--- ray/src/rt/create_version.cmake 2011/10/26 16:48:01 1.1 +++ ray/src/rt/create_version.cmake 2018/10/09 17:57:17 1.5 @@ -1,26 +1,21 @@ -#${CMAKE_COMMAND} -DVERSION_OUT_FILE=v -DVERSION_IN_FILE=src/rt/VERSION -P src/common/create_version.cmake +#${CMAKE_COMMAND} -DRADIANCE_VERSION=v -DVERSION_OUT_FILE=v -DVERSION_IN_FILE=src/rt/VERSION -DVERSION_GOLD=src/rt/Version.c -P src/common/create_version.cmake + +# if the gold version exists then use that instead +if(EXISTS "${VERSION_GOLD}") + configure_file("${VERSION_GOLD}" "${VERSION_OUT_FILE}" COPYONLY) + return() +endif() + find_program(DATE date) if(DATE) - execute_process(COMMAND ${DATE} OUTPUT_VARIABLE DATE_STR) - string(STRIP "${DATE_STR}" DATE_STR) + execute_process(COMMAND ${DATE} "+%F" + OUTPUT_VARIABLE DATE_STR + OUTPUT_STRIP_TRAILING_WHITESPACE + ) endif() -find_program(WHO whoami) -if(WHO) - execute_process(COMMAND ${WHO} OUTPUT_VARIABLE WHO_STR) - string(STRIP "${WHO_STR}" WHO_STR) -endif() -find_program(HOSTNAME hostname) -if(HOSTNAME) - execute_process(COMMAND ${HOSTNAME} OUTPUT_VARIABLE HOST_STR) - message("DATE= ${DATE_STR}") - string(STRIP "${HOST_STR}" HOST_STR) -endif() file(READ "${VERSION_IN_FILE}" VERSION) string(STRIP "${VERSION}" VERSION) message("${VERSION}") file(WRITE "${VERSION_OUT_FILE}" -"char VersionID[]=\"${VERSION} lastmod ${DATE_STR}" -" by ${WHO_STR} on ${HOST_STR}\";\n" + "char VersionID[]=\"RADIANCE ${RADIANCE_VERSION} NREL ${DATE_STR} (based on ${VERSION} by LBNL)\";\n" ) - -# todo actually get the date, user name and hostname in this script
