1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* data.c - routines dealing with interpolated data. |
9 |
10 |
* 6/4/86 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "color.h" |
16 |
17 |
#include "data.h" |
18 |
19 |
20 |
extern char *fgetword(); |
21 |
extern double atof(); |
22 |
23 |
extern char *libpath; /* library search path */ |
24 |
25 |
static DATARRAY *dlist = NULL; /* data array list */ |
26 |
27 |
static DATARRAY *plist = NULL; /* picture list */ |
28 |
29 |
30 |
DATARRAY * |
31 |
getdata(dname) /* get data array dname */ |
32 |
char *dname; |
33 |
34 |
char word[64]; |
35 |
char *dfname; |
36 |
FILE *fp; |
37 |
int asize; |
38 |
register int i, j; |
39 |
register DATARRAY *dp; |
40 |
/* look for array in list */ |
41 |
for (dp = dlist; dp != NULL; dp = dp->next) |
42 |
if (!strcmp(dname, dp->name)) |
43 |
return(dp); /* found! */ |
44 |
45 |
46 |
* If we haven't loaded the data already, we will look |
47 |
* for it in the directorys specified by the library path. |
48 |
49 |
* The file has the following format: |
50 |
51 |
* N |
52 |
* beg0 end0 n0 |
53 |
* beg1 end1 n1 |
54 |
55 |
* begN endN nN |
56 |
* data, later dimensions changing faster |
57 |
58 |
59 |
* For irregularly spaced points, the following can be |
60 |
* substituted for begi endi ni: |
61 |
62 |
* 0 0 ni p0i p1i .. pni |
63 |
64 |
65 |
if ((dfname = getpath(dname, libpath, R_OK)) == NULL) { |
66 |
sprintf(errmsg, "cannot find data file \"%s\"", dname); |
67 |
error(USER, errmsg); |
68 |
69 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL) |
70 |
goto memerr; |
71 |
72 |
dp->name = savestr(dname); |
73 |
74 |
if ((fp = fopen(dfname, "r")) == NULL) { |
75 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname); |
76 |
error(SYSTEM, errmsg); |
77 |
78 |
/* get dimensions */ |
79 |
if (fgetword(word, sizeof(word), fp) == NULL || !isint(word)) |
80 |
goto scanerr; |
81 |
dp->nd = atoi(word); |
82 |
if (dp->nd <= 0 || dp->nd > MAXDDIM) { |
83 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname); |
84 |
85 |
86 |
asize = 1; |
87 |
for (i = 0; i < dp->nd; i++) { |
88 |
if (fgetword(word, sizeof(word), fp) == NULL || !isflt(word)) |
89 |
goto scanerr; |
90 |
dp->dim[i].org = atof(word); |
91 |
92 |
goto scanerr; |
93 |
dp->dim[i].siz = atof(word); |
94 |
95 |
goto scanerr; |
96 |
dp->dim[i].ne = atoi(word); |
97 |
if (dp->dim[i].ne < 2) |
98 |
goto scanerr; |
99 |
asize *= dp->dim[i].ne; |
100 |
if ((dp->dim[i].siz -= dp->dim[i].org) == 0) { |
101 |
dp->dim[i].p = (double *)malloc(dp->dim[i].ne*sizeof(double)); |
102 |
if (dp->dim[i].p == NULL) |
103 |
goto memerr; |
104 |
for (j = 0; j < dp->dim[i].ne; j++) { |
105 |
if (fgetword(word, sizeof(word), fp) == NULL || |
106 |
!isflt(word)) |
107 |
goto scanerr; |
108 |
dp->dim[i].p[j] = atof(word); |
109 |
110 |
for (j = 1; j < dp->dim[i].ne-1; j++) |
111 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) != |
112 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1])) |
113 |
goto scanerr; |
114 |
dp->dim[i].org = dp->dim[i].p[0]; |
115 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1] |
