root/radiance/ray/src/rt/data.c
Revision: 2.27
Committed: Tue Mar 30 16:13:01 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.26: +21 -14 lines
2 static const char RCSid[] = "$Id: data.c,v 2.26 2004/01/02 11:43:42 schorsch Exp $";
5 * data.c - routines dealing with interpolated data.
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11
12 #include "platform.h"
13 #include "standard.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "view.h"
17 #include "data.h"
18
19 /* picture memory usage before warning */
20 #ifndef PSIZWARN
21 #ifdef SMLMEM
22 #define PSIZWARN 1500000
23 #else
24 #define PSIZWARN 5000000
25 #endif
26 #endif
27
28 #ifndef TABSIZ
29 #define TABSIZ 97 /* table size (prime) */
30 #endif
31
32 #define hash(s) (shash(s)%TABSIZ)
33
34
35 static DATARRAY *dtab[TABSIZ]; /* data array list */
36
37 static gethfunc headaspect;
38
39
40 extern DATARRAY *
41 getdata( /* get data array dname */
42 char *dname
43 )
44 {
45 char *dfname;
46 FILE *fp;
47 int asize;
48 register int i, j;
49 register DATARRAY *dp;
50 /* look for array in list */
51 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
52 if (!strcmp(dname, dp->name))
53 return(dp); /* found! */
54 /*
55 * If we haven't loaded the data already, we will look
56 * for it in the directories specified by the library path.
57 *
58 * The file has the following format:
59 *
60 * N
61 * beg0 end0 n0
62 * beg1 end1 n1
63 * . . .
64 * begN endN nN
65 * data, later dimensions changing faster
66 * . . .
67 *
68 * For irregularly spaced points, the following can be
69 * substituted for begi endi ni:
70 *
71 * 0 0 ni p0i p1i .. pni
72 */
73
74 if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
75 sprintf(errmsg, "cannot find data file \"%s\"", dname);
76 error(USER, errmsg);
77 }
78 if ((fp = fopen(dfname, "r")) == NULL) {
79 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
80 error(SYSTEM, errmsg);
81 }
82 /* get dimensions */
83 if (fgetval(fp, 'i', (char *)&asize) <= 0)
84 goto scanerr;
85 if ((asize <= 0) | (asize > MAXDDIM)) {
86 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
87 error(USER, errmsg);
88 }
89 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
90 goto memerr;
91 dp->name = savestr(dname);
92 dp->type = DATATY;
93 dp->nd = asize;
94 asize = 1;
95 for (i = 0; i < dp->nd; i++) {
96 if (fgetval(fp, DATATY, (char *)&dp->dim[i].org) <= 0)
97 goto scanerr;
98 if (fgetval(fp, DATATY, (char *)&dp->dim[i].siz) <= 0)
99 goto scanerr;
100 if (fgetval(fp, 'i', (char *)&dp->dim[i].ne) <= 0)
101 goto scanerr;
102 if (dp->dim[i].ne < 2)
103 goto scanerr;
104 asize *= dp->dim[i].ne;
105 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
106 dp->dim[i].p = (DATATYPE *)
107 malloc(dp->dim[i].ne*sizeof(DATATYPE));
108 if (dp->dim[i].p == NULL)
109 goto memerr;
110 for (j = 0; j < dp->dim[i].ne; j++)
111 if (fgetval(fp, DATATY,
112 (char *)&dp->dim[i].p[j]) <= 0)
113 goto scanerr;
114 for (j = 1; j < dp->dim[i].ne-1; j++)
115 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
116 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
117 goto scanerr;
118 dp->dim[i].org = dp->dim[i].p[0];
119 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
120 - dp->dim[i].p[0];
121 } else
122 dp->dim[i].p = NULL;
123 }
