root/radiance/ray/src/rt/data.c
Revision: 2.23
Committed: Mon Jul 21 22:30:19 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: data.c,v 2.22 2003/07/16 01:32:53 greg Exp $";
5 * data.c - routines dealing with interpolated data.
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11
12 #include "standard.h"
13 #include "platform.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "data.h"
17
18 /* picture memory usage before warning */
19 #ifndef PSIZWARN
20 #ifdef SMLMEM
21 #define PSIZWARN 1500000
22 #else
23 #define PSIZWARN 5000000
24 #endif
25 #endif
26
27 #ifndef TABSIZ
28 #define TABSIZ 97 /* table size (prime) */
29 #endif
30
31 #define hash(s) (shash(s)%TABSIZ)
32
33
34 static DATARRAY *dtab[TABSIZ]; /* data array list */
35
36
37 DATARRAY *
38 getdata(dname) /* get data array dname */
39 char *dname;
40 {
41 char *dfname;
42 FILE *fp;
43 int asize;
44 register int i, j;
45 register DATARRAY *dp;
46 /* look for array in list */
47 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
48 if (!strcmp(dname, dp->name))
49 return(dp); /* found! */
50 /*
51 * If we haven't loaded the data already, we will look
52 * for it in the directories specified by the library path.
53 *
54 * The file has the following format:
55 *
56 * N
57 * beg0 end0 n0
58 * beg1 end1 n1
59 * . . .
60 * begN endN nN
61 * data, later dimensions changing faster
62 * . . .
63 *
64 * For irregularly spaced points, the following can be
65 * substituted for begi endi ni:
66 *
67 * 0 0 ni p0i p1i .. pni
68 */
69
70 if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
71 sprintf(errmsg, "cannot find data file \"%s\"", dname);
72 error(USER, errmsg);
73 }
74 if ((fp = fopen(dfname, "r")) == NULL) {
75 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
76 error(SYSTEM, errmsg);
77 }
78 /* get dimensions */
79 if (fgetval(fp, 'i', (char *)&asize) <= 0)
80 goto scanerr;
81 if (asize <= 0 | asize > MAXDDIM) {
82 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
83 error(USER, errmsg);
84 }
85 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
86 goto memerr;
87 dp->name = savestr(dname);
88 dp->type = DATATY;
89 dp->nd = asize;
90 asize = 1;
91 for (i = 0; i < dp->nd; i++) {
92 if (fgetval(fp, DATATY, (char *)&dp->dim[i].org) <= 0)
93 goto scanerr;
94 if (fgetval(fp, DATATY, (char *)&dp->dim[i].siz) <= 0)
95 goto scanerr;
96 if (fgetval(fp, 'i', (char *)&dp->dim[i].ne) <= 0)
97 goto scanerr;
98 if (dp->dim[i].ne < 2)
99 goto scanerr;
100 asize *= dp->dim[i].ne;
101 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
102 dp->dim[i].p = (DATATYPE *)
103 malloc(dp->dim[i].ne*sizeof(DATATYPE));
104 if (dp->dim[i].p == NULL)
105 goto memerr;
106 for (j = 0; j < dp->dim[i].ne; j++)
107 if (fgetval(fp, DATATY,
108 (char *)&dp->dim[i].p[j]) <= 0)
109 goto scanerr;
110 for (j = 1; j < dp->dim[i].ne-1; j++)
111 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
112 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
113 goto scanerr;
114 dp->dim[i].org = dp->dim[i].p[0];
115 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
116 - dp->dim[i].p[0];
117 } else
118 dp->dim[i].p = NULL;
119 }
120 if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
