--- ray/src/rt/data.c 1997/12/03 11:06:17 2.13 +++ ray/src/rt/data.c 2024/03/12 16:54:51 2.37 @@ -1,56 +1,57 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: data.c,v 2.37 2024/03/12 16:54:51 greg Exp $"; #endif - /* * data.c - routines dealing with interpolated data. */ -#include "standard.h" +#include "copyright.h" -#include "color.h" +#include +#include "platform.h" +#include "paths.h" +#include "standard.h" +#include "color.h" #include "resolu.h" - +#include "view.h" #include "data.h" /* picture memory usage before warning */ #ifndef PSIZWARN -#ifdef BIGMEM -#define PSIZWARN 5000000 +#ifdef SMLMEM +#define PSIZWARN 3000000 #else -#define PSIZWARN 1500000 +#define PSIZWARN 50000000 #endif #endif #ifndef TABSIZ -#define TABSIZ 97 /* table size (prime) */ +#define TABSIZ 997 /* table size (prime) */ #endif #define hash(s) (shash(s)%TABSIZ) -extern char *getlibpath(); /* library search path */ - static DATARRAY *dtab[TABSIZ]; /* data array list */ +static gethfunc headaspect; + DATARRAY * -getdata(dname) /* get data array dname */ -char *dname; +getdata( /* get data array dname */ + char *dname +) { char *dfname; FILE *fp; - int asize; - register int i, j; - register DATARRAY *dp; + int asize=0; + int i, j; + DATARRAY *dp; /* look for array in list */ for (dp = dtab[hash(dname)]; dp != NULL; dp = dp->next) if (!strcmp(dname, dp->name)) return(dp); /* found! */ - /* * If we haven't loaded the data already, we will look * for it in the directories specified by the library path. @@ -71,9 +72,9 @@ char *dname; * 0 0 ni p0i p1i .. pni */ - if ((dfname = getpath(dname, getlibpath(), R_OK)) == NULL) { + if ((dfname = getpath(dname, getrlibpath(), R_OK)) == NULL) { sprintf(errmsg, "cannot find data file \"%s\"", dname); - error(USER, errmsg); + error(SYSTEM, errmsg); } if ((fp = fopen(dfname, "r")) == NULL) { sprintf(errmsg, "cannot open data file \"%s\"", dfname); @@ -82,7 +83,7 @@ char *dname; /* get dimensions */ if (fgetval(fp, 'i', &asize) <= 0) goto scanerr; - if (asize <= 0 | asize > MAXDDIM) { + if ((asize <= 0) | (asize > MAXDDIM)) { sprintf(errmsg, "bad number of dimensions for \"%s\"", dname); error(USER, errmsg); } @@ -130,29 +131,35 @@ char *dname; i = hash(dname); dp->next = dtab[i]; return(dtab[i] = dp); - memerr: error(SYSTEM, "out of memory in getdata"); scanerr: sprintf(errmsg, "%s in data file \"%s\"", feof(fp) ? "unexpected EOF" : "bad format", dfname); error(USER, errmsg); + return NULL; /* pro forma return */ } -static -headaspect(s, iap) /* check string for aspect ratio */ -char *s; -double *iap; +static int +headaspect( /* check string for aspect ratio */ + char *s, + void *iap +) { + char fmt[MAXFMTLEN]; + if (isaspect(s)) - *iap *= aspectval(s); + *(double*)iap *= aspectval(s); + else if (formatval(fmt, s) && strcmp(fmt, COLRFMT)) + *(double*)iap = 0.0; + return(0); } - DATARRAY * -getpict(pname) /* get picture pname */ -char *pname; +getpict( /* get picture pname */ + char *pname +) { double inpaspect; char *pfname; @@ -160,35 +167,32 @@ char *pname; COLR *scanin; int sl, ns; RESOLU inpres; - FLOAT loc[2]; + RREAL loc[2]; int y; - register int x, i; - register DATARRAY *pp; + int x, i; + DATARRAY *pp; /* look for array in list */ for (pp = dtab[hash(pname)]; pp != NULL; pp = pp->next) if (!strcmp(pname, pp->name)) return(pp); /* found! */ - if ((pfname = getpath(pname, getlibpath(), R_OK)) == NULL) { + if ((pfname = getpath(pname, getrlibpath(), R_OK)) == NULL) { sprintf(errmsg, "cannot find picture file \"%s\"", pname); - error(USER, errmsg); + error(SYSTEM, errmsg); } if ((pp = (DATARRAY *)malloc(3*sizeof(DATARRAY))) == NULL) goto memerr; pp[0].name = savestr(pname); - if ((fp = fopen(pfname, "r")) == NULL) { + if ((fp = fopen(pfname, "rb")) == NULL) { sprintf(errmsg, "cannot open picture file \"%s\"", pfname); error(SYSTEM, errmsg); } -#ifdef MSDOS - setmode(fileno(fp), O_BINARY); -#endif /* get dimensions */ inpaspect = 1.0; getheader(fp, headaspect, &inpaspect); - if (!fgetsresolu(&inpres, fp)) + if (inpaspect <= FTINY || !fgetsresolu(&inpres, fp)) goto readerr; pp[0].nd = 2; pp[0].dim[0].ne = inpres.yr; @@ -210,8 +214,8 @@ char *pname; i = ns*sl*sizeof(COLR); #if PSIZWARN if (i > PSIZWARN) { /* memory warning */ - sprintf(errmsg, "picture file \"%s\" using %d bytes of memory", - pname, i); + sprintf(errmsg, "picture file \"%s\" using %.1f MB of memory", + pname, i*(1.0/(1024*1024))); error(WARNING, errmsg); } #endif @@ -230,53 +234,163 @@ char *pname; copycolr(pp[0].arr.c[i], scanin[x]); } } - free((char *)scanin); + free(scanin); fclose(fp); i = hash(pname); pp[0].next = dtab[i]; /* link into picture list */ - copystruct(&pp[1], &pp[0]); - copystruct(&pp[2], &pp[0]); + pp[1] = pp[0]; + pp[2] = pp[0]; pp[0].type = RED; /* differentiate RGB records */ pp[1].type = GRN; pp[2].type = BLU; return(dtab[i] = pp); - memerr: error(SYSTEM, "out of memory in getpict"); readerr: sprintf(errmsg, "bad picture file \"%s\"", pfname); error(USER, errmsg); + return NULL; /* pro forma return */ } -freedata(dname) /* free memory associated with dname */ -char *dname; +/* header info type for hyperspectral image */ +typedef struct { + float wlpart[4]; /* wavelength partitions */ + int nc; /* number of components */ + double inpaspect; /* pixel aspect ratio */ +} SPECINFO; + +static int +specheadline( /* get info for spectral image */ + char *s, + void *cdp +) { + SPECINFO *sip = (SPECINFO *)cdp; + char fmt[MAXFMTLEN]; + + if (isaspect(s)) + sip->inpaspect *= aspectval(s); + else if (isncomp(s)) + sip->nc = ncompval(s); + else if (iswlsplit(s)) + wlsplitval(sip->wlpart, s); + else if (formatval(fmt, s) && strcmp(fmt, SPECFMT)) + return(-1); + return(0); +} + +DATARRAY * +getspec( /* load hyperspectral image as data */ + char *sname +) +{ + SPECINFO si; + char *pfname; + FILE *fp; + int sl, ns; + int y, i; + DATARRAY *pp; + /* look for array in list */ + for (pp = dtab[hash(sname)]; pp != NULL; pp = pp->next) + if (!strcmp(sname, pp->name)) + return(pp); /* found! */ + + if ((pfname = getpath(sname, getrlibpath(), R_OK)) == NULL) { + sprintf(errmsg, "cannot find hyperspectral image \"%s\"", sname); + error(SYSTEM, errmsg); + } + if ((fp = fopen(pfname, "rb")) == NULL) { + sprintf(errmsg, "cannot open hyperspectral image \"%s\"", pfname); + error(SYSTEM, errmsg); + } + si.wlpart[3] = 0; + si.nc = 0; + si.inpaspect = 1.0; + if (getheader(fp, specheadline, &si) < 0 || + (si.nc <= 3) | (si.nc > MAXCSAMP) | (si.wlpart[3] < 1) || + !fscnresolu(&sl, &ns, fp)) + goto readerr; + + if ((pp = (DATARRAY *)malloc(sizeof(DATARRAY))) == NULL) + goto memerr; + + pp->name = savestr(sname); + pp->type = SPECTY; + pp->nd = 3; + pp->dim[0].ne = ns; + pp->dim[1].ne = sl; + pp->dim[0].org = + pp->dim[1].org = 0.0; + if (sl <= ns*si.inpaspect) { + pp->dim[0].siz = si.inpaspect * (double)ns/sl; + pp->dim[1].siz = 1.0; + } else { + pp->dim[0].siz = 1.0; + pp->dim[1].siz = (double)sl/ns / si.inpaspect; + } + pp->dim[2].ne = si.nc; + pp->dim[2].siz = si.wlpart[3] - si.wlpart[0]; + pp->dim[2].org = si.wlpart[0] + 0.5*pp->dim[2].siz/si.nc; + pp->dim[2].siz *= (si.nc - 1.0)/si.nc; + pp->dim[0].p = pp->dim[1].p = pp->dim[2].p = NULL; + i = ns*sl*(si.nc+1); +#if PSIZWARN + if (i > PSIZWARN) { /* memory warning */ + sprintf(errmsg, "hyperspectral image \"%s\" using %.1f MB of memory", + sname, i*(1.0/(1024*1024))); + error(WARNING, errmsg); + } +#endif + if ((pp->arr.s = (uby8 *)malloc(i)) == NULL) + goto memerr; + for (y = 0; y < ns; y++) /* read each scanline */ + if (freadscolrs(pp->arr.s + y*sl*(si.nc+1), si.nc, sl, fp) < 0) + goto readerr; + fclose(fp); + i = hash(sname); /* insert in hash table */ + pp->next = dtab[i]; + return(dtab[i] = pp); +memerr: + error(SYSTEM, "out of memory in getspec"); +readerr: + sprintf(errmsg, "bad hyperspectral image \"%s\"", pfname); + error(USER, errmsg); + return NULL; /* pro forma return */ +} + + +void +freedata( /* release data array reference */ + DATARRAY *dta +) +{ DATARRAY head; int hval, nents; - register DATARRAY *dp, *dpl; - register int i; + DATARRAY *dpl, *dp; + int i; - if (dname == NULL) { /* free all if NULL */ + if (dta == NULL) { /* free all if NULL */ hval = 0; nents = TABSIZ; } else { - hval = hash(dname); nents = 1; + hval = hash(dta->name); nents = 1; + if (!*dta->name) { /* not a data file? */ + dta->next = dtab[hval]; + dtab[hval] = dta; /* ...fake position */ + } } while (nents--) { head.next = dtab[hval]; dpl = &head; while ((dp = dpl->next) != NULL) - if (dname == NULL || !strcmp(dname, dp->name)) { + if ((dta == NULL) | (dta == dp)) { dpl->next = dp->next; - if (dp->type == DATATY) - free((char *)dp->arr.d); - else - free((char *)dp->arr.c); + free(dp->arr.p); for (i = 0; i < dp->nd; i++) if (dp->dim[i].p != NULL) - free((char *)dp->dim[i].p); + free(dp->dim[i].p); freestr(dp->name); - free((char *)dp); + free(dp); } else dpl = dp; dtab[hval++] = head.next; @@ -284,15 +398,189 @@ char *dname; } +/* internal call to interpolate data value or vector */ +static double +data_interp(DATARRAY *dp, double *pt, double coef, DATATYPE *rvec) +{ + DATARRAY sd; + int stride, i; + double x, c0, c1, y0, y1; + /* set up dimensions for recursion */ + if (dp->nd > 1) { + sd.name = dp->name; + sd.type = dp->type; + sd.nd = dp->nd - 1; + memcpy(sd.dim, dp->dim+1, sd.nd*sizeof(struct dadim)); + stride = sd.dim[i = sd.nd-1].ne + (sd.type==SPECTY); + while (i-- > 0) + stride *= sd.dim[i].ne; + } + /* get independent variable */ + if (dp->dim[0].p == NULL) { /* evenly spaced points */ + x = (pt[0] - dp->dim[0].org)/dp->dim[0].siz; + x *= (double)(dp->dim[0].ne - 1); + i = x; + if (i < 0) + i = 0; + else if (i > dp->dim[0].ne - 2) + i = dp->dim[0].ne - 2; + } else { /* unevenly spaced points */ + int lower, upper; + if (dp->dim[0].siz > 0.0) { + lower = 0; + upper = dp->dim[0].ne; + } else { + lower = dp->dim[0].ne; + upper = 0; + } + do { + i = (lower + upper) >> 1; + if (pt[0] >= dp->dim[0].p[i]) + lower = i; + else + upper = i; + } while (i != (lower + upper) >> 1); + + if (i > dp->dim[0].ne - 2) + i = dp->dim[0].ne - 2; + + x = i + (pt[0] - dp->dim[0].p[i]) / + (dp->dim[0].p[i+1] - dp->dim[0].p[i]); + } + /* + * Compute interpolation coefficients: + * extrapolate as far as one division, then + * taper off harmonically to zero. + */ + if (x > i+2) { + c0 = 1./(i-1 - x); + c1 = -2.*c0; + } else if (x < i-1) { + c1 = 1./(i - x); + c0 = -2.*c1; + } else { + c0 = i+1 - x; + c1 = x - i; + } + c0 *= coef; + c1 *= coef; + /* check if vector interp */ + if ((dp->nd == 2) & (rvec != NULL)) { + if (dp->type == DATATY) { + sd.arr.d = dp->arr.d + i*stride; + for (i = sd.dim[0].ne; i--; ) + rvec[i] += c0*sd.arr.d[i] + + c1*sd.arr.d[i+stride]; + return(0.); + } + if (dp->type == SPECTY) { + double f; + sd.arr.s = dp->arr.s + i*stride; + f = ldexp(1.0, (int)sd.arr.s[sd.dim[0].ne] + - (COLXS+8)); + for (i = sd.dim[0].ne; i--; ) + rvec[i] += c0*f*(sd.arr.s[i] + 0.5); + sd.arr.s += stride; + f = ldexp(1.0, (int)sd.arr.s[sd.dim[0].ne] + - (COLXS+8)); + for (i = sd.dim[0].ne; i--; ) + rvec[i] += c1*f*(sd.arr.s[i] + 0.5); + return(0.); + } + sd.arr.c = dp->arr.c + i*stride; + for (i = sd.dim[0].ne; i--; ) + rvec[i] += c0*colrval(sd.arr.c[i],sd.type) + + c1*colrval(sd.arr.c[i+stride],sd.type); + return(0.); + } + /* get dependent variable */ + if (dp->nd > 1) { + if (dp->type == DATATY) { + sd.arr.d = dp->arr.d + i*stride; + y0 = data_interp(&sd, pt+1, c0, rvec); + sd.arr.d += stride; + } else if (dp->type == SPECTY) { + sd.arr.s = dp->arr.s + i*stride; + y0 = data_interp(&sd, pt+1, c0, rvec); + sd.arr.s += stride; + } else { + sd.arr.c = dp->arr.c + i*stride; + y0 = data_interp(&sd, pt+1, c0, rvec); + sd.arr.c += stride; + } + y1 = data_interp(&sd, pt+1, c1, rvec); + } else { /* end of recursion */ + if (dp->type == DATATY) { + y0 = dp->arr.d[i]; + y1 = dp->arr.d[i+1]; + } else if (dp->type == SPECTY) { + if (dp->arr.s[dp->dim[0].ne]) { + double f = ldexp(1.0, -(COLXS+8) + + (int)dp->arr.s[dp->dim[0].ne]); + y0 = (dp->arr.s[i] + 0.5)*f; + y1 = (dp->arr.s[i+1] + 