| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: data.c,v 2.34 2020/04/08 20:35:11 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* data.c - routines dealing with interpolated data.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <time.h>
| 11 |
| 12 |
#include "platform.h"
| 13 |
#include "paths.h"
| 14 |
#include "standard.h"
| 15 |
#include "color.h"
| 16 |
#include "resolu.h"
| 17 |
#include "view.h"
| 18 |
#include "data.h"
| 19 |
| 20 |
/* picture memory usage before warning */
| 21 |
#ifndef PSIZWARN
| 22 |
#ifdef SMLMEM
| 23 |
#define PSIZWARN 3000000
| 24 |
#else
| 25 |
#define PSIZWARN 50000000
| 26 |
#endif
| 27 |
#endif
| 28 |
| 29 |
#ifndef TABSIZ
| 30 |
#define TABSIZ 997 /* table size (prime) */
| 31 |
#endif
| 32 |
| 33 |
#define hash(s) (shash(s)%TABSIZ)
| 34 |
| 35 |
| 36 |
static DATARRAY *dtab[TABSIZ]; /* data array list */
| 37 |
| 38 |
static gethfunc headaspect;
| 39 |
| 40 |
| 41 |
DATARRAY *
| 42 |
getdata( /* get data array dname */
| 43 |
char *dname
| 44 |
| 45 |
| 46 |
char *dfname;
| 47 |
FILE *fp;
| 48 |
int asize=0;
| 49 |
int i, j;
| 50 |
DATARRAY *dp;
| 51 |
/* look for array in list */
| 52 |
for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
| 53 |
if (!strcmp(dname, dp->name))
| 54 |
return(dp); /* found! */
| 55 |
| 56 |
* If we haven't loaded the data already, we will look
| 57 |
* for it in the directories specified by the library path.
| 58 |
| 59 |
* The file has the following format:
| 60 |
| 61 |
* N
| 62 |
* beg0 end0 n0
| 63 |
* beg1 end1 n1
| 64 |
| 65 |
* begN endN nN
| 66 |
* data, later dimensions changing faster
| 67 |
| 68 |
| 69 |
* For irregularly spaced points, the following can be
| 70 |
* substituted for begi endi ni:
| 71 |
| 72 |
* 0 0 ni p0i p1i .. pni
| 73 |
| 74 |
| 75 |
if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) {
| 76 |
sprintf(errmsg, "cannot find data file \"%s\"", dname);
| 77 |
error(SYSTEM, errmsg);
| 78 |
| 79 |
if ((fp = fopen(dfname, "r")) == NULL) {
| 80 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname);
| 81 |
| 82 |
| 83 |
/* get dimensions */
| 84 |
if (fgetval(fp, 'i', (char *)&asize) <= 0)
| 85 |
goto scanerr;
| 86 |
if ((asize <= 0) | (asize > MAXDDIM)) {
| 87 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
| 88 |
error(USER, errmsg);
| 89 |
| 90 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
| 91 |
goto memerr;
| 92 |
dp->name = savestr(dname);
| 93 |
dp->type = DATATY;
| 94 |
dp->nd = asize;
| 95 |
asize = 1;
| 96 |
for (i = 0; i < dp->nd; i++) {
| 97 |
if (fgetval(fp, DATATY, (char *)&dp->dim[i].org) <= 0)
| 98 |
goto scanerr;
| 99 |
if (fgetval(fp, DATATY, (char *)&dp->dim[i].siz) <= 0)
| 100 |
goto scanerr;
| 101 |
if (fgetval(fp, 'i', (char *)&dp->dim[i].ne) <= 0)
| 102 |
goto scanerr;
| 103 |
if (dp->dim[i].ne < 2)
| 104 |
goto scanerr;
| 105 |
asize *= dp->dim[i].ne;
| 106 |
if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
| 107 |
dp->dim[i].p = (DATATYPE *)
| 108 |
malloc(dp->dim[i].ne*sizeof(DATATYPE));
| 109 |
if (dp->dim[i].p == NULL)
| 110 |
goto memerr;
| 111 |
for (j = 0; j < dp->dim[i].ne; j++)
| 112 |
| 113 |
(char *)&dp->dim[i].p[j]) <= 0)
| 114 |
goto scanerr;
| 115 |
for (j = 1; j < dp->dim[i].ne-1; j++)
| 116 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
| 117 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1]))
| 118 |
goto scanerr;
| 119 |
dp->dim[i].org = dp->dim[i].p[0];
| 120 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
| 121 |
- dp->dim[i].p[0];
| 122 |
} else
| 123 |
dp->dim[i].p = NULL;
| 124 |
| 125 |