121 goto memerr;
122
123 for (i = 0; i < asize; i++)
124 if (fgetval(fp, DATATY, (char *)&dp->arr.d[i]) <= 0)
125 goto scanerr;
126 fclose(fp);
127 i = hash(dname);
128 dp->next = dtab[i];
129 return(dtab[i] = dp);
130
131 memerr:
132 error(SYSTEM, "out of memory in getdata");
133 scanerr:
134 sprintf(errmsg, "%s in data file \"%s\"",
135 feof(fp) ? "unexpected EOF" : "bad format", dfname);
136 error(USER, errmsg);
137 }
138
139
140 static int
141 headaspect(s, iap) /* check string for aspect ratio */
142 char *s;
143 double *iap;
144 {
145 char fmt[32];
146
147 if (isaspect(s))
148 *iap *= aspectval(s);
149 else if (formatval(fmt, s) && !globmatch(PICFMT, fmt))
150 *iap = 0.0;
151 return(0);
152 }
153
154
155 DATARRAY *
156 getpict(pname) /* get picture pname */
157 char *pname;
158 {
159 double inpaspect;
160 char *pfname;
161 FILE *fp;
162 COLR *scanin;
163 int sl, ns;
164 RESOLU inpres;
165 RREAL loc[2];
166 int y;
167 register int x, i;
168 register DATARRAY *pp;
169 /* look for array in list */
170 for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
171 if (!strcmp(pname, pp->name))
172 return(pp); /* found! */
173
174 if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
175 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
176 error(USER, errmsg);
177 }
178 if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
179 goto memerr;
180
181 pp[0].name = savestr(pname);
182
183 if ((fp = fopen(pfname, "r")) == NULL) {
184 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
185 error(SYSTEM, errmsg);
186 }
187 SET_FILE_BINARY(fp);
188 /* get dimensions */
189 inpaspect = 1.0;
190 getheader(fp, headaspect, (char *)&inpaspect);
191 if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
192 goto readerr;
193 pp[0].nd = 2;
194 pp[0].dim[0].ne = inpres.yr;
195 pp[0].dim[1].ne = inpres.xr;
196 pp[0].dim[0].org =
197 pp[0].dim[1].org = 0.0;
198 if (inpres.xr <= inpres.yr*inpaspect) {
199 pp[0].dim[0].siz = inpaspect *
200 (double)inpres.yr/inpres.xr;
201 pp[0].dim[1].siz = 1.0;
202 } else {
203 pp[0].dim[0].siz = 1.0;
204 pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
205 inpaspect;
206 }
207 pp[0].dim[0].p = pp[0].dim[1].p = NULL;
208 sl = scanlen(&inpres); /* allocate array */
209 ns = numscans(&inpres);
210 i = ns*sl*sizeof(COLR);
211 #if PSIZWARN
212 if (i > PSIZWARN) { /* memory warning */
213 sprintf(errmsg, "picture file \"%s\" using %d bytes of memory",
214 pname, i);
215 error(WARNING, errmsg);
216 }
217 #endif
218 if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
219 goto memerr;
220 /* load picture */
221 if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
222 goto memerr;
223 for (y = 0; y < ns; y++) {
224 if (freadcolrs(scanin, sl, fp) < 0)
225 goto readerr;
226 for (x = 0; x < sl; x++) {
227 pix2loc(loc, &inpres, x, y);
228 i = (int)(loc[1]*inpres.yr)*inpres.xr +
229 (int)(loc[0]*inpres.xr);
230 copycolr(pp[0].arr.c[i], scanin[x]);
231 }
232 }
233 free((void *)scanin);
234 fclose(fp);
235 i = hash(pname);
236 pp[0].next = dtab[i]; /* link into picture list */
237 pp[1] = pp[0];
238 pp[2] = pp[0];
239 pp[0].type = RED; /* differentiate RGB records */
240 pp[1].type = GRN;
241 pp[2].type = BLU;
