| 1 |
/* Copyright (c) 1986 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* data.c - routines dealing with interpolated data.
| 9 |
| 10 |
* 6/4/86
| 11 |
| 12 |
| 13 |
#include "standard.h"
| 14 |
| 15 |
#include "color.h"
| 16 |
| 17 |
#include "data.h"
| 18 |
| 19 |
| 20 |
extern char *libpath; /* library search path */
| 21 |
| 22 |
static DATARRAY *dlist = NULL; /* data array list */
| 23 |
| 24 |
static DATARRAY *plist = NULL; /* picture list */
| 25 |
| 26 |
| 27 |
DATARRAY *
| 28 |
getdata(dname) /* get data array dname */
| 29 |
char *dname;
| 30 |
| 31 |
char *dfname;
| 32 |
FILE *fp;
| 33 |
int asize;
| 34 |
register int i, j;
| 35 |
register DATARRAY *dp;
| 36 |
/* look for array in list */
| 37 |
for (dp = dlist; dp != NULL; dp = dp->next)
| 38 |
if (!strcmp(dname, dp->name))
| 39 |
return(dp); /* found! */
| 40 |
| 41 |
| 42 |
* If we haven't loaded the data already, we will look
| 43 |
* for it in the directorys specified by the library path.
| 44 |
| 45 |
* The file has the following format:
| 46 |
| 47 |
* N
| 48 |
* beg0 end0 n0
| 49 |
* beg1 end1 n1
| 50 |
| 51 |
* begN endN nN
| 52 |
* data, later dimensions changing faster
| 53 |
| 54 |
| 55 |
* For irregularly spaced points, the following can be
| 56 |
* substituted for begi endi ni:
| 57 |
| 58 |
* @ ni p0i p1i .. pni
| 59 |
| 60 |
| 61 |
if ((dfname = getpath(dname, libpath, R_OK)) == NULL) {
| 62 |
sprintf(errmsg, "cannot find data file \"%s\"", dname);
| 63 |
error(USER, errmsg);
| 64 |
| 65 |
if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
| 66 |
goto memerr;
| 67 |
| 68 |
dp->name = savestr(dname);
| 69 |
| 70 |
if ((fp = fopen(dfname, "r")) == NULL) {
| 71 |
sprintf(errmsg, "cannot open data file \"%s\"", dfname);
| 72 |
error(SYSTEM, errmsg);
| 73 |
| 74 |
/* get dimensions */
| 75 |
if (fscanf(fp, "%d", &dp->nd) != 1)
| 76 |
goto scanerr;
| 77 |
if (dp->nd <= 0 || dp->nd > MAXDIM) {
| 78 |
sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
| 79 |
| 80 |
| 81 |
asize = 1;
| 82 |
for (i = 0; i < dp->nd; i++) {
| 83 |
if (fscanf(fp, "%lf %lf %d",
| 84 |
&dp->dim[i].org, &dp->dim[i].siz,
| 85 |
&dp->dim[i].ne) == 3) {
| 86 |
dp->dim[i].siz -= dp->dim[i].org;
| 87 |
dp->dim[i].p = NULL;
| 88 |
} else if (fscanf(fp, "@ %d", &dp->dim[i].ne) == 1) {
| 89 |
dp->dim[i].p = (double *)malloc(dp->dim[i].ne*sizeof(double));
| 90 |
if (dp->dim[i].p == NULL)
| 91 |
goto memerr;
| 92 |
for (j = 0; j < dp->dim[i].ne; j++)
| 93 |
if (fscanf(fp, "%lf", &dp->dim[i].p[j]) != 1)
| 94 |
goto scanerr;
| 95 |
for (j = 1; j < dp->dim[i].ne-1; j++)
| 96 |
if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
| 97 |
(dp->dim[i].p[j] < dp->dim[i].p[j+1]))
| 98 |
goto scanerr;
| 99 |
dp->dim[i].org = dp->dim[i].p[0];
| 100 |
dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
| 101 |
- dp->dim[i].p[0];
| 102 |
} else
| 103 |
goto scanerr;
| 104 |
if (dp->dim[i].siz == 0.0 || dp->dim[i].ne < 2)
| 105 |
goto scanerr;
| 106 |
asize *= dp->dim[i].ne;
| 107 |
| 108 |
