root/radiance/ray/src/rt/data.c
Revision: 2.14
Committed: Thu Nov 5 17:11:56 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 2.13: +6 -1 lines
changed getheader() to pay attention to function return value
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * data.c - routines dealing with interpolated data.
9 */
10
11 #include "standard.h"
12
13 #include "color.h"
14
15 #include "resolu.h"
16
17 #include "data.h"
18
19 /* picture memory usage before warning */
20 #ifndef PSIZWARN
21 #ifdef BIGMEM
22 #define PSIZWARN 5000000
23 #else
24 #define PSIZWARN 1500000
25 #endif
26 #endif
27
28 #ifndef TABSIZ
29 #define TABSIZ 97 /* table size (prime) */
30 #endif
31
32 #define hash(s) (shash(s)%TABSIZ)
33
34
35 extern char *getlibpath(); /* library search path */
36
37 static DATARRAY *dtab[TABSIZ]; /* data array list */
38
39
40 DATARRAY *
41 getdata(dname) /* get data array dname */
42 char *dname;
43 {
44 char *dfname;
45 FILE *fp;
46 int asize;
47 register int i, j;
48 register DATARRAY *dp;
49 /* look for array in list */
50 for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next)
51 if (!strcmp(dname, dp->name))
52 return(dp); /* found! */
53
54 /*
55 * If we haven't loaded the data already, we will look
56 * for it in the directories specified by the library path.
57 *
58 * The file has the following format:
59 *
60 * N
61 * beg0 end0 n0
62 * beg1 end1 n1
63 * . . .
64 * begN endN nN
65 * data, later dimensions changing faster
66 * . . .
67 *
68 * For irregularly spaced points, the following can be
69 * substituted for begi endi ni:
70 *
71 * 0 0 ni p0i p1i .. pni
72 */
73
74 if ((dfname = getpath(dname, getlibpath(), R_OK)) == NULL) {
75 sprintf(errmsg, "cannot find data file \"%s\"", dname);
76 error(USER, errmsg);
77 }
78 if ((fp = fopen(dfname, "r")) == NULL) {
79 sprintf(errmsg, "cannot open data file \"%s\"", dfname);
80 error(SYSTEM, errmsg);
81 }
82 /* get dimensions */
83 if (fgetval(fp, 'i', &asize) <= 0)
84 goto scanerr;
85 if (asize <= 0 | asize > MAXDDIM) {
86 sprintf(errmsg, "bad number of dimensions for \"%s\"", dname);
87 error(USER, errmsg);
88 }
89 if ((dp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL)
90 goto memerr;
91 dp->name = savestr(dname);
92 dp->type = DATATY;
93 dp->nd = asize;
94 asize = 1;
95 for (i = 0; i < dp->nd; i++) {
96 if (fgetval(fp, DATATY, &dp->dim[i].org) <= 0)
97 goto scanerr;
98 if (fgetval(fp, DATATY, &dp->dim[i].siz) <= 0)
99 goto scanerr;
100 if (fgetval(fp, 'i', &dp->dim[i].ne) <= 0)
101 goto scanerr;
102 if (dp->dim[i].ne < 2)
103 goto scanerr;
104 asize *= dp->dim[i].ne;
105 if ((dp->dim[i].siz -= dp->dim[i].org) == 0) {
106 dp->dim[i].p = (DATATYPE *)
107 malloc(dp->dim[i].ne*sizeof(DATATYPE));
108 if (dp->dim[i].p == NULL)
109 goto memerr;
110 for (j = 0; j < dp->dim[i].ne; j++)
111 if (fgetval(fp, DATATY, &dp->dim[i].p[j]) <= 0)
112 goto scanerr;
113 for (j = 1; j < dp->dim[i].ne-1; j++)
114 if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) !=
115 (dp->dim[i].p[j] < dp->dim[i].p[j+1]))
116 goto scanerr;
117 dp->dim[i].org = dp->dim[i].p[0];
118 dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1]
119 - dp->dim[i].p[0];
120 } else
121 dp->dim[i].p = NULL;
122 }
