root/radiance/ray/src/rt/create_version.cmake
Revision: 1.3
Committed: Mon Jan 8 16:51:32 2018 UTC (7 years, 3 months ago) by greg
Changes since 1.2: +6 -18 lines
Update to CMake build system from Rob G. and Alex S., adding test cases
1 #${CMAKE_COMMAND} -DRADIANCE_VERSION=v -DVERSION_OUT_FILE=v -DVERSION_IN_FILE=src/rt/VERSION -DVERSION_GOLD=src/rt/Version.c -P src/common/create_version.cmake
2
3 # if the gold version exists then use that instead
4 if(EXISTS "${VERSION_GOLD}")
5 configure_file("${VERSION_GOLD}" "${VERSION_OUT_FILE}" COPYONLY)
6 return()
7 endif()
8
9 find_program(DATE date)
10 if(DATE)
11 execute_process(COMMAND ${DATE} "+%F"
12 OUTPUT_VARIABLE DATE_STR
13 OUTPUT_STRIP_TRAILING_WHITESPACE
14 )
15 endif()
16 file(READ "${VERSION_IN_FILE}" VERSION)
17 string(STRIP "${VERSION}" VERSION)
18 message("${VERSION}")
19 file(WRITE "${VERSION_OUT_FILE}"
20 "char VersionID[]=\"RADIANCE ${RADIANCE_VERSION} NREL ${DATE_STR} (based on ${VERSION} Official Release by G. Ward)\";\n"
21 )
