root/radiance/ray/src/rt/data.c
Revision: 2.21
Committed: Thu Jun 26 00:58:10 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: data.c,v 2.20 2003/06/08 12:03:10 schorsch Exp $";
5 * data.c - routines dealing with interpolated data.
6 */
7
8 #include "copyright.h"
9
10 #include "standard.h"
11 #include "platform.h"
12 #include "color.h"
13 #include "resolu.h"
14 #include "data.h"
15
16 /* picture memory usage before warning */
17 #ifndef PSIZWARN
18 #ifdef SMLMEM
19 #define PSIZWARN 1500000
20 #else
21 #define PSIZWARN 5000000
22 #endif
23 #endif
24
25 #ifndef TABSIZ
26 #define TABSIZ 97 /* table size (prime) */
27 #endif
28
29 #define hash(s) (shash(s)%TABSIZ)
30
31
32 static DATARRAY *dtab[TABSIZ]; /* data array list */
33
34
35 DATARRAY *
36 getdata(dname) /* get data array dname */
37 char *dname;
38 {
39 char *dfname;
40 FILE *fp;
41 int asize;
42 register int i, j;
43 register DATARRAY *dp;
44 /* look for array in list */
45 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
46 if (!strcmp(dname, dp->name))
47 return(dp); /* found! */
48 /*
49 * If we haven't loaded the data already, we will look
50 * for it in the directories specified by the library path.
51 *
52 * The file has the following format:
53 *
54 * N
55 * beg0 end0 n0
56 * beg1 end1 n1
57 * . . .
58 * begN endN nN
59 * data, later dimensions changing faster
60 * . . .
61 *
62 * For irregularly spaced points, the following can be
63 * substituted for begi endi ni:
64 *
65 * 0 0 ni p0i p1i .. pni
66 */
67
68 if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
69 sprintf(errmsg, "cannot find data file \"%s\"", dname);
70 error(USER, errmsg);
71 }
72 if ((fp = fopen(dfname, "r")) == NULL) {
73 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
74 error(SYSTEM, errmsg);
75 }
76 /* get dimensions */
77 if (fgetval(fp, 'i', (char *)&asize) <= 0)
78 goto scanerr;
79 if (asize <= 0 | asize > MAXDDIM) {
80 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
81 error(USER, errmsg);
82 }
83 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
84 goto memerr;
85 dp->name = savestr(dname);
86 dp->type = DATATY;
87 dp->nd = asize;
88 asize = 1;
89 for (i = 0; i < dp->nd; i++) {
90 if (fgetval(fp, DATATY, (char *)&dp->dim[i].org) <= 0)
91 goto scanerr;
92 if (fgetval(fp, DATATY, (char *)&dp->dim[i].siz) <= 0)
93 goto scanerr;
94 if (fgetval(fp, 'i', (char *)&dp->dim[i].ne) <= 0)
95 goto scanerr;
96 if (dp->dim[i].ne < 2)
97 goto scanerr;
98 asize *= dp->dim[i].ne;
99 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
100 dp->dim[i].p = (DATATYPE *)
101 malloc(dp->dim[i].ne*sizeof(DATATYPE));
102 if (dp->dim[i].p == NULL)
103 goto memerr;
104 for (j = 0; j < dp->dim[i].ne; j++)
105 if (fgetval(fp, DATATY,
106 (char *)&dp->dim[i].p[j]) <= 0)
107 goto scanerr;
108 for (j = 1; j < dp->dim[i].ne-1; j++)
109 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
110 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
111 goto scanerr;
112 dp->dim[i].org = dp->dim[i].p[0];
113 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
114 - dp->dim[i].p[0];
115 } else
116 dp->dim[i].p = NULL;
117 }
118 if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
119 goto memerr;
