--- ray/src/rt/colortab.c 1989/10/02 17:12:42 1.2 +++ ray/src/rt/colortab.c 1989/10/03 11:10:10 1.3 @@ -20,18 +20,20 @@ static char SCCSid[] = "$SunId$ LBL"; #define NULL 0 /* histogram resolution */ -#define NRED 28 +#define NRED 24 #define NGRN 32 -#define NBLU 22 +#define NBLU 16 #define HMAX NGRN /* minimum box count for adaptive partition */ #define MINSAMP 7 + /* maximum distance^2 before color reassign */ +#define MAXDST2 5 /* maximum frame buffer depth */ #define FBDEPTH 8 /* color map resolution */ -#define MAPSIZ 128 +#define MAPSIZ 256 /* map a color */ -#define map_col(c,p) clrmap[p][ colval(c,p)<1. ? \ +#define map_col(c,p) clrmap[ colval(c,p)<1. ? \ (int)(colval(c,p)*MAPSIZ) : MAPSIZ-1 ] /* color partition tree */ #define CNODE short @@ -42,29 +44,40 @@ static char SCCSid[] = "$SunId$ LBL"; #define prim(cn) ((cn)&3) #define pval(cn) ((cn)>>2) /* our color table */ -COLR clrtab[1< 1< 1<>8; + cv[GRN] = (g*NGRN)>>8; + cv[BLU] = (b*NBLU)>>8; + /* add to histogram */ histo[cv[RED]][cv[GRN]][cv[BLU]]++; - /* find pixel value in tree */ - tp = ctree; + /* find pixel in tree */ + p.t = ctree; for (h = FBDEPTH; h > 0; h--) { - if (is_pval(*tp)) + if (is_pval(*p.t)) break; - if (cv[prim(*tp)] < part(*tp)) - tp++; /* left branch */ + if (cv[prim(*p.t)] < part(*p.t)) + p.t++; /* left branch */ else - tp += 1<sum[RED] += r; + p.e->sum[GRN] += g; + p.e->sum[BLU] += b; + p.e->n++; + /* recompute average */ + r = p.e->sum[RED] / p.e->n; + g = p.e->sum[GRN] / p.e->n; + b = p.e->sum[BLU] / p.e->n; + /* check for movement */ + if (p.e->n == 1 || + (r-p.e->ent[RED])*(r-p.e->ent[RED]) + + (g-p.e->ent[GRN])*(g-p.e->ent[GRN]) + + (b-p.e->ent[BLU])*(b-p.e->ent[BLU]) > MAXDST2) { + p.e->ent[RED] = r; + p.e->ent[GRN] = g; /* reassign pixel */ + p.e->ent[BLU] = b; #ifdef notdef - printf("distance (%d,%d,%d)\n", - cv[RED] - clrtab[pval(*tp)][RED]*NRED/256, - cv[GRN] - clrtab[pval(*tp)][GRN]*NGRN/256, - cv[BLU] - clrtab[pval(*tp)][BLU]*NBLU/256); + printf("pixel %d = (%d,%d,%d) (%d refs)\n", + h, r, g, b, p.e->n); #endif - return(pval(*tp)); + (*set_pixel)(h, r, g, b); + } + return(h); /* return pixel value */ } @@ -105,15 +143,10 @@ make_cmap(gam) /* make gamma correction map */ double gam; { extern double pow(); - double d; register int i; - for (i = 0; i < MAPSIZ; i++) { - d = pow(i/(double)MAPSIZ, 1.0/gam); - clrmap[RED][i] = d * NRED; - clrmap[GRN][i] = d * NGRN; - clrmap[BLU][i] = d * NBLU; - } + for (i = 0; i < MAPSIZ; i++) + clrmap[i] = 256.0 * pow(i/(double)MAPSIZ, 1.0/gam); } @@ -126,28 +159,20 @@ int c0, c1; { int kb[3][2]; - if (c1-c0 == 1) { /* assign color */ - clrtab[c0][RED] = ((box[RED][0]+box[RED][1])<<7)/NRED; - clrtab[c0][GRN] = ((box[GRN][0]+box[GRN][1])<<7)/NGRN; - clrtab[c0][BLU] = ((box[BLU][0]+box[BLU][1])<<7)/NBLU; - clrtab[c0][EXP] = COLXS; + if (c1-c0 <= 1) { /* assign pixel */ *tree = set_pval(c0); -#ifdef notdef - printf("final box size = (%d,%d,%d)\n", - box[RED][1] - box[RED][0], - box[GRN][1] - box[GRN][0], - box[BLU][1] - box[BLU][0]); -#endif return; } /* split box */ *tree = split(box); bcopy(box, kb, sizeof(kb)); + /* do left (lesser) branch */ kb[prim(*tree)][1] = part(*tree); - cut(tree+1, height-1, kb, c0, (c0+c1)>>1); /* lesser */ + cut(tree+1, height-1, kb, c0, (c0+c1)>>1); + /* do right branch */ kb[prim(*tree)][0] = part(*tree); kb[prim(*tree)][1] = box[prim(*tree)][1]; - cut(tree+(1<>1, c1); /* greater */ + cut(tree+(1<>1, c1); }