if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
| 126 |
goto memerr;
| 127 |
| 128 |
for (i = 0; i < asize; i++)
| 129 |
if (fgetval(fp, DATATY, (char *)&dp->arr.d[i]) <= 0)
| 130 |
goto scanerr;
| 131 |
fclose(fp);
| 132 |
i = hash(dname);
| 133 |
dp->next = dtab[i];
| 134 |
return(dtab[i] = dp);
| 135 |
| 136 |
memerr:
| 137 |
error(SYSTEM, "out of memory in getdata");
| 138 |
scanerr:
| 139 |
sprintf(errmsg, "%s in data file \"%s\"",
| 140 |
feof(fp) ? "unexpected EOF" : "bad format", dfname);
| 141 |
| 142 |
return NULL; /* pro forma return */
| 143 |
| 144 |
| 145 |
| 146 |
static int
| 147 |
headaspect( /* check string for aspect ratio */
| 148 |
char *s,
| 149 |
void *iap
| 150 |
| 151 |
| 152 |
char fmt[MAXFMTLEN];
| 153 |
| 154 |
if (isaspect(s))
| 155 |
*(double*)iap *= aspectval(s);
| 156 |
else if (formatval(fmt, s) && !globmatch(PICFMT, fmt))
| 157 |
*(double*)iap = 0.0;
| 158 |
return(0);
| 159 |
| 160 |
| 161 |
| 162 |
DATARRAY *
| 163 |
getpict( /* get picture pname */
| 164 |
char *pname
| 165 |
| 166 |
| 167 |
double inpaspect;
| 168 |
char *pfname;
| 169 |
FILE *fp;
| 170 |
COLR *scanin;
| 171 |
int sl, ns;
| 172 |
RESOLU inpres;
| 173 |
RREAL loc[2];
| 174 |
int y;
| 175 |
int x, i;
| 176 |
DATARRAY *pp;
| 177 |
| 178 |
for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
| 179 |
if (!strcmp(pname, pp->name))
| 180 |
return(pp); /* found! */
| 181 |
| 182 |
if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) {
| 183 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname);
| 184 |
| 185 |
| 186 |
if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
| 187 |
goto memerr;
| 188 |
| 189 |
pp[0].name = savestr(pname);
| 190 |
| 191 |
if ((fp = fopen(pfname, "r")) == NULL) {
| 192 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
| 193 |
| 194 |
| 195 |
SET_FILE_BINARY(fp);
| 196 |
| 197 |
inpaspect = 1.0;
| 198 |
getheader(fp, headaspect, &inpaspect);
| 199 |
if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
| 200 |
goto readerr;
| 201 |
pp[0].nd = 2;
| 202 |
pp[0].dim[0].ne = inpres.yr;
| 203 |
pp[0].dim[1].ne = inpres.xr;
| 204 |
pp[0].dim[0].org =
| 205 |
pp[0].dim[1].org = 0.0;
| 206 |
if (inpres.xr <= inpres.yr*inpaspect) {
| 207 |
pp[0].dim[0].siz = inpaspect *
| 208 |
(double)inpres.yr/inpres.xr;
| 209 |
pp[0].dim[1].siz = 1.0;
| 210 |
} else {
| 211 |
pp[0].dim[0].siz = 1.0;
| 212 |
pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
| 213 |
inpaspect;
| 214 |
| 215 |
pp[0].dim[0].p = pp[0].dim[1].p = NULL;
| 216 |
sl = scanlen(&inpres); /* allocate array */
| 217 |
ns = numscans(&inpres);
| 218 |
i = ns*sl*sizeof(COLR);
| 219 |
#if PSIZWARN
| 220 |
if (i > PSIZWARN) { /* memory warning */
| 221 |
sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory",
| 222 |
pname, i*(1.0/(1024*1024)));
| 223 |
error(WARNING, errmsg);
| 224 |
| 225 |
#endif
| 226 |
if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
| 227 |
goto memerr;
| 228 |
/* load picture */
| 229 |
if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
| 230 |
goto memerr;
| 231 |
for (y = 0; y < ns; y++) {
| 232 |
if (freadcolrs(scanin, sl, fp) < 0)
| 233 |
goto readerr;
| 234 |
for (x = 0; x < sl; x++) {
| 235 |
pix2loc(loc, &inpres, x, y);
| 236 |
i = (int)(loc[1]*inpres.yr)*inpres.xr +
| 237 |
(int)(loc[0]*inpres.xr);
| 238 |
copycolr(pp[0].arr.c[i], scanin[x]);
| 239 |
| 240 |
| 241 |
free((void *)scanin);
| 242 |
fclose(fp);
| 243 |
i = hash(pname);
| 244 |
pp[0].next = dtab[i]; /* link into picture list */
| 245 |
pp[1] = pp[0];
| 246 |
pp[2] = pp[0];
| 247 |