116 |
- dp->dim[i].p[0]; |
117 |
} else |
118 |
dp->dim[i].p = NULL; |
119 |
120 |
if ((dp->arr = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL) |
121 |
goto memerr; |
122 |
123 |
for (i = 0; i < asize; i++) { |
124 |
125 |
goto scanerr; |
126 |
dp->arr[i] = atof(word); |
127 |
128 |
fclose(fp); |
129 |
dp->next = dlist; |
130 |
return(dlist = dp); |
131 |
132 |
memerr: |
133 |
error(SYSTEM, "out of memory in getdata"); |
134 |
scanerr: |
135 |
sprintf(errmsg, "%s in data file \"%s\"", |
136 |
feof(fp) ? "unexpected EOF" : "bad format", dfname); |
137 |
138 |
139 |
140 |
141 |
static double inpaspect; /* aspect ratio of input picture */ |
142 |
143 |
static |
144 |
headaspect(s) /* check string for aspect ratio */ |
145 |
char *s; |
146 |
147 |
if (isaspect(s)) |
148 |
inpaspect *= aspectval(s); |
149 |
150 |
151 |
152 |
DATARRAY * |
153 |
getpict(pname) /* get picture pname */ |
154 |
char *pname; |
155 |
156 |
extern char *libpath; |
157 |
char *pfname; |
158 |
FILE *fp; |
159 |
COLOR *scanin; |
160 |
int width, height; |
161 |
int x, y; |
162 |
register int i; |
163 |
register DATARRAY *pp; |
164 |
165 |
for (pp = plist; pp != NULL; pp = pp->next) |
166 |
if (!strcmp(pname, pp->name)) |
167 |
return(pp); /* found! */ |
168 |
169 |
if ((pfname = getpath(pname, libpath, R_OK)) == NULL) { |
170 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname); |
171 |
172 |
173 |
if ((pp = (DATARRAY *)calloc(3, sizeof(DATARRAY))) == NULL) |
174 |
goto memerr; |
175 |
176 |
pp[0].name = |
177 |
pp[1].name = |
178 |
pp[2].name = savestr(pname); |
179 |
180 |
if ((fp = fopen(pfname, "r")) == NULL) { |
181 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname); |
182 |
183 |
184 |
185 |
inpaspect = 1.0; |
186 |
getheader(fp, headaspect); |
187 |
if (fgetresolu(&width, &height, fp) != (YMAJOR|YDECR)) |
188 |
goto readerr; |
189 |
for (i = 0; i < 3; i++) { |
190 |
pp[i].nd = 2; |
191 |
pp[i].dim[0].ne = height; |
192 |
pp[i].dim[1].ne = width; |
193 |
pp[i].dim[0].org = |
194 |
pp[i].dim[1].org = 0.0; |
195 |
if (width <= height*inpaspect) { |
196 |
pp[i].dim[0].siz = inpaspect*(double)height/width; |
197 |
pp[i].dim[1].siz = 1.0; |
198 |
} else { |
199 |
pp[i].dim[0].siz = 1.0; |
200 |
pp[i].dim[1].siz = (double)width/height/inpaspect; |
201 |
202 |
pp[i].dim[0].p = pp[i].dim[1].p = NULL; |
203 |
pp[i].arr = (DATATYPE *)malloc(width*height*sizeof(DATATYPE)); |
204 |
if (pp[i].arr == NULL) |
205 |
goto memerr; |
206 |
207 |
/* load picture */ |
208 |
if ((scanin = (COLOR *)malloc(width*sizeof(COLOR))) == NULL) |
209 |
goto memerr; |
210 |
for (y = height-1; y >= 0; y--) { |
211 |
if (freadscan(scanin, width, fp) < 0) |
212 |
goto readerr; |
213 |
for (x = 0; x < width; x++) |
214 |
for (i = 0; i < 3; i++) |
215 |
pp[i].arr[y*width+x] = colval(scanin[x],i); |
216 |
217 |
free((char *)scanin); |
218 |
fclose(fp); |
219 |
pp[0].next = |
220 |
pp[1].next = |
221 |
pp[2].next = plist; |
222 |
return(plist = pp); |
223 |
224 |
memerr: |
225 |
error(SYSTEM, "out of memory in getpict"); |
226 |
readerr: |
227 |
sprintf(errmsg, "bad picture file \"%s\"", pfname); |