124 if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
125 goto memerr;
126
127 for (i = 0; i < asize; i++)
128 if (fgetval(fp, DATATY, (char *)&dp->arr.d[i]) <= 0)
129 goto scanerr;
130 fclose(fp);
131 i = hash(dname);
132 dp->next = dtab[i];
133 return(dtab[i] = dp);
134
135 memerr:
136 error(SYSTEM, "out of memory in getdata");
137 scanerr:
138 sprintf(errmsg, "%s in data file \"%s\"",
139 feof(fp) ? "unexpected EOF" : "bad format", dfname);
140 error(USER, errmsg);
141 return NULL; /* pro forma return */
142 }
143
144
145 static int
146 headaspect( /* check string for aspect ratio */
147 char *s,
148 void *iap
149 )
150 {
151 char fmt[32];
152
153 if (isaspect(s))
154 *(double*)iap *= aspectval(s);
155 else if (formatval(fmt, s) && !globmatch(PICFMT, fmt))
156 *(double*)iap = 0.0;
157 return(0);
158 }
159
160
161 extern DATARRAY *
162 getpict( /* get picture pname */
163 char *pname
164 )
165 {
166 double inpaspect;
167 char *pfname;
168 FILE *fp;
169 COLR *scanin;
170 int sl, ns;
171 RESOLU inpres;
172 RREAL loc[2];
173 int y;
174 register int x, i;
175 register DATARRAY *pp;
176 /* look for array in list */
177 for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
178 if (!strcmp(pname, pp->name))
179 return(pp); /* found! */
180
181 if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
182 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
183 error(USER, errmsg);
184 }
185 if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
186 goto memerr;
187
188 pp[0].name = savestr(pname);
189
190 if ((fp = fopen(pfname, "r")) == NULL) {
191 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
192 error(SYSTEM, errmsg);
193 }
194 SET_FILE_BINARY(fp);
195 /* get dimensions */
196 inpaspect = 1.0;
197 getheader(fp, headaspect, &inpaspect);
198 if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
199 goto readerr;
200 pp[0].nd = 2;
201 pp[0].dim[0].ne = inpres.yr;
202 pp[0].dim[1].ne = inpres.xr;
203 pp[0].dim[0].org =
204 pp[0].dim[1].org = 0.0;
205 if (inpres.xr <= inpres.yr*inpaspect) {
206 pp[0].dim[0].siz = inpaspect *
207 (double)inpres.yr/inpres.xr;
208 pp[0].dim[1].siz = 1.0;
209 } else {
210 pp[0].dim[0].siz = 1.0;
211 pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
212 inpaspect;
213 }
214 pp[0].dim[0].p = pp[0].dim[1].p = NULL;
215 sl = scanlen(&inpres); /* allocate array */
216 ns = numscans(&inpres);
217 i = ns*sl*sizeof(COLR);
218 #if PSIZWARN
219 if (i > PSIZWARN) { /* memory warning */
220 sprintf(errmsg, "picture file \"%s\" using %d bytes of memory",
221 pname, i);
222 error(WARNING, errmsg);
223 }
224 #endif
225 if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
226 goto memerr;
227 /* load picture */
228 if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
229 goto memerr;
230 for (y = 0; y < ns; y++) {
231 if (freadcolrs(scanin, sl, fp) < 0)
232 goto readerr;
233 for (x = 0; x < sl; x++) {
234 pix2loc(loc, &inpres, x, y);
235 i = (int)(loc[1]*inpres.yr)*inpres.xr +
236 (int)(loc[0]*inpres.xr);
237 copycolr(pp[0].arr.c[i], scanin[x]);
238 }
239 }
240 free((void *)scanin);
241 fclose(fp);
242 i = hash(pname);
243 pp[0].next = dtab[i]; /* link into picture list */
244 pp[1] = pp[0];
245 pp[2] = pp[0];
246 pp[0].type = RED; /* differentiate RGB records */
247 pp[1].type = GRN;
