Increased memory amount for warning and changed to MBytes report
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Minor compile fixes
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed getheader() to pay attention to function return value
increased PSIZWARN definitions
made pictures use RGBE storage r.t. float reduced MAXDDIM to 5
bug fix from adding comments to data files
added comments to data files using new fgetval() function
minor grooming of datavalue()
added warning for pictures using more than PSIZWARN bytes memory
finally moved to hash-table lookup of data file entries
added global freeing routines
fixed call to getheader() to pass 3 arguments always (DOS bug fix)
Changes for PC port
removed atof() declarations for NeXT
got rid of scanf() calls
changed MAXDIM to MAXDDIM to avoid conflict
eliminated unnecessary tests for unevenly spaced data points
changed y to be first dimension in picture
Changed format for uneven point data and used binary search
Added check for pixel aspect ratio in getpict()
Added capability for unevenly spaced points
added calls to picture resolution get/put routines
Changed getpath to check permissions
