root/radiance/ray/src/rt/data.c
Revision: 2.7
Committed: Mon Feb 8 13:12:28 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.6: +20 -1 lines
added warning for pictures using more than PSIZWARN bytes memory
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * data.c - routines dealing with interpolated data.
9 *
10 * 6/4/86
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "resolu.h"
18
19 #include "data.h"
20
21 /* picture memory usage before warning */
22 #ifndef PSIZWARN
23 #ifdef BIGMEM
24 #define PSIZWARN 3000000
25 #else
26 #define PSIZWARN 1000000
27 #endif
28 #endif
29
30 #ifndef TABSIZ
31 #define TABSIZ 97 /* table size (prime) */
32 #endif
33
34 #define hash(s) (shash(s)%TABSIZ)
35
36
37 extern char *fgetword();
38
39 extern char *libpath; /* library search path */
40
41 static DATARRAY *dtab[TABSIZ]; /* data array list */
42
43 static DATARRAY *ptab[TABSIZ]; /* picture list */
44
45
46 DATARRAY *
47 getdata(dname) /* get data array dname */
48 char *dname;
49 {
50 char word[64];
51 char *dfname;
52 FILE *fp;
53 int asize;
54 register int i, j;
55 register DATARRAY *dp;
56 /* look for array in list */
57 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
58 if (!strcmp(dname, dp->name))
59 return(dp); /* found! */
60
61 /*
62 * If we haven't loaded the data already, we will look
63 * for it in the directories specified by the library path.
64 *
65 * The file has the following format:
66 *
67 * N
68 * beg0 end0 n0
69 * beg1 end1 n1
70 * . . .
71 * begN endN nN
72 * data, later dimensions changing faster
73 * . . .
74 *
75 * For irregularly spaced points, the following can be
76 * substituted for begi endi ni:
77 *
78 * 0 0 ni p0i p1i .. pni
79 */
80
81 if ((dfname = getpath(dname, libpath, R_OK)) == NULL) {
82 sprintf(errmsg, "cannot find data file \"%s\"", dname);
83 error(USER, errmsg);
84 }
85 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
86 goto memerr;
87
88 dp->name = savestr(dname);
89
90 if ((fp = fopen(dfname, "r")) == NULL) {
91 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
92 error(SYSTEM, errmsg);
93 }
94 /* get dimensions */
95 if (fgetword(word, sizeof(word), fp) == NULL || !isint(word))
96 goto scanerr;
97 dp->nd = atoi(word);
98 if (dp->nd <= 0 || dp->nd > MAXDDIM) {
99 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
100 error(USER, errmsg);
101 }
102 asize = 1;
103 for (i = 0; i < dp->nd; i++) {
104 if (fgetword(word, sizeof(word), fp) == NULL || !isflt(word))
105 goto scanerr;
106 dp->dim[i].org = atof(word);
107 if (fgetword(word, sizeof(word), fp) == NULL || !isflt(word))
108 goto scanerr;
109 dp->dim[i].siz = atof(word);
110 if (fgetword(word, sizeof(word), fp) == NULL || !isint(word))
111 goto scanerr;
112 dp->dim[i].ne = atoi(word);
113 if (dp->dim[i].ne < 2)
114 goto scanerr;
115 asize *= dp->dim[i].ne;
116 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
117 dp->dim[i].p = (double *)malloc(dp->dim[i].ne*sizeof(double));
118 if (dp->dim[i].p == NULL)
119 goto memerr;
120 for (j = 0; j < dp->dim[i].ne; j++) {
121 if (fgetword(word, sizeof(word), fp) == NULL ||
122 !isflt(word))
123 goto scanerr;
124 dp->dim[i].p[j] = atof(word);
125 }
126 for (j = 1; j < dp->dim[i].ne-1; j++)
127 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
128 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
129 goto scanerr;
130 dp->dim[i].org = dp->dim[i].p[0];
