--- ray/src/rt/data.c 1989/09/12 12:26:14 1.3 +++ ray/src/rt/data.c 1990/04/03 17:48:46 1.5 @@ -31,7 +31,7 @@ char *dname; char *dfname; FILE *fp; int asize; - register int i; + register int i, j; register DATARRAY *dp; /* look for array in list */ for (dp = dlist; dp != NULL; dp = dp->next) @@ -44,13 +44,18 @@ char *dname; * * The file has the following format: * - * #dimensions + * N * beg0 end0 n0 * beg1 end1 n1 * . . . + * begN endN nN * data, later dimensions changing faster * . . . * + * For irregularly spaced points, the following can be + * substituted for begi endi ni: + * + * @ ni p0i p1i .. pni */ if ((dfname = getpath(dname, libpath, R_OK)) == NULL) { @@ -77,9 +82,27 @@ char *dname; for (i = 0; i < dp->nd; i++) { if (fscanf(fp, "%lf %lf %d", &dp->dim[i].org, &dp->dim[i].siz, - &dp->dim[i].ne) != 3) + &dp->dim[i].ne) == 3) { + dp->dim[i].siz -= dp->dim[i].org; + dp->dim[i].p = NULL; + } else if (fscanf(fp, "@ %d", &dp->dim[i].ne) == 1) { + dp->dim[i].p = (double *)malloc(dp->dim[i].ne*sizeof(double)); + if (dp->dim[i].p == NULL) + goto memerr; + for (j = 0; j < dp->dim[i].ne; j++) + if (fscanf(fp, "%lf", &dp->dim[i].p[j]) != 1) + goto scanerr; + for (j = 1; j < dp->dim[i].ne-1; j++) + if ((dp->dim[i].p[j-1] < dp->dim[i].p[j]) != + (dp->dim[i].p[j] < dp->dim[i].p[j+1])) + goto scanerr; + dp->dim[i].org = dp->dim[i].p[0]; + dp->dim[i].siz = dp->dim[i].p[dp->dim[i].ne-1] + - dp->dim[i].p[0]; + } else goto scanerr; - dp->dim[i].siz -= dp->dim[i].org; + if (dp->dim[i].siz == 0.0 || dp->dim[i].ne < 2) + goto scanerr; asize *= dp->dim[i].ne; } if ((dp->arr = (DATATYPE *)malloc(asize*sizeof(DATATYPE))) == NULL) @@ -102,6 +125,17 @@ scanerr: } +static double inpaspect; /* aspect ratio of input picture */ + +static +headaspect(s) /* check string for aspect ratio */ +char *s; +{ + if (isaspect(s)) + inpaspect *= aspectval(s); +} + + DATARRAY * getpict(pname) /* get picture pname */ char *pname; @@ -135,7 +169,8 @@ char *pname; error(SYSTEM, errmsg); } /* get dimensions */ - getheader(fp, NULL); + inpaspect = 1.0; + getheader(fp, headaspect); if (fgetresolu(&width, &height, fp) != (YMAJOR|YDECR)) goto readerr; for (i = 0; i < 3; i++) { @@ -144,11 +179,11 @@ char *pname; pp[i].dim[1].ne = height; pp[i].dim[0].org = pp[i].dim[1].org = 0.0; - if (width <= height) { + if (width <= height*inpaspect) { pp[i].dim[0].siz = 1.0; - pp[i].dim[1].siz = (double)height/width; + pp[i].dim[1].siz = inpaspect*(double)height/width; } else { - pp[i].dim[0].siz = (double)width/height; + pp[i].dim[0].siz = (double)width/height/inpaspect; pp[i].dim[1].siz = 1.0; } pp[i].arr = (DATATYPE *)malloc(width*height*sizeof(DATATYPE)); @@ -184,6 +219,7 @@ freedata(dname) /* free memory associated with dname char *dname; { register DATARRAY *dp, *dpl; + register int i; for (dpl = NULL, dp = dlist; dp != NULL; dpl = dp, dp = dp->next) if (!strcmp(dname, dp->name)) { @@ -192,6 +228,9 @@ char *dname; else dpl->next = dp->next; free((char *)dp->arr); + for (i = 0; i < dp->nd; i++) + if (dp->dim[i].p != NULL) + free((char *)dp->dim[i].p); freestr(dp->name); free((char *)dp); return; @@ -229,25 +268,43 @@ double *pt; int asize; register int i; double x, y, y0, y1; - + /* set up dimensions for recursion */ sd.nd = dp->nd - 1; asize = 1; for (i = 0; i < sd.nd; i++) { sd.dim[i].org = dp->dim[i+1].org; sd.dim[i].siz = dp->dim[i+1].siz; + sd.dim[i].p = dp->dim[i+1].p; asize *= sd.dim[i].ne = dp->dim[i+1].ne; } - - x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; - - x *= dp->dim[0].ne - 1; - - i = x; - if (i < 0) - i = 0; - else if (i > dp->dim[0].ne - 2) - i = dp->dim[0].ne - 2; - + /* get independent variable */ + if (dp->dim[0].p == NULL) { /* evenly spaced points */ + x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; + x = x * (dp->dim[0].ne - 1); + i = x; + if (i < 0) + i = 0; + else if (i > dp->dim[0].ne - 2) + i = dp->dim[0].ne - 2; + } else { /* unevenly spaced points */ + if (dp->dim[0].siz > 0.0) + for (i = 0; i < dp->dim[0].ne; i++) + if (pt[0] < dp->dim[0].p[i]) + break; + else + for (i = 0; i < dp->dim[0].ne; i++) + if (pt[0] >= dp->dim[0].p[i]) + break; + if (i <= 0) + i = 0; + else if (i >= dp->dim[0].ne) + i = dp->dim[0].ne - 2; + else + i--; + x = i + (pt[0] - dp->dim[0].p[i]) / + (dp->dim[0].p[i+1] - dp->dim[0].p[i]); + } + /* get dependent variable */ if (dp->nd == 1) { y0 = dp->arr[i]; y1 = dp->arr[i+1]; @@ -257,7 +314,6 @@ double *pt; sd.arr = &dp->arr[(i+1)*asize]; y1 = datavalue(&sd, pt+1); } - /* * Extrapolate as far as one division, then * taper off harmonically to zero.
