1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: data.c,v 2.19 2003/06/05 19:29:34 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* data.c - routines dealing with interpolated data. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "standard.h" |
11 |
#include "platform.h" |
12 |
#include "color.h" |
13 |
#include "resolu.h" |
14 |
#include "data.h" |
15 |
16 |
/* picture memory usage before warning */ |
17 |
#ifndef PSIZWARN |
18 |
#ifdef SMLMEM |
19 |
#define PSIZWARN 1500000 |
20 |
#else |
21 |
#define PSIZWARN 5000000 |
22 |
#endif |
23 |
#endif |
24 |
25 |
#ifndef TABSIZ |
26 |
#define TABSIZ 97 /* table size (prime) */ |
27 |
#endif |
28 |
29 |
#define hash(s) (shash(s)%TABSIZ) |
30 |
31 |
32 |
static DATARRAY *dtab[TABSIZ]; /* data array list */ |
33 |
34 |
35 |
DATARRAY * |
36 |
getdata(dname) /* get data array dname */ |
37 |
char *dname; |
38 |
39 |
char *dfname; |
40 |
FILE *fp; |
41 |
int asize; |
42 |
register int i, j; |
43 |
register DATARRAY *dp; |
44 |
/* look for array in list */ |
45 |
for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next) |
46 |
if (!strcmp(dname, dp->name)) |
47 |
return(dp); /* found! */ |
48 |
49 |
* If we haven't loaded the data already, we will look |
50 |
* for it in the directories specified by the library path. |
51 |
52 |
* The file has the following format: |
53 |
54 |
* N |
55 |
* beg0 end0 n0 |
56 |
* beg1 end1 n1 |
57 |
58 |
* begN endN nN |
59 |
* data, later dimensions changing faster |
60 |
61 |
62 |
* For irregularly spaced points, the following can be |
63 |
* substituted for begi endi ni: |
64 |
65 |
* 0 0 ni p0i p1i .. pni |
66 |
67 |
68 |
if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) { |
69 |
sprintf(errmsg, "cannot find data file \"%s\"", dname); |
70 |
error(USER, errmsg); |
71 |
72 |
if ((fp = fopen(dfname, "r")) == NULL) { |
73 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname); |
74 |
error(SYSTEM, errmsg); |
75 |
76 |
/* get dimensions */ |
77 |
if (fgetval(fp, 'i', (char *)&asize) <= 0) |
78 |
goto scanerr; |
79 |
if (asize <= 0 | asize > MAXDDIM) { |
80 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname); |
81 |
82 |
83 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL) |
84 |
goto memerr; |
85 |
dp->name = savestr(dname); |
86 |
dp->type = DATATY; |
87 |
dp->nd = asize; |
88 |
asize = 1; |
89 |
for (i = 0; i < dp->nd; i++) { |
90 |
if (fgetval(fp, DATATY, (char *)&dp->dim[i].org) <= 0) |
91 |
goto scanerr; |
92 |
if (fgetval(fp, DATATY, (char *)&dp->dim[i].siz) <= 0) |
93 |
goto scanerr; |
94 |
if (fgetval(fp, 'i', (char *)&dp->dim[i].ne) <= 0) |
95 |
goto scanerr; |
96 |
if (dp->dim[i].ne < 2) |
97 |
goto scanerr; |
98 |
asize *= dp->dim[i].ne; |
99 |
if ((dp->dim[i].siz -= dp->dim[i].org) == 0) { |
100 |
dp->dim[i].p = (DATATYPE *) |
101 |
malloc(dp->dim[i].ne*sizeof(DATATYPE)); |
102 |
if (dp->dim[i].p == NULL) |
103 |
goto memerr; |
104 |
for (j = 0; j < dp->dim[i].ne; j++) |
105 |
if (fgetval(fp, DATATY, |
106 |
(char *)&dp->dim[i].p[j]) <= 0) |
107 |
goto scanerr; |
108 |
for (j = 1; j < dp->dim[i].ne-1; j++) |
109 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) != |
110 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1])) |
111 |
goto scanerr; |
112 |
dp->dim[i].org = dp->dim[i].p[0]; |
113 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1] |
114 |
- dp->dim[i].p[0]; |
115 |
} else |
116 |
dp->dim[i].p = NULL; |
117 |
118 |
if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL) |
