root/radiance/ray/src/rt/data.c
Revision: 1.2
Committed: Thu Jul 27 22:25:10 1989 UTC (35 years, 9 months ago) by greg
Changed getpath to check permissions
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * data.c - routines dealing with interpolated data.
9 *
10 * 6/4/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "data.h"
18
19
20 extern char *libpath; /* library search path */
21
22 static DATARRAY *dlist = NULL; /* data array list */
23
24 static DATARRAY *plist = NULL; /* picture list */
25
26
27 DATARRAY *
28 getdata(dname) /* get data array dname */
29 char *dname;
30 {
31 char *dfname;
32 FILE *fp;
33 int asize;
34 register int i;
35 register DATARRAY *dp;
36 /* look for array in list */
37 for (dp = dlist; dp != NULL; dp = dp->next)
38 if (!strcmp(dname, dp->name))
39 return(dp); /* found! */
40
41 /*
42 * If we haven't loaded the data already, we will look
43 * for it in the directorys specified by the library path.
44 *
45 * The file has the following format:
46 *
47 * #dimensions
48 * beg0 end0 n0
49 * beg1 end1 n1
50 * . . .
51 * data, later dimensions changing faster
52 * . . .
53 *
54 */
55
56 if ((dfname = getpath(dname, libpath, R_OK)) == NULL) {
57 sprintf(errmsg, "cannot find data file \"%s\"", dname);
58 error(USER, errmsg);
59 }
60 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
61 goto memerr;
62
63 dp->name = savestr(dname);
64
65 if ((fp = fopen(dfname, "r")) == NULL) {
66 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
67 error(SYSTEM, errmsg);
68 }
69 /* get dimensions */
70 if (fscanf(fp, "%d", &dp->nd) != 1)
71 goto scanerr;
72 if (dp->nd <= 0 || dp->nd > MAXDIM) {
73 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
74 error(USER, errmsg);
75 }
76 asize = 1;
77 for (i = 0; i < dp->nd; i++) {
78 if (fscanf(fp, "%lf %lf %d",
79 &dp->dim[i].org, &dp->dim[i].siz,
80 &dp->dim[i].ne) != 3)
81 goto scanerr;
82 dp->dim[i].siz -= dp->dim[i].org;
83 asize *= dp->dim[i].ne;
84 }
85 if ((dp->arr = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
86 goto memerr;
87
88 for (i = 0; i < asize; i++)
89 if (fscanf(fp, DSCANF, &dp->arr[i]) != 1)
90 goto scanerr;
91
92 fclose(fp);
93 dp->next = dlist;
94 return(dlist = dp);
95
96 memerr:
97 error(SYSTEM, "out of memory in getdata");
98 scanerr:
99 sprintf(errmsg, "%s in data file \"%s\"",
100 feof(fp) ? "unexpected EOF" : "bad format", dfname);
101 error(USER, errmsg);
102 }
103
104
105 DATARRAY *
106 getpict(pname) /* get picture pname */
107 char *pname;
108 {
109 extern char *libpath;
110 char *pfname;
111 FILE *fp;
112 COLOR *scanin;
113 int width, height;
114 int x, y;
115 register int i;
116 register DATARRAY *pp;
117 /* look for array in list */
118 for (pp = plist; pp != NULL; pp = pp->next)
119 if (!strcmp(pname, pp->name))
120 return(pp); /* found! */
121
122 if ((pfname = getpath(pname, libpath, R_OK)) == NULL) {
123 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
124 error(USER, errmsg);
125 }
126 if ((pp = (DATARRAY *)calloc(3, sizeof(DATARRAY))) == NULL)
127 goto memerr;
128
129 pp[0].name =
130 pp[1].name =
131 pp[2].name = savestr(pname);
132
133 if ((fp = fopen(pfname, "r")) == NULL) {
134 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
