root/Development/ray/src/rt/data.c
Tue May 12 16:37:53 2009 UTC (16 years, 7 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 2.28: +5 -5 lines
Diff to previous 2.28 , to selected 2.27
Increased memory amount for warning and changed to MBytes report
Sat Oct 23 18:55:52 2004 UTC (21 years, 2 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9
Changes since 2.27: +2 -1 lines
Diff to previous 2.27
Revision 2.27 - (view) (download) (annotate) - [selected]
Tue Mar 30 16:13:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.26: +21 -14 lines
Diff to previous 2.26
Fri Jan 2 11:43:42 2004 UTC (22 years ago) by schorsch
Changes since 2.25: +10 -7 lines
Diff to previous 2.25 , to selected 2.27
Wed Oct 22 02:06:35 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.24 , to selected 2.27
Sun Jul 27 22:12:03 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.23 , to selected 2.27
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.22 , to selected 2.27
Wed Jul 16 01:32:53 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21 , to selected 2.27
Minor compile fixes
Thu Jun 26 00:58:10 2003 UTC (22 years, 6 months ago) by schorsch
Diff to previous 2.20 , to selected 2.27
Sun Jun 8 12:03:10 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 2.19: +2 -1 lines
Diff to previous 2.19 , to selected 2.27
Thu Jun 5 19:29:34 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 2.18: +2 -7 lines
Diff to previous 2.18 , to selected 2.27
Thu May 15 05:13:35 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.17 , to selected 2.27
Tue May 13 17:58:33 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.16 , to selected 2.27
Tue Feb 25 02:47:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.15: +1 -56 lines
Diff to previous 2.15 , to selected 2.27
Sat Feb 22 02:07:28 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.14: +80 -27 lines
Diff to previous 2.14 , to selected 2.27
Thu Nov 5 17:11:56 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.13: +6 -1 lines
Diff to previous 2.13 , to selected 2.27
changed getheader() to pay attention to function return value
Wed Dec 3 11:06:17 1997 UTC (28 years, 1 month ago) by gregl
Diff to previous 2.12 , to selected 2.27
increased PSIZWARN definitions
Thu Feb 15 18:46:54 1996 UTC (29 years, 10 months ago) by greg
Changes since 2.11: +84 -104 lines
Diff to previous 2.11 , to selected 2.27
made pictures use RGBE storage r.t. float
reduced MAXDDIM to 5
Tue Aug 22 08:51:57 1995 UTC (30 years, 4 months ago) by greg
Diff to previous 2.10 , to selected 2.27
bug fix from adding comments to data files
Fri Jun 30 16:07:44 1995 UTC (30 years, 6 months ago) by greg
Changes since 2.9: +8 -20 lines
Diff to previous 2.9 , to selected 2.27
added comments to data files using new fgetval() function
Fri May 13 13:05:13 1994 UTC (31 years, 7 months ago) by greg
Changes since 2.8: +7 -8 lines
Diff to previous 2.8 , to selected 2.27
minor grooming of datavalue()
Thu Apr 14 04:50:27 1994 UTC (31 years, 8 months ago) by greg
Changes since 2.7: +3 -4 lines
Diff to previous 2.7 , to selected 2.27
Mon Feb 8 13:12:28 1993 UTC (32 years, 11 months ago) by greg
Changes since 2.6: +20 -1 lines
Diff to previous 2.6 , to selected 2.27
added warning for pictures using more than PSIZWARN bytes memory
Sun Nov 22 10:47:51 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.5: +58 -35 lines
Diff to previous 2.5 , to selected 2.27
finally moved to hash-table lookup of data file entries
Sun Nov 22 10:02:57 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.4: +19 -17 lines
Diff to previous 2.4 , to selected 2.27
added global freeing routines
Thu Nov 12 10:11:51 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.3: +5 -5 lines
Diff to previous 2.3 , to selected 2.27
fixed call to getheader() to pass 3 arguments always (DOS bug fix)
Mon Sep 21 12:07:42 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.2: +9 -6 lines
Diff to previous 2.2 , to selected 2.27
Changes for PC port
Thu Dec 19 14:54:58 1991 UTC (34 years ago) by greg
Diff to previous 2.1 , to selected 2.27
removed atof() declarations for NeXT
Tue Nov 12 17:10:07 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.11 , to selected 2.27
Mon Nov 11 14:02:43 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.10: +30 -16 lines
Diff to previous 1.10 , to selected 2.27
Mon Jul 22 13:02:24 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.9: +23 -9 lines
Diff to previous 1.9 , to selected 2.27
got rid of scanf() calls
Thu May 23 08:14:57 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 2.27
changed MAXDIM to MAXDDIM to avoid conflict
Tue Jan 15 22:24:19 1991 UTC (34 years, 11 months ago) by greg
Changes since 1.7: +3 -5 lines
Diff to previous 1.7 , to selected 2.27
eliminated unnecessary tests for unevenly spaced data points
Tue May 8 10:37:57 1990 UTC (35 years, 8 months ago) by greg
Changes since 1.6: +8 -7 lines
Diff to previous 1.6 , to selected 2.27
changed y to be first dimension in picture
Fri Apr 6 14:12:21 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.5: +25 -21 lines
Diff to previous 1.5 , to selected 2.27
Changed format for uneven point data and used binary search
Tue Apr 3 17:48:46 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.4: +16 -4 lines
Diff to previous 1.4 , to selected 2.27
Added check for pixel aspect ratio in getpict()
Tue Apr 3 17:24:35 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.3: +61 -17 lines
Diff to previous 1.3 , to selected 2.27
Added capability for unevenly spaced points
Tue Sep 12 12:26:14 1989 UTC (36 years, 3 months ago) by greg
Diff to previous 1.2 , to selected 2.27
added calls to picture resolution get/put routines
Thu Jul 27 22:25:10 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.1 , to selected 2.27
Changed getpath to check permissions
Thu Feb 2 10:41:18 1989 UTC (36 years, 11 months ago) by greg
Diff to selected 2.27