119 |
goto memerr; |
120 |
121 |
for (i = 0; i < asize; i++) |
122 |
if (fgetval(fp, DATATY, (char *)&dp->arr.d[i]) <= 0) |
123 |
goto scanerr; |
124 |
fclose(fp); |
125 |
i = hash(dname); |
126 |
dp->next = dtab[i]; |
127 |
return(dtab[i] = dp); |
128 |
129 |
memerr: |
130 |
error(SYSTEM, "out of memory in getdata"); |
131 |
scanerr: |
132 |
sprintf(errmsg, "%s in data file \"%s\"", |
133 |
feof(fp) ? "unexpected EOF" : "bad format", dfname); |
134 |
135 |
136 |
137 |
138 |
static int |
139 |
headaspect(s, iap) /* check string for aspect ratio */ |
140 |
char *s; |
141 |
double *iap; |
142 |
143 |
char fmt[32]; |
144 |
145 |
if (isaspect(s)) |
146 |
*iap *= aspectval(s); |
147 |
else if (formatval(fmt, s) && !globmatch(PICFMT, fmt)) |
148 |
*iap = 0.0; |
149 |
return(0); |
150 |
151 |
152 |
153 |
DATARRAY * |
154 |
getpict(pname) /* get picture pname */ |
155 |
char *pname; |
156 |
157 |
double inpaspect; |
158 |
char *pfname; |
159 |
FILE *fp; |
160 |
COLR *scanin; |
161 |
int sl, ns; |
162 |
RESOLU inpres; |
163 |
FLOAT loc[2]; |
164 |
int y; |
165 |
register int x, i; |
166 |
register DATARRAY *pp; |
167 |
168 |
for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next) |
169 |
if (!strcmp(pname, pp->name)) |
170 |
return(pp); /* found! */ |
171 |
172 |
if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) { |
173 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname); |
174 |
175 |
176 |
if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL) |
177 |
goto memerr; |
178 |
179 |
pp[0].name = savestr(pname); |
180 |
181 |
if ((fp = fopen(pfname, "r")) == NULL) { |
182 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname); |
183 |
184 |
185 |
SET_FILE_BINARY(fp); |
186 |
187 |
inpaspect = 1.0; |
188 |
getheader(fp, headaspect, (char *)&inpaspect); |
189 |
if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp)) |
190 |
goto readerr; |
191 |
pp[0].nd = 2; |
192 |
pp[0].dim[0].ne = inpres.yr; |
193 |
pp[0].dim[1].ne = inpres.xr; |
194 |
pp[0].dim[0].org = |
195 |
pp[0].dim[1].org = 0.0; |
196 |
if (inpres.xr <= inpres.yr*inpaspect) { |
197 |
pp[0].dim[0].siz = inpaspect * |
198 |
(double)inpres.yr/inpres.xr; |
199 |
pp[0].dim[1].siz = 1.0; |
200 |
} else { |
201 |
pp[0].dim[0].siz = 1.0; |
202 |
pp[0].dim[1].siz = (double)inpres.xr/inpres.yr / |
203 |
inpaspect; |
204 |
205 |
pp[0].dim[0].p = pp[0].dim[1].p = NULL; |
206 |
sl = scanlen(&inpres); /* allocate array */ |
207 |
ns = numscans(&inpres); |
208 |
i = ns*sl*sizeof(COLR); |
209 |
#if PSIZWARN |
210 |
if (i > PSIZWARN) { /* memory warning */ |
211 |
sprintf(errmsg, "picture file \"%s\" using %d bytes of memory", |
212 |
pname, i); |
213 |
error(WARNING, errmsg); |
214 |
215 |
#endif |
216 |
if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL) |
217 |
goto memerr; |
218 |
/* load picture */ |
219 |
if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL) |
220 |
goto memerr; |
221 |
for (y = 0; y < ns; y++) { |
222 |
if (freadcolrs(scanin, sl, fp) < 0) |
223 |
goto readerr; |
224 |
for (x = 0; x < sl; x++) { |
225 |
pix2loc(loc, &inpres, x, y); |
226 |
i = (int)(loc[1]*inpres.yr)*inpres.xr + |
227 |
(int)(loc[0]*inpres.xr); |
228 |
copycolr(pp[0].arr.c[i], scanin[x]); |
229 |
230 |
231 |
free((void *)scanin); |
232 |
fclose(fp); |
233 |
i = hash(pname); |
234 |
pp[0].next = dtab[i]; /* link into picture list */ |
235 |
copystruct(&pp[1], &pp[0]); |
236 |
copystruct(&pp[2], &pp[0]); |
237 |
pp[0].type = RED; /* differentiate RGB records */ |
