 |
for (x = 0; x < sl; x++) { |
235 |
pix2loc(loc, &inpres, x, y); |
236 |
i = (int)(loc[1]*inpres.yr)*inpres.xr + |
237 |
(int)(loc[0]*inpres.xr); |
238 |
copycolr(pp[0].arr.c[i], scanin[x]); |
239 |
240 |
241 |
free((void *)scanin); |
242 |
fclose(fp); |
243 |
i = hash(pname); |
244 |
pp[0].next = dtab[i]; /* link into picture list */ |
245 |
pp[1] = pp[0]; |
246 |
pp[2] = pp[0]; |
247 |
pp[0].type = RED; /* differentiate RGB records */ |
248 |
pp[1].type = GRN; |
249 |
pp[2].type = BLU; |
250 |
return(dtab[i] = pp); |
251 |
252 |
memerr: |
253 |
error(SYSTEM, "out of memory in getpict"); |
254 |
readerr: |
255 |
sprintf(errmsg, "bad picture file \"%s\"", pfname); |
256 |
257 |
258 |
259 |
260 |
261 |
void |
262 |
freedata( /* release data array reference */ |
263 |
DATARRAY *dta |
264 |
265 |
266 |
DATARRAY head; |
267 |
int hval, nents; |
268 |
DATARRAY *dpl, *dp; |
269 |
int i; |
270 |
271 |
if (dta == NULL) { /* free all if NULL */ |
272 |
hval = 0; nents = TABSIZ; |
273 |
} else { |
274 |
hval = hash(dta->name); nents = 1; |
275 |
276 |
while (nents--) { |
277 |
head.next = dtab[hval]; |
278 |
dpl = &head; |
279 |
while ((dp = dpl->next) != NULL) |
280 |
if ((dta == NULL) | (dta == dp)) { |
281 |
dpl->next = dp->next; |
282 |
if (dp->type == DATATY) |
283 |
free((void *)dp->arr.d); |
284 |
else |
285 |
free((void *)dp->arr.c); |
286 |
for (i = 0; i < dp->nd; i++) |
287 |
if (dp->dim[i].p != NULL) |
288 |
free((void *)dp->dim[i].p); |
289 |
freestr(dp->name); |
290 |
free((void *)dp); |
291 |
} else |
292 |
dpl = dp; |
293 |
dtab[hval++] = head.next; |
294 |
295 |
296 |
297 |
298 |
double |
299 |
datavalue( /* interpolate data value at a point */ |
300 |
DATARRAY *dp, |
301 |
double *pt |
302 |
303 |
304 |
DATARRAY sd; |
305 |
int asize; |
306 |
int lower, upper; |
307 |
int i; |
308 |
double x, y0, y1; |
309 |
/* set up dimensions for recursion */ |
310 |
if (dp->nd > 1) { |
311 |
sd.name = dp->name; |
312 |
sd.type = dp->type; |
313 |
sd.nd = dp->nd - 1; |
314 |
asize = 1; |
315 |
for (i = 0; i < sd.nd; i++) { |
316 |
sd.dim[i].org = dp->dim[i+1].org; |
317 |
sd.dim[i].siz = dp->dim[i+1].siz; |
318 |
sd.dim[i].p = dp->dim[i+1].p; |
319 |
asize *= sd.dim[i].ne = dp->dim[i+1].ne; |
320 |
321 |
322 |
/* get independent variable */ |
323 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */ |
324 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; |
325 |
x *= (double)(dp->dim[0].ne - 1); |
326 |
i = x; |
327 |
if (i < 0) |
328 |
i = 0; |
329 |
else if (i > dp->dim[0].ne - 2) |
330 |
i = dp->dim[0].ne - 2; |
331 |
} else { /* unevenly spaced points */ |
332 |
if (dp->dim[0].siz > 0.0) { |
333 |
lower = 0; |
334 |
upper = dp->dim[0].ne; |
335 |
} else { |
336 |
lower = dp->dim[0].ne; |
337 |
upper = 0; |
338 |
339 |
do { |
340 |
i = (lower + upper) >> 1; |
341 |
if (pt[0] >= dp->dim[0].p[i]) |
342 |
lower = i; |
343 |
else |
344 |
upper = i; |
345 |
} while (i != (lower + upper) >> 1); |
346 |
347 |
348 |
x = i + (pt[0] - dp->dim[0].p[i]) / |
349 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]); |
350 |
351 |
/* get dependent variable */ |
352 |
if (dp->nd > 1) { |
353 |
if (dp->type == DATATY) { |
354 |
sd.arr.d = dp->arr.d + i*asize; |
355 |
y0 = datavalue(&sd, pt+1); |
356 |
sd.arr.d = dp->arr.d + (i+1)*asize; |
357 |
y1 = datavalue(&sd, pt+1); |
358 |
} else { |
359 |
sd.arr.c = dp->arr.c + i*asize; |
360 |
361 |
sd.arr.c = dp->arr.c + (i+1)*asize; |
362 |
363 |
364 |
} else { |
365 |
366 |
y0 = dp->arr.d[i]; |
367 |
y1 = dp->arr.d[i+1]; |
368 |
} else { |
369 |
y0 = colrval(dp->arr.c[i],dp->type); |
370 |
y1 = colrval(dp->arr.c[i+1],dp->type); |
371 |
372 |
373 |
374 |
* Extrapolate as far as one division, then |
375 |
* taper off harmonically to zero. |
376 |
377 |
if (x > i+2) |
378 |
return( (2*y1-y0)/(x-(i-1)) ); |
379 |
380 |
if (x < i-1) |
381 |
return( (2*y0-y1)/(i-x) ); |
382 |
383 |
return( y0*((i+1)-x) + y1*(x-i) ); |
384 |