135 error(SYSTEM, errmsg);
136 }
137 /* get dimensions */
138 getheader(fp, NULL);
139 if (fscanf(fp, "-Y %d +X %d\n", &height, &width) != 2)
140 goto readerr;
141 for (i = 0; i < 3; i++) {
142 pp[i].nd = 2;
143 pp[i].dim[0].ne = width;
144 pp[i].dim[1].ne = height;
145 pp[i].dim[0].org =
146 pp[i].dim[1].org = 0.0;
147 if (width <= height) {
148 pp[i].dim[0].siz = 1.0;
149 pp[i].dim[1].siz = (double)height/width;
150 } else {
151 pp[i].dim[0].siz = (double)width/height;
152 pp[i].dim[1].siz = 1.0;
153 }
154 pp[i].arr = (DATATYPE *)malloc(width*height*sizeof(DATATYPE));
155 if (pp[i].arr == NULL)
156 goto memerr;
157 }
158 /* load picture */
159 if ((scanin = (COLOR *)malloc(width*sizeof(COLOR))) == NULL)
160 goto memerr;
161 for (y = height-1; y >= 0; y--) {
162 if (freadscan(scanin, width, fp) < 0)
163 goto readerr;
164 for (x = 0; x < width; x++)
165 for (i = 0; i < 3; i++)
166 pp[i].arr[x*height+y] = colval(scanin[x],i);
167 }
168 free((char *)scanin);
169 fclose(fp);
170 pp[0].next =
171 pp[1].next =
172 pp[2].next = plist;
173 return(plist = pp);
174
175 memerr:
176 error(SYSTEM, "out of memory in getpict");
177 readerr:
178 sprintf(errmsg, "bad picture file \"%s\"", pfname);
179 error(USER, errmsg);
180 }
181
182
183 freedata(dname) /* free memory associated with dname */
184 char *dname;
185 {
186 register DATARRAY *dp, *dpl;
187
188 for (dpl = NULL, dp = dlist; dp != NULL; dpl = dp, dp = dp->next)
189 if (!strcmp(dname, dp->name)) {
190 if (dpl == NULL)
191 dlist = dp->next;
192 else
193 dpl->next = dp->next;
194 free((char *)dp->arr);
195 freestr(dp->name);
196 free((char *)dp);
197 return;
198 }
199 }
200
201
202 freepict(pname) /* free memory associated with pname */
203 char *pname;
204 {
205 register DATARRAY *pp, *ppl;
206
207 for (ppl = NULL, pp = plist; pp != NULL; ppl = pp, pp = pp->next)
208 if (!strcmp(pname, pp->name)) {
209 if (ppl == NULL)
210 plist = pp->next;
211 else
212 ppl->next = pp->next;
213 free((char *)pp[0].arr);
214 free((char *)pp[1].arr);
215 free((char *)pp[2].arr);
216 freestr(pp[0].name);
217 free((char *)pp);
218 return;
219 }
220 }
221
222
223 double
224 datavalue(dp, pt) /* interpolate data value at a point */
225 register DATARRAY *dp;
226 double *pt;
227 {
228 DATARRAY sd;
229 int asize;
230 register int i;
231 double x, y, y0, y1;
232
233 sd.nd = dp->nd - 1;
234 asize = 1;
235 for (i = 0; i < sd.nd; i++) {
236 sd.dim[i].org = dp->dim[i+1].org;
237 sd.dim[i].siz = dp->dim[i+1].siz;
238 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
239 }
240
241 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
242
243 x *= dp->dim[0].ne - 1;
244
245 i = x;
246 if (i < 0)
247 i = 0;
248 else if (i > dp->dim[0].ne - 2)
249 i = dp->dim[0].ne - 2;
250
251 if (dp->nd == 1) {
252 y0 = dp->arr[i];
253 y1 = dp->arr[i+1];
254 } else {
255 sd.arr = &dp->arr[i*asize];
256 y0 = datavalue(&sd, pt+1);
257 sd.arr = &dp->arr[(i+1)*asize];
258 y1 = datavalue(&sd, pt+1);
259 }
260
261 /*
262 * Extrapolate as far as one division, then
263 * taper off harmonically to zero.
264 */
265 if (x > i+2)
266 y = (2*y1-y0)/(x-i-1);
267 else if (x < i-1)
268 y = (2*y0-y1)/(i-x);
269 else
270 y = y0*((i+1)-x) + y1*(x-i);
271
272 return(y);
273 }