if ((dp->arr = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
| 109 |
goto memerr;
| 110 |
| 111 |
for (i = 0; i < asize; i++)
| 112 |
if (fscanf(fp, DSCANF, &dp->arr[i]) != 1)
| 113 |
goto scanerr;
| 114 |
| 115 |
fclose(fp);
| 116 |
dp->next = dlist;
| 117 |
return(dlist = dp);
| 118 |
| 119 |
memerr:
| 120 |
error(SYSTEM, "out of memory in getdata");
| 121 |
scanerr:
| 122 |
sprintf(errmsg, "%s in data file \"%s\"",
| 123 |
feof(fp) ? "unexpected EOF" : "bad format", dfname);
| 124 |
| 125 |
| 126 |
| 127 |
| 128 |
static double inpaspect; /* aspect ratio of input picture */
| 129 |
| 130 |
static
| 131 |
headaspect(s) /* check string for aspect ratio */
| 132 |
char *s;
| 133 |
| 134 |
if (isaspect(s))
| 135 |
inpaspect *= aspectval(s);
| 136 |
| 137 |
| 138 |
| 139 |
DATARRAY *
| 140 |
getpict(pname) /* get picture pname */
| 141 |
char *pname;
| 142 |
| 143 |
| 144 |
char *pfname;
| 145 |
FILE *fp;
| 146 |
COLOR *scanin;
| 147 |
int width, height;
| 148 |
int x, y;
| 149 |
register int i;
| 150 |
register DATARRAY *pp;
| 151 |
| 152 |
for (pp = plist; pp != NULL; pp = pp->next)
| 153 |
if (!strcmp(pname, pp->name))
| 154 |
return(pp); /* found! */
| 155 |
| 156 |
if ((pfname = getpath(pname, libpath, R_OK)) == NULL) {
| 157 |
sprintf(errmsg, "cannot find picture file \"%s\"", pname);
| 158 |
| 159 |
| 160 |
if ((pp = (DATARRAY *)calloc(3, sizeof(DATARRAY))) == NULL)
| 161 |
goto memerr;
| 162 |
| 163 |
pp[0].name =
| 164 |
pp[1].name =
| 165 |
pp[2].name = savestr(pname);
| 166 |
| 167 |
if ((fp = fopen(pfname, "r")) == NULL) {
| 168 |
sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
| 169 |
| 170 |
| 171 |
| 172 |
inpaspect = 1.0;
| 173 |
getheader(fp, headaspect);
| 174 |
if (fgetresolu(&width, &height, fp) != (YMAJOR|YDECR))
| 175 |
goto readerr;
| 176 |
for (i = 0; i < 3; i++) {
| 177 |
pp[i].nd = 2;
| 178 |
pp[i].dim[0].ne = width;
| 179 |
pp[i].dim[1].ne = height;
| 180 |
pp[i].dim[0].org =
| 181 |
pp[i].dim[1].org = 0.0;
| 182 |
if (width <= height*inpaspect) {
| 183 |
pp[i].dim[0].siz = 1.0;
| 184 |
pp[i].dim[1].siz = inpaspect*(double)height/width;
| 185 |
} else {
| 186 |
pp[i].dim[0].siz = (double)width/height/inpaspect;
| 187 |
pp[i].dim[1].siz = 1.0;
| 188 |
| 189 |
pp[i].arr = (DATATYPE *)malloc(width*height*sizeof(DATATYPE));
| 190 |
if (pp[i].arr == NULL)
| 191 |
goto memerr;
| 192 |
| 193 |
/* load picture */
| 194 |
if ((scanin = (COLOR *)malloc(width*sizeof(COLOR))) == NULL)
| 195 |
goto memerr;
| 196 |
for (y = height-1; y >= 0; y--) {
| 197 |
if (freadscan(scanin, width, fp) < 0)
| 198 |
goto readerr;
| 199 |
for (x = 0; x < width; x++)
| 200 |
| 201 |
pp[i].arr[x*height+y] = colval(scanin[x],i);
| 202 |
| 203 |
free((char *)scanin);
| 204 |
fclose(fp);
| 205 |
pp[0].next =
| 206 |
pp[1].next =
| 207 |
pp[2].next = plist;
| 208 |
return(plist = pp);
| 209 |
| 210 |
memerr:
| 211 |
error(SYSTEM, "out of memory in getpict");
| 212 |
readerr:
| 213 |
sprintf(errmsg, "bad picture file \"%s\"", pfname);
| 214 |
| 215 |
| 216 |
| 217 |
| 218 |