120
121 for (i = 0; i < asize; i++)
122 if (fgetval(fp, DATATY, (char *)&dp->arr.d[i]) <= 0)
123 goto scanerr;
124 fclose(fp);
125 i = hash(dname);
126 dp->next = dtab[i];
127 return(dtab[i] = dp);
128
129 memerr:
130 error(SYSTEM, "out of memory in getdata");
131 scanerr:
132 sprintf(errmsg, "%s in data file \"%s\"",
133 feof(fp) ? "unexpected EOF" : "bad format", dfname);
134 error(USER, errmsg);
135 }
136
137
138 static int
139 headaspect(s, iap) /* check string for aspect ratio */
140 char *s;
141 double *iap;
142 {
143 char fmt[32];
144
145 if (isaspect(s))
146 *iap *= aspectval(s);
147 else if (formatval(fmt, s) && !globmatch(PICFMT, fmt))
148 *iap = 0.0;
149 return(0);
150 }
151
152
153 DATARRAY *
154 getpict(pname) /* get picture pname */
155 char *pname;
156 {
157 double inpaspect;
158 char *pfname;
159 FILE *fp;
160 COLR *scanin;
161 int sl, ns;
162 RESOLU inpres;
163 RREAL loc[2];
164 int y;
165 register int x, i;
166 register DATARRAY *pp;
167 /* look for array in list */
168 for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
169 if (!strcmp(pname, pp->name))
170 return(pp); /* found! */
171
172 if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
173 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
174 error(USER, errmsg);
175 }
176 if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
177 goto memerr;
178
179 pp[0].name = savestr(pname);
180
181 if ((fp = fopen(pfname, "r")) == NULL) {
182 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
183 error(SYSTEM, errmsg);
184 }
185 SET_FILE_BINARY(fp);
186 /* get dimensions */
187 inpaspect = 1.0;
188 getheader(fp, headaspect, (char *)&inpaspect);
189 if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
190 goto readerr;
191 pp[0].nd = 2;
192 pp[0].dim[0].ne = inpres.yr;
193 pp[0].dim[1].ne = inpres.xr;
194 pp[0].dim[0].org =
195 pp[0].dim[1].org = 0.0;
196 if (inpres.xr <= inpres.yr*inpaspect) {
197 pp[0].dim[0].siz = inpaspect *
198 (double)inpres.yr/inpres.xr;
199 pp[0].dim[1].siz = 1.0;
200 } else {
201 pp[0].dim[0].siz = 1.0;
202 pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
203 inpaspect;
204 }
205 pp[0].dim[0].p = pp[0].dim[1].p = NULL;
206 sl = scanlen(&inpres); /* allocate array */
207 ns = numscans(&inpres);
208 i = ns*sl*sizeof(COLR);
209 #if PSIZWARN
210 if (i > PSIZWARN) { /* memory warning */
211 sprintf(errmsg, "picture file \"%s\" using %d bytes of memory",
212 pname, i);
213 error(WARNING, errmsg);
214 }
215 #endif
216 if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
217 goto memerr;
218 /* load picture */
219 if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
220 goto memerr;
221 for (y = 0; y < ns; y++) {
222 if (freadcolrs(scanin, sl, fp) < 0)
223 goto readerr;
224 for (x = 0; x < sl; x++) {
225 pix2loc(loc, &inpres, x, y);
226 i = (int)(loc[1]*inpres.yr)*inpres.xr +
227 (int)(loc[0]*inpres.xr);
228 copycolr(pp[0].arr.c[i], scanin[x]);
229 }
230 }
231 free((void *)scanin);
232 fclose(fp);
233 i = hash(pname);
234 pp[0].next = dtab[i]; /* link into picture list */
235 copystruct(&pp[1], &pp[0]);
236 copystruct(&pp[2], &pp[0]);
237 pp[0].type = RED; /* differentiate RGB records */
238 pp[1].type = GRN;
239 pp[2].type = BLU;