123 if ((dp->arr.d = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL)
124 goto memerr;
125
126 for (i = 0; i < asize; i++)
127 if (fgetval(fp, DATATY, &dp->arr.d[i]) <= 0)
128 goto scanerr;
129 fclose(fp);
130 i = hash(dname);
131 dp->next = dtab[i];
132 return(dtab[i] = dp);
133
134 memerr:
135 error(SYSTEM, "out of memory in getdata");
136 scanerr:
137 sprintf(errmsg, "%s in data file \"%s\"",
138 feof(fp) ? "unexpected EOF" : "bad format", dfname);
139 error(USER, errmsg);
140 }
141
142
143 static
144 headaspect(s, iap) /* check string for aspect ratio */
145 char *s;
146 double *iap;
147 {
148 char fmt[32];
149
150 if (isaspect(s))
151 *iap *= aspectval(s);
152 else if (formatval(fmt, s) && strcmp(fmt, COLRFMT))
153 *iap = 0.0;
154 return(0);
155 }
156
157
158 DATARRAY *
159 getpict(pname) /* get picture pname */
160 char *pname;
161 {
162 double inpaspect;
163 char *pfname;
164 FILE *fp;
165 COLR *scanin;
166 int sl, ns;
167 RESOLU inpres;
168 FLOAT loc[2];
169 int y;
170 register int x, i;
171 register DATARRAY *pp;
172 /* look for array in list */
173 for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next)
174 if (!strcmp(pname, pp->name))
175 return(pp); /* found! */
176
177 if ((pfname = getpath(pname, getlibpath(), R_OK)) == NULL) {
178 sprintf(errmsg, "cannot find picture file \"%s\"", pname);
179 error(USER, errmsg);
180 }
181 if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL)
182 goto memerr;
183
184 pp[0].name = savestr(pname);
185
186 if ((fp = fopen(pfname, "r")) == NULL) {
187 sprintf(errmsg, "cannot open picture file \"%s\"", pfname);
188 error(SYSTEM, errmsg);
189 }
190 #ifdef MSDOS
191 setmode(fileno(fp), O_BINARY);
192 #endif
193 /* get dimensions */
194 inpaspect = 1.0;
195 getheader(fp, headaspect, &inpaspect);
196 if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp))
197 goto readerr;
198 pp[0].nd = 2;
199 pp[0].dim[0].ne = inpres.yr;
200 pp[0].dim[1].ne = inpres.xr;
201 pp[0].dim[0].org =
202 pp[0].dim[1].org = 0.0;
203 if (inpres.xr <= inpres.yr*inpaspect) {
204 pp[0].dim[0].siz = inpaspect *
205 (double)inpres.yr/inpres.xr;
206 pp[0].dim[1].siz = 1.0;
207 } else {
208 pp[0].dim[0].siz = 1.0;
209 pp[0].dim[1].siz = (double)inpres.xr/inpres.yr /
210 inpaspect;
211 }
212 pp[0].dim[0].p = pp[0].dim[1].p = NULL;
213 sl = scanlen(&inpres); /* allocate array */
214 ns = numscans(&inpres);
215 i = ns*sl*sizeof(COLR);
216 #if PSIZWARN
217 if (i > PSIZWARN) { /* memory warning */
218 sprintf(errmsg, "picture file \"%s\" using %d bytes of memory",
219 pname, i);
220 error(WARNING, errmsg);
221 }
222 #endif
223 if ((pp[0].arr.c = (COLR *)malloc(i)) == NULL)
224 goto memerr;
225 /* load picture */
226 if ((scanin = (COLR *)malloc(sl*sizeof(COLR))) == NULL)
227 goto memerr;
228 for (y = 0; y < ns; y++) {
229 if (freadcolrs(scanin, sl, fp) < 0)
230 goto readerr;
231 for (x = 0; x < sl; x++) {
232 pix2loc(loc, &inpres, x, y);
233 i = (int)(loc[1]*inpres.yr)*inpres.xr +
234 (int)(loc[0]*inpres.xr);
235 copycolr(pp[0].arr.c[i], scanin[x]);
236 }
237 }
238 free((char *)scanin);
239 fclose(fp);
240 i = hash(pname);
241 pp[0].next = dtab[i]; /* link into picture list */
242 copystruct(&pp[1], &pp[0]);
243 copystruct(&pp[2], &pp[0]);
244 pp[0].type = RED; /* differentiate RGB records */
