Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed getheader() to pay attention to function return value
increased PSIZWARN definitions
made pictures use RGBE storage r.t. float reduced MAXDDIM to 5
bug fix from adding comments to data files
added comments to data files using new fgetval() function
minor grooming of datavalue()
added warning for pictures using more than PSIZWARN bytes memory
finally moved to hash-table lookup of data file entries
added global freeing routines
fixed call to getheader() to pass 3 arguments always (DOS bug fix)
Changes for PC port
removed atof() declarations for NeXT
got rid of scanf() calls
changed MAXDIM to MAXDDIM to avoid conflict
eliminated unnecessary tests for unevenly spaced data points
changed y to be first dimension in picture
Changed format for uneven point data and used binary search
Added check for pixel aspect ratio in getpict()
Added capability for unevenly spaced points
added calls to picture resolution get/put routines
Changed getpath to check permissions