248 pp[2].type = BLU;
249 return(dtab[i] = pp);
250
251 memerr:
252 error(SYSTEM, "out of memory in getpict");
253 readerr:
254 sprintf(errmsg, "bad picture file \"%s\"", pfname);
255 error(USER, errmsg);
256 return NULL; /* pro forma return */
257 }
258
259
260 extern void
261 freedata( /* release data array reference */
262 DATARRAY *dta
263 )
264 {
265 DATARRAY head;
266 int hval, nents;
267 register DATARRAY *dpl, *dp;
268 register int i;
269
270 if (dta == NULL) { /* free all if NULL */
271 hval = 0; nents = TABSIZ;
272 } else {
273 hval = hash(dta->name); nents = 1;
274 }
275 while (nents--) {
276 head.next = dtab[hval];
277 dpl = &head;
278 while ((dp = dpl->next) != NULL)
279 if ((dta == NULL) | (dta == dp)) {
280 dpl->next = dp->next;
281 if (dp->type == DATATY)
282 free((void *)dp->arr.d);
283 else
284 free((void *)dp->arr.c);
285 for (i = 0; i < dp->nd; i++)
286 if (dp->dim[i].p != NULL)
287 free((void *)dp->dim[i].p);
288 freestr(dp->name);
289 free((void *)dp);
290 } else
291 dpl = dp;
292 dtab[hval++] = head.next;
293 }
294 }
295
296
297 extern double
298 datavalue( /* interpolate data value at a point */
299 register DATARRAY *dp,
300 double *pt
301 )
302 {
303 DATARRAY sd;
304 int asize;
305 int lower, upper;
306 register int i;
307 double x, y0, y1;
308 /* set up dimensions for recursion */
309 if (dp->nd > 1) {
310 sd.name = dp->name;
311 sd.type = dp->type;
312 sd.nd = dp->nd - 1;
313 asize = 1;
314 for (i = 0; i < sd.nd; i++) {
315 sd.dim[i].org = dp->dim[i+1].org;
316 sd.dim[i].siz = dp->dim[i+1].siz;
317 sd.dim[i].p = dp->dim[i+1].p;
318 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
319 }
320 }
321 /* get independent variable */
322 if (dp->dim[0].p == NULL) { /* evenly spaced points */
323 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
324 x *= (double)(dp->dim[0].ne - 1);
325 i = x;
326 if (i < 0)
327 i = 0;
328 else if (i > dp->dim[0].ne - 2)
329 i = dp->dim[0].ne - 2;
330 } else { /* unevenly spaced points */
331 if (dp->dim[0].siz > 0.0) {
332 lower = 0;
333 upper = dp->dim[0].ne;
334 } else {
335 lower = dp->dim[0].ne;
336 upper = 0;
337 }
338 do {
339 i = (lower + upper) >> 1;
340 if (pt[0] >= dp->dim[0].p[i])
341 lower = i;
342 else
343 upper = i;
344 } while (i != (lower + upper) >> 1);
345 if (i > dp->dim[0].ne - 2)
346 i = dp->dim[0].ne - 2;
347 x = i + (pt[0] - dp->dim[0].p[i]) /
348 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
349 }
350 /* get dependent variable */
351 if (dp->nd > 1) {
352 if (dp->type == DATATY) {
353 sd.arr.d = dp->arr.d + i*asize;
354 y0 = datavalue(&sd, pt+1);
355 sd.arr.d = dp->arr.d + (i+1)*asize;
356 y1 = datavalue(&sd, pt+1);
357 } else {
358 sd.arr.c = dp->arr.c + i*asize;
359 y0 = datavalue(&sd, pt+1);
360 sd.arr.c = dp->arr.c + (i+1)*asize;
361 y1 = datavalue(&sd, pt+1);
362 }
363 } else {
364 if (dp->type == DATATY) {
365 y0 = dp->arr.d[i];
366 y1 = dp->arr.d[i+1];
367 } else {
368 y0 = colrval(dp->arr.c[i],dp->type);
369 y1 = colrval(dp->arr.c[i+1],dp->type);
370 }
371 }
372 /*
373 * Extrapolate as far as one division, then
374 * taper off harmonically to zero.
375 */
376 if (x > i+2)
377 return( (2*y1-y0)/(x-(i-1)) );
378
379 if (x < i-1)
380 return( (2*y0-y1)/(i-x) );
381
382 return( y0*((i+1)-x) + y1*(x-i) );
383 }