245 pp[1].type = GRN;
246 pp[2].type = BLU;
247 return(dtab[i] = pp);
248
249 memerr:
250 error(SYSTEM, "out of memory in getpict");
251 readerr:
252 sprintf(errmsg, "bad picture file \"%s\"", pfname);
253 error(USER, errmsg);
254 }
255
256
257 freedata(dname) /* free memory associated with dname */
258 char *dname;
259 {
260 DATARRAY head;
261 int hval, nents;
262 register DATARRAY *dp, *dpl;
263 register int i;
264
265 if (dname == NULL) { /* free all if NULL */
266 hval = 0; nents = TABSIZ;
267 } else {
268 hval = hash(dname); nents = 1;
269 }
270 while (nents--) {
271 head.next = dtab[hval];
272 dpl = &head;
273 while ((dp = dpl->next) != NULL)
274 if (dname == NULL || !strcmp(dname, dp->name)) {
275 dpl->next = dp->next;
276 if (dp->type == DATATY)
277 free((char *)dp->arr.d);
278 else
279 free((char *)dp->arr.c);
280 for (i = 0; i < dp->nd; i++)
281 if (dp->dim[i].p != NULL)
282 free((char *)dp->dim[i].p);
283 freestr(dp->name);
284 free((char *)dp);
285 } else
286 dpl = dp;
287 dtab[hval++] = head.next;
288 }
289 }
290
291
292 double
293 datavalue(dp, pt) /* interpolate data value at a point */
294 register DATARRAY *dp;
295 double *pt;
296 {
297 DATARRAY sd;
298 int asize;
299 int lower, upper;
300 register int i;
301 double x, y0, y1;
302 /* set up dimensions for recursion */
303 if (dp->nd > 1) {
304 sd.name = dp->name;
305 sd.type = dp->type;
306 sd.nd = dp->nd - 1;
307 asize = 1;
308 for (i = 0; i < sd.nd; i++) {
309 sd.dim[i].org = dp->dim[i+1].org;
310 sd.dim[i].siz = dp->dim[i+1].siz;
311 sd.dim[i].p = dp->dim[i+1].p;
312 asize *= sd.dim[i].ne = dp->dim[i+1].ne;
313 }
314 }
315 /* get independent variable */
316 if (dp->dim[0].p == NULL) { /* evenly spaced points */
317 x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz;
318 x *= (double)(dp->dim[0].ne - 1);
319 i = x;
320 if (i < 0)
321 i = 0;
322 else if (i > dp->dim[0].ne - 2)
323 i = dp->dim[0].ne - 2;
324 } else { /* unevenly spaced points */
325 if (dp->dim[0].siz > 0.0) {
326 lower = 0;
327 upper = dp->dim[0].ne;
328 } else {
329 lower = dp->dim[0].ne;
330 upper = 0;
331 }
332 do {
333 i = (lower + upper) >> 1;
334 if (pt[0] >= dp->dim[0].p[i])
335 lower = i;
336 else
337 upper = i;
338 } while (i != (lower + upper) >> 1);
339 if (i > dp->dim[0].ne - 2)
340 i = dp->dim[0].ne - 2;
341 x = i + (pt[0] - dp->dim[0].p[i]) /
342 (dp->dim[0].p[i+1] - dp->dim[0].p[i]);
343 }
344 /* get dependent variable */
345 if (dp->nd > 1) {
346 if (dp->type == DATATY) {
347 sd.arr.d = dp->arr.d + i*asize;
348 y0 = datavalue(&sd, pt+1);
349 sd.arr.d = dp->arr.d + (i+1)*asize;
350 y1 = datavalue(&sd, pt+1);
351 } else {
352 sd.arr.c = dp->arr.c + i*asize;
353 y0 = datavalue(&sd, pt+1);
354 sd.arr.c = dp->arr.c + (i+1)*asize;
355 y1 = datavalue(&sd, pt+1);
356 }
357 } else {
358 if (dp->type == DATATY) {
359 y0 = dp->arr.d[i];
360 y1 = dp->arr.d[i+1];
361 } else {
362 y0 = colrval(dp->arr.c[i],dp->type);
363 y1 = colrval(dp->arr.c[i+1],dp->type);
364 }
365 }
366 /*
367 * Extrapolate as far as one division, then
368 * taper off harmonically to zero.
369 */
370 if (x > i+2)
371 return( (2*y1-y0)/(x-(i-1)) );
372
373 if (x < i-1)
374 return( (2*y0-y1)/(i-x) );
375
376 return( y0*((i+1)-x) + y1*(x-i) );
377 }
