root/radiance/ray/src/rt/data.c
Revision: 2.12
Committed: Thu Feb 15 18:46:54 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.11: +84 -104 lines
made pictures use RGBE storage r.t. float
reduced MAXDDIM to 5
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * data.c - routines dealing with interpolated data.
9 */
10
11 #include "standard.h"
12
13 #include "color.h"
14
15 #include "resolu.h"
16
17 #include "data.h"
18
19 /* picture memory usage before warning */
20 #ifndef PSIZWARN
21 #ifdef BIGMEM
22 #define PSIZWARN 3000000
23 #else
24 #define PSIZWARN 1000000
25 #endif
26 #endif
27
28 #ifndef TABSIZ
29 #define TABSIZ 97 /* table size (prime) */
30 #endif
31
32 #define hash(s) (shash(s)%TABSIZ)
33
34
35 extern char *getlibpath(); /* library search path */
36
37 static DATARRAY *dtab[TABSIZ]; /* data array list */
38
39
40 DATARRAY *
41 getdata(dname) /* get data array dname */
42 char *dname;
43 {
44 char *dfname;
45 FILE *fp;
46 int asize;
47 register int i, j;
48 register DATARRAY *dp;
49 /* look for array in list */
50 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
51 if (!strcmp(dname, dp->name))
52 return(dp); /* found! */
53
54 /*
55 * If we haven't loaded the data already, we will look
56 * for it in the directories specified by the library path.
57 *
58 * The file has the following format:
59 *
60 * N
61 * beg0 end0 n0
62 * beg1 end1 n1
63 * . . .
64 * begN endN nN
65 * data, later dimensions changing faster
66 * . . .
67 *
68 * For irregularly spaced points, the following can be
69 * substituted for begi endi ni:
70 *
71 * 0 0 ni p0i p1i .. pni
72 */
73
74 if ((dfname = getpath(dname, getlibpath(), R_OK)) == NULL) {
75 sprintf(errmsg, "cannot find data file \"%s\"", dname);
76 error(USER, errmsg);
77 }
78 if ((fp = fopen(dfname, "r")) == NULL) {
79 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
80 error(SYSTEM, errmsg);
81 }
82 /* get dimensions */
83 if (fgetval(fp, 'i', &asize) <= 0)
84 goto scanerr;
85 if (asize <= 0 | asize > MAXDDIM) {
86 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
87 error(USER, errmsg);
88 }
89 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
90 goto memerr;
91 dp->name = savestr(dname);
92 dp->type = DATATY;
93 dp->nd = asize;
94 asize = 1;
95 for (i = 0; i < dp->nd; i++) {
96 if (fgetval(fp, DATATY, &dp->dim[i].org) <= 0)
97 goto scanerr;
98 if (fgetval(fp, DATATY, &dp->dim[i].siz) <= 0)
99 goto scanerr;
100 if (fgetval(fp, 'i', &dp->dim[i].ne) <= 0)
101 goto scanerr;
102 if (dp->dim[i].ne < 2)
103 goto scanerr;
104 asize *= dp->dim[i].ne;
105 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
106 dp->dim[i].p = (DATATYPE *)
107 malloc(dp->dim[i].ne*sizeof(DATATYPE));
108 if (dp->dim[i].p == NULL)
109 goto memerr;
110 for (j = 0; j < dp->dim[i].ne; j++)
111 if (fgetval(fp, DATATY, &dp->dim[i].p[j]) <= 0)
112 goto scanerr;
113 for (j = 1; j < dp->dim[i].ne-1; j++)
114 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
115 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
116 goto scanerr;
117 dp->dim[i].org = dp->dim[i].p[0];
118 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
119 - dp->dim[i].p[0];
120 } else
121 dp->dim[i].p = NULL;