131 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
132 - dp->dim[i].p[0];
133 } else
134 dp->dim[i].p = NULL;
135 }
136 if ((dp->arr = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
137 goto memerr;
138
139 for (i = 0; i < asize; i++) {
140 if (fgetword(word, sizeof(word), fp) == NULL || !isflt(word))
141 goto scanerr;
142 dp->arr[i] = atof(word);
143 }
144 fclose(fp);
145 i = hash(dname);
146 dp->next = dtab[i];
147 return(dtab[i] = dp);
148
149 memerr:
150 error(SYSTEM, "out of memory in getdata");
151 scanerr:
152 sprintf(errmsg, "%s in data file \"%s\"",
153 feof(fp) ? "unexpected EOF" : "bad format", dfname);
154 error(USER, errmsg);
155 }
156
157
158 static
159 headaspect(s, iap) /* check string for aspect ratio */
160 char *s;
161 double *iap;
162 {
163 if (isaspect(s))
164 *iap *= aspectval(s);
165 }
166
167
168 DATARRAY *
169 getpict(pname) /* get picture pname */
170 char *pname;
171 {
172 extern char *libpath;
173 double inpaspect;
174 char *pfname;
175 FILE *fp;
176 COLOR *scanin;
177 int sl, ns;
178 RESOLU inpres;
179 FLOAT loc[2];
180 int y;
181 register int x, i;
182 register DATARRAY *pp;
183 /* look for array in list */
184 for (pp = ptab[hash(pname)]; pp != NULL; pp = pp->next)
185 if (!strcmp(pname, pp->name))
186 return(pp); /* found! */
187
188 if ((pfname = getpath(pname, libpath, R_OK)) == NULL) {
189 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
190 error(USER, errmsg);
191 }
192 if ((pp = (DATARRAY *)calloc(3, sizeof(DATARRAY))) == NULL)
193 goto memerr;
194
195 pp[0].name =
196 pp[1].name =
197 pp[2].name = savestr(pname);
198
199 if ((fp = fopen(pfname, "r")) == NULL) {
200 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
201 error(SYSTEM, errmsg);
202 }
203 #ifdef MSDOS
204 setmode(fileno(fp), O_BINARY);
205 #endif
206 /* get dimensions */
207 inpaspect = 1.0;
208 getheader(fp, headaspect, &inpaspect);
209 if (!fgetsresolu(&inpres, fp))
210 goto readerr;
211 #if PSIZWARN
212 /* check memory usage */
213 i = 3*sizeof(DATATYPE)*inpres.xr*inpres.yr;
214 if (i > PSIZWARN) {
215 sprintf(errmsg, "picture file \"%s\" using %d bytes of memory",
216 pname, i);
217 error(WARNING, errmsg);
218 }
219 #endif
220 for (i = 0; i < 3; i++) {
221 pp[i].nd = 2;
222 pp[i].dim[0].ne = inpres.yr;
223 pp[i].dim[1].ne = inpres.xr;
224 pp[i].dim[0].org =
225 pp[i].dim[1].org = 0.0;
226 if (inpres.xr <= inpres.yr*inpaspect) {
227 pp[i].dim[0].siz = inpaspect *
228 (double)inpres.yr/inpres.xr;
229 pp[i].dim[1].siz = 1.0;
230 } else {
231 pp[i].dim[0].siz = 1.0;
232 pp[i].dim[1].siz = (double)inpres.xr/inpres.yr /
233 inpaspect;
234 }
235 pp[i].dim[0].p = pp[i].dim[1].p = NULL;
236 pp[i].arr = (DATATYPE *)
237 malloc(inpres.xr*inpres.yr*sizeof(DATATYPE));
238 if (pp[i].arr == NULL)
239 goto memerr;
240 }
241 /* load picture */
242 sl = scanlen(&inpres);
243 ns = numscans(&inpres);
244 if ((scanin = (COLOR *)malloc(sl*sizeof(COLOR))) == NULL)
245 goto memerr;
246 for (y = 0; y < ns; y++) {
247 if (freadscan(scanin, sl, fp) < 0)
248 goto readerr;
249 for (x = 0; x < sl; x++) {
250 pix2loc(loc, &inpres, x, y);
251 i = (int)(loc[1]*inpres.yr)*inpres.xr +
252 (int)(loc[0]*inpres.xr);
253 pp[0].arr[i] = colval(scanin[x],RED);
254 pp[1].arr[i] = colval(scanin[x],GRN);
255 pp[2].arr[i] = colval(scanin[x],BLU);
256 }
257 }
258 free((char *)scanin);
259 fclose(fp);
260 i = hash(pname);
261 pp[0].next =
262 pp[1].next =
263 pp[2].next = ptab[i];