pp[0].type = RED; /* differentiate RGB records */
| 248 |
pp[1].type = GRN;
| 249 |
pp[2].type = BLU;
| 250 |
return(dtab[i] = pp);
| 251 |
| 252 |
memerr:
| 253 |
error(SYSTEM, "out of memory in getpict");
| 254 |
readerr:
| 255 |
sprintf(errmsg, "bad picture file \"%s\"", pfname);
| 256 |
| 257 |
| 258 |
| 259 |
| 260 |
| 261 |
void
| 262 |
freedata( /* release data array reference */
| 263 |
DATARRAY *dta
| 264 |
| 265 |
| 266 |
DATARRAY head;
| 267 |
int hval, nents;
| 268 |
DATARRAY *dpl, *dp;
| 269 |
int i;
| 270 |
| 271 |
if (dta == NULL) { /* free all if NULL */
| 272 |
hval = 0; nents = TABSIZ;
| 273 |
} else {
| 274 |
hval = hash(dta->name); nents = 1;
| 275 |
| 276 |
while (nents--) {
| 277 |
head.next = dtab[hval];
| 278 |
dpl = &head;
| 279 |
while ((dp = dpl->next) != NULL)
| 280 |
if ((dta == NULL) | (dta == dp)) {
| 281 |
dpl->next = dp->next;
| 282 |
if (dp->type == DATATY)
| 283 |
free((void *)dp->arr.d);
| 284 |
else
| 285 |
free((void *)dp->arr.c);
| 286 |
| 287 |
if (dp->dim[i].p != NULL)
| 288 |
free((void *)dp->dim[i].p);
| 289 |
freestr(dp->name);
| 290 |
free((void *)dp);
| 291 |
} else
| 292 |
dpl = dp;
| 293 |
dtab[hval++] = head.next;
| 294 |
| 295 |
| 296 |
| 297 |
| 298 |
double
| 299 |
datavalue( /* interpolate data value at a point */
| 300 |
DATARRAY *dp,
| 301 |
double *pt
| 302 |
| 303 |
| 304 |
DATARRAY sd;
| 305 |
int asize;
| 306 |
int lower, upper;
| 307 |
int i;
| 308 |
double x, y0, y1;
| 309 |
/* set up dimensions for recursion */
| 310 |
if (dp->nd > 1) {
| 311 |
sd.name = dp->name;
| 312 |
sd.type = dp->type;
| 313 |
sd.nd = dp->nd - 1;
| 314 |
asize = 1;
| 315 |
for (i = 0; i < sd.nd; i++) {
| 316 |
sd.dim[i].org = dp->dim[i+1].org;
| 317 |
sd.dim[i].siz = dp->dim[i+1].siz;
| 318 |
sd.dim[i].p = dp->dim[i+1].p;
| 319 |
asize *= sd.dim[i].ne = dp->dim[i+1].ne;
| 320 |
| 321 |
| 322 |
/* get independent variable */
| 323 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */
| 324 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
| 325 |
x *= (double)(dp->dim[0].ne - 1);
| 326 |
i = x;
| 327 |
if (i < 0)
| 328 |
i = 0;
| 329 |
else if (i > dp->dim[0].ne - 2)
| 330 |
i = dp->dim[0].ne - 2;
| 331 |
} else { /* unevenly spaced points */
| 332 |
if (dp->dim[0].siz > 0.0) {
| 333 |
lower = 0;
| 334 |
upper = dp->dim[0].ne;
| 335 |
} else {
| 336 |
lower = dp->dim[0].ne;
| 337 |
upper = 0;
| 338 |
| 339 |
do {
| 340 |
i = (lower + upper) >> 1;
| 341 |
if (pt[0] >= dp->dim[0].p[i])
| 342 |
lower = i;
| 343 |
else
| 344 |
upper = i;
| 345 |
} while (i != (lower + upper) >> 1);
| 346 |
| 347 |
| 348 |
x = i + (pt[0] - dp->dim[0].p[i]) /
| 349 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]);
| 350 |
| 351 |
/* get dependent variable */
| 352 |
if (dp->nd > 1) {
| 353 |
if (dp->type == DATATY) {
| 354 |
sd.arr.d = dp->arr.d + i*asize;
| 355 |
y0 = datavalue(&sd, pt+1);
| 356 |
sd.arr.d = dp->arr.d + (i+1)*asize;
| 357 |
y1 = datavalue(&sd, pt+1);
| 358 |
} else {
| 359 |
sd.arr.c = dp->arr.c + i*asize;
| 360 |
| 361 |
sd.arr.c = dp->arr.c + (i+1)*asize;
| 362 |
| 363 |
| 364 |
} else {
| 365 |
| 366 |
y0 = dp->arr.d[i];
| 367 |
y1 = dp->arr.d[i+1];
| 368 |
} else {
| 369 |
y0 = colrval(dp->arr.c[i],dp->type);
| 370 |
y1 = colrval(dp->arr.c[i+1],dp->type);
| 371 |
| 372 |
| 373 |
| 374 |
* Extrapolate as far as one division, then
| 375 |
* taper off harmonically to zero.
| 376 |
| 377 |
if (x > i+2)
| 378 |
return( (2*y1-y0)/(x-(i-1)) );
| 379 |
| 380 |
if (x < i-1)
| 381 |
return( (2*y0-y1)/(i-x) );
| 382 |
| 383 |
return( y0*((i+1)-x) + y1*(x-i) );
| 384 |