228 |
229 |
230 |
231 |
232 |
freedata(dname) /* free memory associated with dname */ |
233 |
char *dname; |
234 |
235 |
register DATARRAY *dp, *dpl; |
236 |
register int i; |
237 |
238 |
for (dpl = NULL, dp = dlist; dp != NULL; dpl = dp, dp = dp->next) |
239 |
if (!strcmp(dname, dp->name)) { |
240 |
if (dpl == NULL) |
241 |
dlist = dp->next; |
242 |
else |
243 |
dpl->next = dp->next; |
244 |
free((char *)dp->arr); |
245 |
for (i = 0; i < dp->nd; i++) |
246 |
if (dp->dim[i].p != NULL) |
247 |
free((char *)dp->dim[i].p); |
248 |
freestr(dp->name); |
249 |
free((char *)dp); |
250 |
return; |
251 |
252 |
253 |
254 |
255 |
freepict(pname) /* free memory associated with pname */ |
256 |
char *pname; |
257 |
258 |
register DATARRAY *pp, *ppl; |
259 |
260 |
for (ppl = NULL, pp = plist; pp != NULL; ppl = pp, pp = pp->next) |
261 |
if (!strcmp(pname, pp->name)) { |
262 |
if (ppl == NULL) |
263 |
plist = pp->next; |
264 |
else |
265 |
ppl->next = pp->next; |
266 |
free((char *)pp[0].arr); |
267 |
free((char *)pp[1].arr); |
268 |
free((char *)pp[2].arr); |
269 |
freestr(pp[0].name); |
270 |
free((char *)pp); |
271 |
return; |
272 |
273 |
274 |
275 |
276 |
double |
277 |
datavalue(dp, pt) /* interpolate data value at a point */ |
278 |
279 |
double *pt; |
280 |
281 |
DATARRAY sd; |
282 |
int asize; |
283 |
int lower, upper; |
284 |
register int i; |
285 |
double x, y, y0, y1; |
286 |
/* set up dimensions for recursion */ |
287 |
sd.nd = dp->nd - 1; |
288 |
asize = 1; |
289 |
for (i = 0; i < sd.nd; i++) { |
290 |
sd.dim[i].org = dp->dim[i+1].org; |
291 |
sd.dim[i].siz = dp->dim[i+1].siz; |
292 |
sd.dim[i].p = dp->dim[i+1].p; |
293 |
asize *= sd.dim[i].ne = dp->dim[i+1].ne; |
294 |
295 |
/* get independent variable */ |
296 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */ |
297 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; |
298 |
x = x * (dp->dim[0].ne - 1); |
299 |
i = x; |
300 |
if (i < 0) |
301 |
i = 0; |
302 |
else if (i > dp->dim[0].ne - 2) |
303 |
i = dp->dim[0].ne - 2; |
304 |
} else { /* unevenly spaced points */ |
305 |
if (dp->dim[0].siz > 0.0) { |
306 |
lower = 0; |
307 |
upper = dp->dim[0].ne; |
308 |
} else { |
309 |
lower = dp->dim[0].ne; |
310 |
upper = 0; |
311 |
312 |
do { |
313 |
i = (lower + upper) >> 1; |
314 |
if (pt[0] >= dp->dim[0].p[i]) |
315 |
lower = i; |
316 |
else |
317 |
upper = i; |
318 |
} while (i != (lower + upper) >> 1); |
319 |
320 |
321 |
x = i + (pt[0] - dp->dim[0].p[i]) / |
322 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]); |
323 |
324 |
/* get dependent variable */ |
325 |
if (dp->nd == 1) { |
326 |
y0 = dp->arr[i]; |
327 |
y1 = dp->arr[i+1]; |
328 |
} else { |
329 |
sd.arr = &dp->arr[i*asize]; |
330 |
y0 = datavalue(&sd, pt+1); |
331 |
sd.arr = &dp->arr[(i+1)*asize]; |
332 |
y1 = datavalue(&sd, pt+1); |
333 |
334 |
335 |
* Extrapolate as far as one division, then |
336 |
* taper off harmonically to zero. |
337 |
338 |
if (x > i+2) |
339 |
y = (2*y1-y0)/(x-i-1); |
340 |
else if (x < i-1) |
341 |
y = (2*y0-y1)/(i-x); |
342 |
else |
343 |
y = y0*((i+1)-x) + y1*(x-i); |
344 |
345 |
return(y); |
346 |