freedata(dname) /* free memory associated with dname */
| 219 |
char *dname;
| 220 |
| 221 |
register DATARRAY *dp, *dpl;
| 222 |
register int i;
| 223 |
| 224 |
for (dpl = NULL, dp = dlist; dp != NULL; dpl = dp, dp = dp->next)
| 225 |
if (!strcmp(dname, dp->name)) {
| 226 |
if (dpl == NULL)
| 227 |
dlist = dp->next;
| 228 |
else
| 229 |
dpl->next = dp->next;
| 230 |
free((char *)dp->arr);
| 231 |
| 232 |
if (dp->dim[i].p != NULL)
| 233 |
free((char *)dp->dim[i].p);
| 234 |
freestr(dp->name);
| 235 |
free((char *)dp);
| 236 |
return;
| 237 |
| 238 |
| 239 |
| 240 |
| 241 |
freepict(pname) /* free memory associated with pname */
| 242 |
char *pname;
| 243 |
| 244 |
register DATARRAY *pp, *ppl;
| 245 |
| 246 |
for (ppl = NULL, pp = plist; pp != NULL; ppl = pp, pp = pp->next)
| 247 |
if (!strcmp(pname, pp->name)) {
| 248 |
if (ppl == NULL)
| 249 |
plist = pp->next;
| 250 |
else
| 251 |
ppl->next = pp->next;
| 252 |
free((char *)pp[0].arr);
| 253 |
free((char *)pp[1].arr);
| 254 |
free((char *)pp[2].arr);
| 255 |
freestr(pp[0].name);
| 256 |
free((char *)pp);
| 257 |
return;
| 258 |
| 259 |
| 260 |
| 261 |
| 262 |
double
| 263 |
datavalue(dp, pt) /* interpolate data value at a point */
| 264 |
| 265 |
double *pt;
| 266 |
| 267 |
DATARRAY sd;
| 268 |
int asize;
| 269 |
register int i;
| 270 |
double x, y, y0, y1;
| 271 |
/* set up dimensions for recursion */
| 272 |
sd.nd = dp->nd - 1;
| 273 |
asize = 1;
| 274 |
for (i = 0; i < sd.nd; i++) {
| 275 |
sd.dim[i].org = dp->dim[i+1].org;
| 276 |
sd.dim[i].siz = dp->dim[i+1].siz;
| 277 |
sd.dim[i].p = dp->dim[i+1].p;
| 278 |
asize *= sd.dim[i].ne = dp->dim[i+1].ne;
| 279 |
| 280 |
/* get independent variable */
| 281 |
if (dp->dim[0].p == NULL) { /* evenly spaced points */
| 282 |
x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
| 283 |
x = x * (dp->dim[0].ne - 1);
| 284 |
i = x;
| 285 |
if (i < 0)
| 286 |
i = 0;
| 287 |
else if (i > dp->dim[0].ne - 2)
| 288 |
i = dp->dim[0].ne - 2;
| 289 |
} else { /* unevenly spaced points */
| 290 |
if (dp->dim[0].siz > 0.0)
| 291 |
for (i = 0; i < dp->dim[0].ne; i++)
| 292 |
if (pt[0] < dp->dim[0].p[i])
| 293 |
break;
| 294 |
else
| 295 |
| 296 |
if (pt[0] >= dp->dim[0].p[i])
| 297 |
break;
| 298 |
if (i <= 0)
| 299 |
i = 0;
| 300 |
else if (i >= dp->dim[0].ne)
| 301 |
| 302 |
else
| 303 |
i--;
| 304 |
x = i + (pt[0] - dp->dim[0].p[i]) /
| 305 |
(dp->dim[0].p[i+1] - dp->dim[0].p[i]);
| 306 |
| 307 |
/* get dependent variable */
| 308 |
if (dp->nd == 1) {
| 309 |
y0 = dp->arr[i];
| 310 |
y1 = dp->arr[i+1];
| 311 |
} else {
| 312 |
sd.arr = &dp->arr[i*asize];
| 313 |
y0 = datavalue(&sd, pt+1);
| 314 |
sd.arr = &dp->arr[(i+1)*asize];
| 315 |
y1 = datavalue(&sd, pt+1);
| 316 |
| 317 |
| 318 |
* Extrapolate as far as one division, then
| 319 |
* taper off harmonically to zero.
| 320 |
| 321 |
if (x > i+2)
| 322 |
y = (2*y1-y0)/(x-i-1);
| 323 |
else if (x < i-1)
| 324 |
y = (2*y0-y1)/(i-x);
| 325 |
else
| 326 |
y = y0*((i+1)-x) + y1*(x-i);
| 327 |
| 328 |
return(y);
| 329 |