242 return(dtab[i] = pp);
243
244 memerr:
245 error(SYSTEM, "out of memory in getpict");
246 readerr:
247 sprintf(errmsg, "bad picture file \"%s\"", pfname);
248 error(USER, errmsg);
249 }
250
251
252 void
253 freedata(dta) /* release data array reference */
254 DATARRAY *dta;
255 {
256 DATARRAY head;
257 int hval, nents;
258 register DATARRAY *dpl, *dp;
259 register int i;
260
261 if (dta == NULL) { /* free all if NULL */
262 hval = 0; nents = TABSIZ;
263 } else {
264 hval = hash(dta->name); nents = 1;
265 }
266 while (nents--) {
267 head.next = dtab[hval];
268 dpl = &head;
269 while ((dp = dpl->next) != NULL)
270 if ((dta == NULL | dta == dp)) {
271 dpl->next = dp->next;
272 if (dp->type == DATATY)
273 free((void *)dp->arr.d);
274 else
275 free((void *)dp->arr.c);
276 for (i = 0; i < dp->nd; i++)
277 if (dp->dim[i].p != NULL)
278 free((void *)dp->dim[i].p);
279 freestr(dp->name);
280 free((void *)dp);
281 } else
282 dpl = dp;
283 dtab[hval++] = head.next;
284 }
285 }
286
287
288 double
289 datavalue(dp, pt) /* interpolate data value at a point */
290 register DATARRAY *dp;
291 double *pt;
292 {
293 DATARRAY sd;
294 int asize;
295 int lower, upper;
296 register int i;
297 double x, y0, y1;
298 /* set up dimensions for recursion */
299 if (dp->nd > 1) {
300 sd.name = dp->name;
301 sd.type = dp->type;
302 sd.nd = dp->nd - 1;
303 asize = 1;
304 for (i = 0; i < sd.nd; i++) {
305 sd.dim[i].org = dp->dim[i+1].org;
306 sd.dim[i].siz = dp->dim[i+1].siz;
307 sd.dim[i].p = dp->dim[i+1].p;
308 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
309 }
310 }
311 /* get independent variable */
312 if (dp->dim[0].p == NULL) { /* evenly spaced points */
313 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
314 x *= (double)(dp->dim[0].ne - 1);
315 i = x;
316 if (i < 0)
317 i = 0;
318 else if (i > dp->dim[0].ne - 2)
319 i = dp->dim[0].ne - 2;
320 } else { /* unevenly spaced points */
321 if (dp->dim[0].siz > 0.0) {
322 lower = 0;
323 upper = dp->dim[0].ne;
324 } else {
325 lower = dp->dim[0].ne;
326 upper = 0;
327 }
328 do {
329 i = (lower + upper) >> 1;
330 if (pt[0] >= dp->dim[0].p[i])
331 lower = i;
332 else
333 upper = i;
334 } while (i != (lower + upper) >> 1);
335 if (i > dp->dim[0].ne - 2)
336 i = dp->dim[0].ne - 2;
337 x = i + (pt[0] - dp->dim[0].p[i]) /
338 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
339 }
340 /* get dependent variable */
341 if (dp->nd > 1) {
342 if (dp->type == DATATY) {
343 sd.arr.d = dp->arr.d + i*asize;
344 y0 = datavalue(&sd, pt+1);
345 sd.arr.d = dp->arr.d + (i+1)*asize;
346 y1 = datavalue(&sd, pt+1);
347 } else {
348 sd.arr.c = dp->arr.c + i*asize;
349 y0 = datavalue(&sd, pt+1);
350 sd.arr.c = dp->arr.c + (i+1)*asize;
351 y1 = datavalue(&sd, pt+1);
352 }
353 } else {
354 if (dp->type == DATATY) {
355 y0 = dp->arr.d[i];
356 y1 = dp->arr.d[i+1];
357 } else {
358 y0 = colrval(dp->arr.c[i],dp->type);
359 y1 = colrval(dp->arr.c[i+1],dp->type);
360 }
361 }
362 /*
363 * Extrapolate as far as one division, then
364 * taper off harmonically to zero.
365 */
366 if (x > i+2)
367 return( (2*y1-y0)/(x-(i-1)) );
368
369 if (x < i-1)
370 return( (2*y0-y1)/(i-x) );
371
372 return( y0*((i+1)-x) + y1*(x-i) );
373 }