264 return(ptab[i] = pp);
265
266 memerr:
267 error(SYSTEM, "out of memory in getpict");
268 readerr:
269 sprintf(errmsg, "bad picture file \"%s\"", pfname);
270 error(USER, errmsg);
271 }
272
273
274 freedata(dname) /* free memory associated with dname */
275 char *dname;
276 {
277 DATARRAY head;
278 int hval, nents;
279 register DATARRAY *dp, *dpl;
280 register int i;
281
282 if (dname == NULL) { /* free all if NULL */
283 hval = 0; nents = TABSIZ;
284 } else {
285 hval = hash(dname); nents = 1;
286 }
287 while (nents--) {
288 head.next = dtab[hval];
289 dpl = &head;
290 while ((dp = dpl->next) != NULL)
291 if (dname == NULL || !strcmp(dname, dp->name)) {
292 dpl->next = dp->next;
293 free((char *)dp->arr);
294 for (i = 0; i < dp->nd; i++)
295 if (dp->dim[i].p != NULL)
296 free((char *)dp->dim[i].p);
297 freestr(dp->name);
298 free((char *)dp);
299 } else
300 dpl = dp;
301 dtab[hval++] = head.next;
302 }
303 }
304
305
306 freepict(pname) /* free memory associated with pname */
307 char *pname;
308 {
309 DATARRAY head;
310 int hval, nents;
311 register DATARRAY *pp, *ppl;
312
313 if (pname == NULL) { /* free all if NULL */
314 hval = 0; nents = TABSIZ;
315 } else {
316 hval = hash(pname); nents = 1;
317 }
318 while (nents--) {
319 head.next = ptab[hval];
320 ppl = &head;
321 while ((pp = ppl->next) != NULL)
322 if (pname == NULL || !strcmp(pname, pp->name)) {
323 ppl->next = pp->next;
324 free((char *)pp[0].arr);
325 free((char *)pp[1].arr);
326 free((char *)pp[2].arr);
327 freestr(pp[0].name);
328 free((char *)pp);
329 } else
330 ppl = pp;
331 ptab[hval++] = head.next;
332 }
333 }
334
335
336 double
337 datavalue(dp, pt) /* interpolate data value at a point */
338 register DATARRAY *dp;
339 double *pt;
340 {
341 DATARRAY sd;
342 int asize;
343 int lower, upper;
344 register int i;
345 double x, y, y0, y1;
346 /* set up dimensions for recursion */
347 sd.nd = dp->nd - 1;
348 asize = 1;
349 for (i = 0; i < sd.nd; i++) {
350 sd.dim[i].org = dp->dim[i+1].org;
351 sd.dim[i].siz = dp->dim[i+1].siz;
352 sd.dim[i].p = dp->dim[i+1].p;
353 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
354 }
355 /* get independent variable */
356 if (dp->dim[0].p == NULL) { /* evenly spaced points */
357 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
358 x = x * (dp->dim[0].ne - 1);
359 i = x;
360 if (i < 0)
361 i = 0;
362 else if (i > dp->dim[0].ne - 2)
363 i = dp->dim[0].ne - 2;
364 } else { /* unevenly spaced points */
365 if (dp->dim[0].siz > 0.0) {
366 lower = 0;
367 upper = dp->dim[0].ne;
368 } else {
369 lower = dp->dim[0].ne;
370 upper = 0;
371 }
372 do {
373 i = (lower + upper) >> 1;
374 if (pt[0] >= dp->dim[0].p[i])
375 lower = i;
376 else
377 upper = i;
378 } while (i != (lower + upper) >> 1);
379 if (i > dp->dim[0].ne - 2)
380 i = dp->dim[0].ne - 2;
381 x = i + (pt[0] - dp->dim[0].p[i]) /
382 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
383 }
384 /* get dependent variable */
385 if (dp->nd == 1) {
386 y0 = dp->arr[i];
387 y1 = dp->arr[i+1];
388 } else {
389 sd.arr = &dp->arr[i*asize];
390 y0 = datavalue(&sd, pt+1);
391 sd.arr = &dp->arr[(i+1)*asize];
392 y1 = datavalue(&sd, pt+1);
393 }
394 /*
395 * Extrapolate as far as one division, then
396 * taper off harmonically to zero.
397 */
398 if (x > i+2)
399 y = (2*y1-y0)/(x-i-1);
400 else if (x < i-1)
401 y = (2*y0-y1)/(i-x);
402 else
403 y = y0*((i+1)-x) + y1*(x-i);
404
405 return(y);
406 }
