root/radiance/ray/src/rt/colortab.c
Revision: 1.1
Committed: Mon Oct 2 14:10:19 1989 UTC (34 years, 7 months ago) by greg
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * colortab.c - allocate and control dynamic color table.
9 *
10 * We start off with a uniform partition of color space.
11 * As pixels are sent to the frame buffer, a histogram is built.
12 * When a new color table is requested, the histogram is used
13 * to make a pseudo-optimal partition, after which the
14 * histogram is cleared. This algorithm
15 * performs only as well as the next drawing's color
16 * distribution is correlated to the last.
17 */
18
19 #include "color.h"
20
21 #define NULL 0
22 /* histogram resolution */
23 #define NRED 24
24 #define NGRN 32
25 #define NBLU 18
26 #define HMAX NGRN
27 /* minimum box count for adaptive partition */
28 #define MINSAMP 7
29 /* maximum frame buffer depth */
30 #define FBDEPTH 8
31 /* color map resolution */
32 #define MAPSIZ 128
33 /* map a color */
34 #define map_col(c,p) clrmap[p][ colval(c,p)<1. ? \
35 (int)(colval(c,p)*MAPSIZ) : MAPSIZ-1 ]
36 /* color partition tree */
37 #define CNODE short
38 #define set_branch(p,c) ((c)<<2|(p))
39 #define set_pval(pv) ((pv)<<2|3)
40 #define is_pval(cn) (((cn)&3)==3)
41 #define part(cn) ((cn)>>2)
42 #define prim(cn) ((cn)&3)
43 #define pval(cn) ((cn)>>2)
44 /* our color table */
45 COLR clrtab[1<<FBDEPTH];
46 /* our color correction map */
47 static BYTE clrmap[3][MAPSIZ];
48 /* histogram of colors used */
49 static unsigned histo[NRED][NGRN][NBLU];
50 /* initial color cube boundaries */
51 static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
52 /* color cube partition */
53 static CNODE ctree[1<<(FBDEPTH+1)];
54
55
56 COLR *
57 get_ctab(ncolors) /* assign a color table with max ncolors */
58 int ncolors;
59 {
60 if (ncolors < 1 || ncolors > 1<<FBDEPTH)
61 return(NULL);
62 /* partition color table */
63 cut(ctree, FBDEPTH, CLRCUBE, 0, ncolors);
64 /* clear histogram */
65 bzero(histo, sizeof(histo));
66 /* return color table */
67 return(clrtab);
68 }
69
70
71 int
72 get_pixel(col) /* get pixel for color */
73 COLOR col;
74 {
75 int cv[3];
76 register CNODE *tp;
77 register int h;
78 /* map color */
79 cv[RED] = map_col(col,RED);
80 cv[GRN] = map_col(col,GRN);
81 cv[BLU] = map_col(col,BLU);
82 /* add to histogram */
83 histo[cv[RED]][cv[GRN]][cv[BLU]]++;
84 /* find pixel value in tree */
85 tp = ctree;
86 for (h = FBDEPTH; h > 0; h--) {
87 if (is_pval(*tp))
88 break;
89 if (cv[prim(*tp)] < part(*tp))
90 tp++; /* left branch */
91 else
92 tp += 1<<h; /* right branch */
93 }
94 #ifdef notdef
95 printf("distance (%d,%d,%d)\n",
96 cv[RED] - clrtab[pval(*tp)][RED]*NRED/256,
97 cv[GRN] - clrtab[pval(*tp)][GRN]*NGRN/256,
98 cv[BLU] - clrtab[pval(*tp)][BLU]*NBLU/256);
99 #endif
100 return(pval(*tp));
101 }
102
103
104 make_cmap(gam) /* make gamma correction map */
105 double gam;
106 {
107 extern double pow();
108 double d;
109 register int i;
110
111 for (i = 0; i < MAPSIZ; i++) {
112 d = pow(i/(double)MAPSIZ, 1.0/gam);
113 clrmap[RED][i] = d * NRED;
114 clrmap[GRN][i] = d * NGRN;
115 clrmap[BLU][i] = d * NBLU;
116 }
117 }
118
119
120 static
121 cut(tree, height, box, c0, c1) /* partition color space */
122 register CNODE *tree;
123 int height;
124 register int box[3][2];
125 int c0, c1;
126 {
127 int kb[3][2];
128
129 if (c1-c0 == 1) { /* assign color */
130 clrtab[c0][RED] = ((box[RED][0]+box[RED][1])<<7)/NRED;
131 clrtab[c0][GRN] = ((box[GRN][0]+box[GRN][1])<<7)/NGRN;
132 clrtab[c0][BLU] = ((box[BLU][0]+box[BLU][1])<<7)/NBLU;
133 clrtab[c0][EXP] = COLXS;
134 *tree = set_pval(c0);
135 #ifdef notdef
136 printf("final box size = (%d,%d,%d)\n",
137 box[RED][1] - box[RED][0],
138 box[GRN][1] - box[GRN][0],
139 box[BLU][1] - box[BLU][0]);
140 #endif
141 return;
142 }
143 /* split box */
144 *tree = split(box);
145 bcopy(box, kb, sizeof(kb));
146 kb[prim(*tree)][1] = part(*tree);
147 cut(tree+1, height-1, kb, c0, (c0+c1)>>1); /* lesser */
148 kb[prim(*tree)][0] = part(*tree);
149 kb[prim(*tree)][1] = box[prim(*tree)][1];
150 cut(tree+(1<<height), height-1, kb, (c0+c1)>>1, c1); /* greater */
151 }
152
153
154 static int
155 split(box) /* find median cut for box */
156 register int box[3][2];
157 {
158 #define c0 r
159 register int r, g, b;
160 int pri;
161 int t[HMAX], med;
162 /* find dominant axis */
163 pri = RED;
164 if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
165 pri = GRN;
166 if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
167 pri = BLU;
168 /* sum histogram over box */
169 med = 0;
170 switch (pri) {
171 case RED:
172 for (r = box[RED][0]; r < box[RED][1]; r++) {
173 t[r] = 0;
174 for (g = box[GRN][0]; g < box[GRN][1]; g++)
175 for (b = box[BLU][0]; b < box[BLU][1]; b++)
176 t[r] += histo[r][g][b];
177 med += t[r];
178 }
179 break;
180 case GRN:
181 for (g = box[GRN][0]; g < box[GRN][1]; g++) {
182 t[g] = 0;
183 for (b = box[BLU][0]; b < box[BLU][1]; b++)
184 for (r = box[RED][0]; r < box[RED][1]; r++)
185 t[g] += histo[r][g][b];
186 med += t[g];
187 }
188 break;
189 case BLU:
190 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
191 t[b] = 0;
192 for (r = box[RED][0]; r < box[RED][1]; r++)
193 for (g = box[GRN][0]; g < box[GRN][1]; g++)
194 t[b] += histo[r][g][b];
195 med += t[b];
196 }
197 break;
198 }
199 if (med < MINSAMP) /* if too sparse, split at midpoint */
200 return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
201 /* find median position */
202 med >>= 1;
203 for (c0 = box[pri][0]; med > 0; c0++)
204 med -= t[c0];
205 if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
206 c0--; /* part left of median */
207 return(set_branch(pri,c0));
208 #undef c0
209 }