0.5)*f; + } else + y0 = y1 = 0.0; + } else { + y0 = colrval(dp->arr.c[i],dp->type); + y1 = colrval(dp->arr.c[i+1],dp->type); + } + y0 *= c0; + y1 *= c1; + } + return(y0 + y1); /* coefficients already applied */ +} + + double -datavalue(dp, pt) /* interpolate data value at a point */ -register DATARRAY *dp; -double *pt; +datavalue( /* interpolate data value at a point */ + DATARRAY *dp, + double *pt +) { + return(data_interp(dp, pt, 1., NULL)); +} + + +/* Interpolate final vector corresponding to last dimension in data array */ +DATARRAY * +datavector(DATARRAY *dp, double *pt) +{ + DATARRAY *newdp; + + if (dp->nd < 2) + error(INTERNAL, "datavector() called with 1-D array"); + /* create vector array */ + newdp = (DATARRAY *)malloc(sizeof(DATARRAY) - + (MAXDDIM-1)*sizeof(struct dadim) + + sizeof(DATATYPE)*dp->dim[dp->nd-1].ne); + if (newdp == NULL) + error(SYSTEM, "out of memory in datavector"); + newdp->next = NULL; + newdp->name = dp->name; + newdp->type = DATATY; + newdp->nd = 1; /* vector data goes here */ + newdp->dim[0] = dp->dim[dp->nd-1]; + newdp->arr.d = (DATATYPE *)(newdp->dim + 1); + memset(newdp->arr.d, 0, sizeof(DATATYPE)*newdp->dim[0].ne); + + (void)data_interp(dp, pt, 1., newdp->arr.d); + + return(newdp); /* will be free'd using free() */ +} + + +#if 0 +double +datavalue( /* interpolate data value at a point */ + DATARRAY *dp, + double *pt +) +{ DATARRAY sd; int asize; int lower, upper; - register int i; + int i; double x, y0, y1; /* set up dimensions for recursion */ if (dp->nd > 1) { @@ -304,7 +592,8 @@ double *pt; sd.dim[i].org = dp->dim[i+1].org; sd.dim[i].siz = dp->dim[i+1].siz; sd.dim[i].p = dp->dim[i+1].p; - asize *= sd.dim[i].ne = dp->dim[i+1].ne; + asize *= (sd.dim[i].ne = dp->dim[i+1].ne) + + ((sd.type==SPECTY) & (i==sd.nd-1)); } } /* get independent variable */ @@ -331,8 +620,10 @@ double *pt; else upper = i; } while (i != (lower + upper) >> 1); + if (i > dp->dim[0].ne - 2) i = dp->dim[0].ne - 2; + x = i + (pt[0] - dp->dim[0].p[i]) / (dp->dim[0].p[i+1] - dp->dim[0].p[i]); } @@ -341,18 +632,31 @@ double *pt; if (dp->type == DATATY) { sd.arr.d = dp->arr.d + i*asize; y0 = datavalue(&sd, pt+1); - sd.arr.d = dp->arr.d + (i+1)*asize; + sd.arr.d += asize; y1 = datavalue(&sd, pt+1); + } else if (dp->type == SPECTY) { + sd.arr.s = dp->arr.s + i*asize; + y0 = datavalue(&sd, pt+1); + sd.arr.s += asize; + y1 = datavalue(&sd, pt+1); } else { sd.arr.c = dp->arr.c + i*asize; y0 = datavalue(&sd, pt+1); - sd.arr.c = dp->arr.c + (i+1)*asize; + sd.arr.c += asize; y1 = datavalue(&sd, pt+1); } } else { if (dp->type == DATATY) { y0 = dp->arr.d[i]; y1 = dp->arr.d[i+1]; + } else if (dp->type == SPECTY) { + if (dp->arr.s[dp->dim[0].ne]) { + double f = ldexp(1.0, -(COLXS+8) + + (int)dp->arr.s[dp->dim[0].ne]); + y0 = (dp->arr.s[i] + 0.5)*f; + y1 = (dp->arr.s[i+1] + 0.5)*f; + } else + y0 = y1 = 0.0; } else { y0 = colrval(dp->arr.c[i],dp->type); y1 = colrval(dp->arr.c[i+1],dp->type); @@ -370,3 +674,4 @@ double *pt; return( y0*((i+1)-x) + y1*(x-i) ); } +#endif