238 |
pp[1].type = GRN; |
239 |
pp[2].type = BLU; |
240 |
return(dtab[i] = pp); |
241 |
242 |
memerr: |
243 |
error(SYSTEM, "out of memory in getpict"); |
244 |
readerr: |
245 |
sprintf(errmsg, "bad picture file \"%s\"", pfname); |
246 |
247 |
248 |
249 |
250 |
void |
251 |
freedata(dta) /* release data array reference */ |
252 |
DATARRAY *dta; |
253 |
254 |
DATARRAY head; |
255 |
int hval, nents; |
256 |
register DATARRAY *dpl, *dp; |
257 |
register int i; |
258 |
259 |
if (dta == NULL) { /* free all if NULL */ |
260 |
hval = 0; nents = TABSIZ; |
261 |
} else { |
262 |
hval = hash(dta->name); nents = 1; |
263 |
264 |
while (nents--) { |
265 |
head.next = dtab[hval]; |
266 |
dpl = &head; |
267 |
while ((dp = dpl->next) != NULL) |
268 |
if ((dta == NULL | dta == dp)) { |
269 |
dpl->next = dp->next; |
270 |
if (dp->type == DATATY) |
271 |
free((void *)dp->arr.d); |
272 |
else |
273 |
free((void *)dp->arr.c); |
274 |
for (i = 0; i < dp->nd; i++) |
275 |
if (dp->dim[i].p != NULL) |
276 |
free((void *)dp->dim[i].p); |
277 |
freestr(dp->name); |
278 |
free((void *)dp); |
279 |
} else |
280 |
dpl = dp; |
281 |
dtab[hval++] = head.next; |
282 |
283 |
284 |
285 |
286 |
double |
287 |
datavalue(dp, pt) /* interpolate data value at a point */ |
288 |
289 |
double *pt; |
290 |
291 |
DATARRAY sd; |
292 |
int asize; |
293 |
int lower, upper; |
294 |
register int i; |
295 |
double x, y0, y1; |
296 |
/* set up dimensions for recursion */ |
297 |
if (dp->nd > 1) { |
298 |
sd.name = dp->name; |
299 |
sd.type = dp->type; |
300 |
sd.nd = dp->nd - 1; |
301 |
asize = 1; |
302 |
for (i = 0; i < sd.nd; i++) { |
303 |
sd.dim[i].org = dp->dim[i+1].org; |
304 |
sd.dim[i].siz = dp->dim[i+1].siz; |
305 |
sd.dim[i].p = dp->dim[i+1].p; |
306 |
asize *= sd.dim[i].ne = dp->dim[i+1].ne; |
307 |
308 |
309 |
/* get independent variable */ |
310 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */ |
311 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; |
312 |
x *= (double)(dp->dim[0].ne - 1); |
313 |
i = x; |
314 |
if (i < 0) |
315 |
i = 0; |
316 |
else if (i > dp->dim[0].ne - 2) |
317 |
i = dp->dim[0].ne - 2; |
318 |
} else { /* unevenly spaced points */ |
319 |
if (dp->dim[0].siz > 0.0) { |
320 |
lower = 0; |
321 |
upper = dp->dim[0].ne; |
322 |
} else { |
323 |
lower = dp->dim[0].ne; |
324 |
upper = 0; |
325 |
326 |
do { |
327 |
i = (lower + upper) >> 1; |
328 |
if (pt[0] >= dp->dim[0].p[i]) |
329 |
lower = i; |
330 |
else |
331 |
upper = i; |
332 |
} while (i != (lower + upper) >> 1); |
333 |
334 |
335 |
x = i + (pt[0] - dp->dim[0].p[i]) / |
336 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]); |
337 |
338 |
/* get dependent variable */ |
339 |
if (dp->nd > 1) { |
340 |
if (dp->type == DATATY) { |
341 |
sd.arr.d = dp->arr.d + i*asize; |
342 |
y0 = datavalue(&sd, pt+1); |
343 |
sd.arr.d = dp->arr.d + (i+1)*asize; |
344 |
y1 = datavalue(&sd, pt+1); |
345 |
} else { |
346 |
sd.arr.c = dp->arr.c + i*asize; |
347 |
348 |
sd.arr.c = dp->arr.c + (i+1)*asize; |
349 |
350 |
351 |
} else { |
352 |
353 |
y0 = dp->arr.d[i]; |
354 |
y1 = dp->arr.d[i+1]; |
355 |
} else { |
356 |
y0 = colrval(dp->arr.c[i],dp->type); |
357 |
y1 = colrval(dp->arr.c[i+1],dp->type); |
358 |
359 |
360 |
361 |
* Extrapolate as far as one division, then |
362 |
* taper off harmonically to zero. |
363 |
364 |
if (x > i+2) |
365 |
return( (2*y1-y0)/(x-(i-1)) ); |
366 |
367 |
if (x < i-1) |
368 |
return( (2*y0-y1)/(i-x) ); |
369 |
370 |
return( y0*((i+1)-x) + y1*(x-i) ); |
371 |