122 }
123 if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
124 goto memerr;
125
126 for (i = 0; i < asize; i++)
127 if (fgetval(fp, DATATY, &dp->arr.d[i]) <= 0)
128 goto scanerr;
129 fclose(fp);
130 i = hash(dname);
131 dp->next = dtab[i];
132 return(dtab[i] = dp);
133
134 memerr:
135 error(SYSTEM, "out of memory in getdata");
136 scanerr:
137 sprintf(errmsg, "%s in data file \"%s\"",
138 feof(fp) ? "unexpected EOF" : "bad format", dfname);
139 error(USER, errmsg);
140 }
141
142
143 static
144 headaspect(s, iap) /* check string for aspect ratio */
145 char *s;
146 double *iap;
147 {
148 if (isaspect(s))
149 *iap *= aspectval(s);
150 }
151
152
153 DATARRAY *
154 getpict(pname) /* get picture pname */
155 char *pname;
156 {
157 double inpaspect;
158 char *pfname;
159 FILE *fp;
160 COLR *scanin;
161 int sl, ns;
162 RESOLU inpres;
163 FLOAT loc[2];
164 int y;
165 register int x, i;
166 register DATARRAY *pp;
167 /* look for array in list */
168 for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
169 if (!strcmp(pname, pp->name))
170 return(pp); /* found! */
171
172 if ((pfname = getpath(pname, getlibpath(), R_OK)) == NULL) {
173 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
174 error(USER, errmsg);
175 }
176 if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
177 goto memerr;
178
179 pp[0].name = savestr(pname);
180
181 if ((fp = fopen(pfname, "r")) == NULL) {
182 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
183 error(SYSTEM, errmsg);
184 }
185 #ifdef MSDOS
186 setmode(fileno(fp), O_BINARY);
187 #endif
188 /* get dimensions */
189 inpaspect = 1.0;
190 getheader(fp, headaspect, &inpaspect);
191 if (!fgetsresolu(&inpres, fp))
192 goto readerr;
193 pp[0].nd = 2;
194 pp[0].dim[0].ne = inpres.yr;
195 pp[0].dim[1].ne = inpres.xr;
196 pp[0].dim[0].org =
197 pp[0].dim[1].org = 0.0;
198 if (inpres.xr <= inpres.yr*inpaspect) {
199 pp[0].dim[0].siz = inpaspect *
200 (double)inpres.yr/inpres.xr;
201 pp[0].dim[1].siz = 1.0;
202 } else {
203 pp[0].dim[0].siz = 1.0;
204 pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
205 inpaspect;
206 }
207 pp[0].dim[0].p = pp[0].dim[1].p = NULL;
208 sl = scanlen(&inpres); /* allocate array */
209 ns = numscans(&inpres);
210 i = ns*sl*sizeof(COLR);
211 #if PSIZWARN
212 if (i > PSIZWARN) { /* memory warning */
213 sprintf(errmsg, "picture file \"%s\" using %d bytes of memory",
214 pname, i);
215 error(WARNING, errmsg);
216 }
217 #endif
218 if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
219 goto memerr;
220 /* load picture */
221 if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
222 goto memerr;
223 for (y = 0; y < ns; y++) {
224 if (freadcolrs(scanin, sl, fp) < 0)
225 goto readerr;
226 for (x = 0; x < sl; x++) {
227 pix2loc(loc, &inpres, x, y);
228 i = (int)(loc[1]*inpres.yr)*inpres.xr +
229 (int)(loc[0]*inpres.xr);
230 copycolr(pp[0].arr.c[i], scanin[x]);
231 }
232 }
233 free((char *)scanin);
234 fclose(fp);
235 i = hash(pname);
236 pp[0].next = dtab[i]; /* link into picture list */
237 copystruct(&pp[1], &pp[0]);
238 copystruct(&pp[2], &pp[0]);
239 pp[0].type = RED; /* differentiate RGB records */
240 pp[1].type = GRN;
241 pp[2].type = BLU;
242 return(dtab[i] = pp);