240 return(dtab[i] = pp);
241
242 memerr:
243 error(SYSTEM, "out of memory in getpict");
244 readerr:
245 sprintf(errmsg, "bad picture file \"%s\"", pfname);
246 error(USER, errmsg);
247 }
248
249
250 void
251 freedata(dta) /* release data array reference */
252 DATARRAY *dta;
253 {
254 DATARRAY head;
255 int hval, nents;
256 register DATARRAY *dpl, *dp;
257 register int i;
258
259 if (dta == NULL) { /* free all if NULL */
260 hval = 0; nents = TABSIZ;
261 } else {
262 hval = hash(dta->name); nents = 1;
263 }
264 while (nents--) {
265 head.next = dtab[hval];
266 dpl = &head;
267 while ((dp = dpl->next) != NULL)
268 if ((dta == NULL | dta == dp)) {
269 dpl->next = dp->next;
270 if (dp->type == DATATY)
271 free((void *)dp->arr.d);
272 else
273 free((void *)dp->arr.c);
274 for (i = 0; i < dp->nd; i++)
275 if (dp->dim[i].p != NULL)
276 free((void *)dp->dim[i].p);
277 freestr(dp->name);
278 free((void *)dp);
279 } else
280 dpl = dp;
281 dtab[hval++] = head.next;
282 }
283 }
284
285
286 double
287 datavalue(dp, pt) /* interpolate data value at a point */
288 register DATARRAY *dp;
289 double *pt;
290 {
291 DATARRAY sd;
292 int asize;
293 int lower, upper;
294 register int i;
295 double x, y0, y1;
296 /* set up dimensions for recursion */
297 if (dp->nd > 1) {
298 sd.name = dp->name;
299 sd.type = dp->type;
300 sd.nd = dp->nd - 1;
301 asize = 1;
302 for (i = 0; i < sd.nd; i++) {
303 sd.dim[i].org = dp->dim[i+1].org;
304 sd.dim[i].siz = dp->dim[i+1].siz;
305 sd.dim[i].p = dp->dim[i+1].p;
306 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
307 }
308 }
309 /* get independent variable */
310 if (dp->dim[0].p == NULL) { /* evenly spaced points */
311 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
312 x *= (double)(dp->dim[0].ne - 1);
313 i = x;
314 if (i < 0)
315 i = 0;
316 else if (i > dp->dim[0].ne - 2)
317 i = dp->dim[0].ne - 2;
318 } else { /* unevenly spaced points */
319 if (dp->dim[0].siz > 0.0) {
320 lower = 0;
321 upper = dp->dim[0].ne;
322 } else {
323 lower = dp->dim[0].ne;
324 upper = 0;
325 }
326 do {
327 i = (lower + upper) >> 1;
328 if (pt[0] >= dp->dim[0].p[i])
329 lower = i;
330 else
331 upper = i;
332 } while (i != (lower + upper) >> 1);
333 if (i > dp->dim[0].ne - 2)
334 i = dp->dim[0].ne - 2;
335 x = i + (pt[0] - dp->dim[0].p[i]) /
336 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
337 }
338 /* get dependent variable */
339 if (dp->nd > 1) {
340 if (dp->type == DATATY) {
341 sd.arr.d = dp->arr.d + i*asize;
342 y0 = datavalue(&sd, pt+1);
343 sd.arr.d = dp->arr.d + (i+1)*asize;
344 y1 = datavalue(&sd, pt+1);
345 } else {
346 sd.arr.c = dp->arr.c + i*asize;
347 y0 = datavalue(&sd, pt+1);
348 sd.arr.c = dp->arr.c + (i+1)*asize;
349 y1 = datavalue(&sd, pt+1);
350 }
351 } else {
352 if (dp->type == DATATY) {
353 y0 = dp->arr.d[i];
354 y1 = dp->arr.d[i+1];
355 } else {
356 y0 = colrval(dp->arr.c[i],dp->type);
357 y1 = colrval(dp->arr.c[i+1],dp->type);
358 }
359 }
360 /*
361 * Extrapolate as far as one division, then
362 * taper off harmonically to zero.
363 */
364 if (x > i+2)
365 return( (2*y1-y0)/(x-(i-1)) );
366
367 if (x < i-1)
368 return( (2*y0-y1)/(i-x) );
369
370 return( y0*((i+1)-x) + y1*(x-i) );
371 }