243
244 memerr:
245 error(SYSTEM, "out of memory in getpict");
246 readerr:
247 sprintf(errmsg, "bad picture file \"%s\"", pfname);
248 error(USER, errmsg);
249 }
250
251
252 freedata(dname) /* free memory associated with dname */
253 char *dname;
254 {
255 DATARRAY head;
256 int hval, nents;
257 register DATARRAY *dp, *dpl;
258 register int i;
259
260 if (dname == NULL) { /* free all if NULL */
261 hval = 0; nents = TABSIZ;
262 } else {
263 hval = hash(dname); nents = 1;
264 }
265 while (nents--) {
266 head.next = dtab[hval];
267 dpl = &head;
268 while ((dp = dpl->next) != NULL)
269 if (dname == NULL || !strcmp(dname, dp->name)) {
270 dpl->next = dp->next;
271 if (dp->type == DATATY)
272 free((char *)dp->arr.d);
273 else
274 free((char *)dp->arr.c);
275 for (i = 0; i < dp->nd; i++)
276 if (dp->dim[i].p != NULL)
277 free((char *)dp->dim[i].p);
278 freestr(dp->name);
279 free((char *)dp);
280 } else
281 dpl = dp;
282 dtab[hval++] = head.next;
283 }
284 }
285
286
287 double
288 datavalue(dp, pt) /* interpolate data value at a point */
289 register DATARRAY *dp;
290 double *pt;
291 {
292 DATARRAY sd;
293 int asize;
294 int lower, upper;
295 register int i;
296 double x, y0, y1;
297 /* set up dimensions for recursion */
298 if (dp->nd > 1) {
299 sd.name = dp->name;
300 sd.type = dp->type;
301 sd.nd = dp->nd - 1;
302 asize = 1;
303 for (i = 0; i < sd.nd; i++) {
304 sd.dim[i].org = dp->dim[i+1].org;
305 sd.dim[i].siz = dp->dim[i+1].siz;
306 sd.dim[i].p = dp->dim[i+1].p;
307 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
308 }
309 }
310 /* get independent variable */
311 if (dp->dim[0].p == NULL) { /* evenly spaced points */
312 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
313 x *= (double)(dp->dim[0].ne - 1);
314 i = x;
315 if (i < 0)
316 i = 0;
317 else if (i > dp->dim[0].ne - 2)
318 i = dp->dim[0].ne - 2;
319 } else { /* unevenly spaced points */
320 if (dp->dim[0].siz > 0.0) {
321 lower = 0;
322 upper = dp->dim[0].ne;
323 } else {
324 lower = dp->dim[0].ne;
325 upper = 0;
326 }
327 do {
328 i = (lower + upper) >> 1;
329 if (pt[0] >= dp->dim[0].p[i])
330 lower = i;
331 else
332 upper = i;
333 } while (i != (lower + upper) >> 1);
334 if (i > dp->dim[0].ne - 2)
335 i = dp->dim[0].ne - 2;
336 x = i + (pt[0] - dp->dim[0].p[i]) /
337 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
338 }
339 /* get dependent variable */
340 if (dp->nd > 1) {
341 if (dp->type == DATATY) {
342 sd.arr.d = dp->arr.d + i*asize;
343 y0 = datavalue(&sd, pt+1);
344 sd.arr.d = dp->arr.d + (i+1)*asize;
345 y1 = datavalue(&sd, pt+1);
346 } else {
347 sd.arr.c = dp->arr.c + i*asize;
348 y0 = datavalue(&sd, pt+1);
349 sd.arr.c = dp->arr.c + (i+1)*asize;
350 y1 = datavalue(&sd, pt+1);
351 }
352 } else {
353 if (dp->type == DATATY) {
354 y0 = dp->arr.d[i];
355 y1 = dp->arr.d[i+1];
356 } else {
357 y0 = colrval(dp->arr.c[i],dp->type);
358 y1 = colrval(dp->arr.c[i+1],dp->type);
359 }
360 }
361 /*
362 * Extrapolate as far as one division, then
363 * taper off harmonically to zero.
364 */
365 if (x > i+2)
366 return( (2*y1-y0)/(x-(i-1)) );
367
368 if (x < i-1)
369 return( (2*y0-y1)/(i-x) );
370
371 return( y0*((i+1)-x) + y1*(x-i) );
372 }
