root/radiance/ray/src/rt/colortab.c
Revision: 2.11
Committed: Tue Jul 8 18:24:59 2014 UTC (9 years, 11 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Changes since 2.10: +9 -9 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.11 static const char RCSid[] = "$Id: colortab.c,v 2.10 2011/05/20 02:06:39 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * colortab.c - allocate and control dynamic color table.
6     *
7     * We start off with a uniform partition of color space.
8     * As pixels are sent to the frame buffer, a histogram is built.
9     * When a new color table is requested, the histogram is used
10     * to make a pseudo-optimal partition, after which the
11     * histogram is cleared. This algorithm
12     * performs only as well as the next drawing's color
13     * distribution is correlated to the last.
14 greg 2.5 *
15     * External symbols declared in drvier.h
16     */
17
18 greg 2.6 #include "copyright.h"
19 greg 1.1
20 schorsch 2.8 #include <string.h>
21
22 greg 1.15 #include "standard.h"
23 schorsch 2.8 #include "color.h"
24 schorsch 2.9 #include "driver.h"
25 greg 1.15
26 greg 1.1 /* histogram resolution */
27 greg 1.3 #define NRED 24
28 greg 1.1 #define NGRN 32
29 greg 1.3 #define NBLU 16
30 greg 1.1 #define HMAX NGRN
31     /* minimum box count for adaptive partition */
32     #define MINSAMP 7
33 greg 1.3 /* maximum distance^2 before color reassign */
34 greg 1.5 #define MAXDST2 12
35 greg 1.1 /* map a color */
36 greg 1.4 #define map_col(c,p) clrmap[p][ colval(c,p)<1. ? \
37     (int)(colval(c,p)*256.) : 255 ]
38 greg 1.1 /* color partition tree */
39     #define CNODE short
40 greg 2.2 #define set_branch(p,c) ((c)<<2|(p))
41 greg 1.1 #define set_pval(pv) ((pv)<<2|3)
42 greg 1.7 #define is_branch(cn) (((cn)&3)!=3)
43 greg 1.1 #define is_pval(cn) (((cn)&3)==3)
44     #define part(cn) ((cn)>>2)
45     #define prim(cn) ((cn)&3)
46     #define pval(cn) ((cn)>>2)
47     /* our color table */
48 greg 1.6 static struct tabent {
49 greg 1.3 long sum[3]; /* sum of colors using this entry */
50 greg 1.15 int n; /* number of colors */
51 greg 2.10 uby8 ent[3]; /* current table value */
52 greg 1.8 } *clrtab = NULL;
53     /* color cube partition */
54     static CNODE *ctree = NULL;
55 greg 1.1 /* our color correction map */
56 greg 2.10 static uby8 clrmap[3][256];
57 greg 1.1 /* histogram of colors used */
58 greg 1.9 static unsigned short histo[NRED][NGRN][NBLU];
59 greg 1.8 /* initial color cube boundary */
60 greg 2.3 static int CLRCUBE[3][2] = {{0,NRED},{0,NGRN},{0,NBLU}};
61
62 greg 2.5 static int split();
63     static void cut();
64 greg 1.1
65
66 greg 1.3 int
67 greg 1.4 new_ctab(ncolors) /* start new color table with max ncolors */
68 greg 1.1 int ncolors;
69     {
70 greg 1.8 int treesize;
71
72 greg 1.6 if (ncolors < 1)
73 greg 1.3 return(0);
74 greg 1.8 /* free old tables */
75     if (clrtab != NULL)
76 greg 2.5 free((void *)clrtab);
77 greg 1.8 if (ctree != NULL)
78 greg 2.5 free((void *)ctree);
79 greg 1.8 /* get new tables */
80     for (treesize = 1; treesize < ncolors; treesize <<= 1)
81     ;
82     treesize <<= 1;
83     clrtab = (struct tabent *)calloc(ncolors, sizeof(struct tabent));
84     ctree = (CNODE *)malloc(treesize*sizeof(CNODE));
85     if (clrtab == NULL || ctree == NULL)
86     return(0);
87 greg 1.3 /* partition color space */
88 greg 1.7 cut(ctree, 0, CLRCUBE, 0, ncolors);
89 greg 1.1 /* clear histogram */
90 schorsch 2.8 memset((void *)histo, '\0', sizeof(histo));
91 greg 1.3 /* return number of colors used */
92     return(ncolors);
93 greg 1.1 }
94
95
96 greg 2.11 int
97 schorsch 2.9 get_pixel( /* get pixel for color */
98     COLOR col,
99     dr_newcolrf_t *newcolr
100     )
101 greg 1.1 {
102 greg 1.3 int r, g, b;
103 greg 1.1 int cv[3];
104 greg 2.11 CNODE *tp;
105     int h;
106 greg 1.3 /* map color */
107     r = map_col(col,RED);
108     g = map_col(col,GRN);
109     b = map_col(col,BLU);
110     /* reduce resolution */
111     cv[RED] = (r*NRED)>>8;
112     cv[GRN] = (g*NGRN)>>8;
113     cv[BLU] = (b*NBLU)>>8;
114     /* add to histogram */
115 greg 1.1 histo[cv[RED]][cv[GRN]][cv[BLU]]++;
116 greg 1.3 /* find pixel in tree */
117 greg 1.10 for (tp = ctree, h = 0; is_branch(*tp); h++)
118     if (cv[prim(*tp)] < part(*tp))
119     tp += 1<<h; /* left branch */
120 greg 1.1 else
121 greg 1.15 tp += 1<<(h+1); /* right branch */
122 greg 1.10 h = pval(*tp);
123 greg 1.3 /* add to color table */
124 greg 1.10 clrtab[h].sum[RED] += r;
125     clrtab[h].sum[GRN] += g;
126     clrtab[h].sum[BLU] += b;
127     clrtab[h].n++;
128 greg 1.3 /* recompute average */
129 greg 1.10 r = clrtab[h].sum[RED] / clrtab[h].n;
130     g = clrtab[h].sum[GRN] / clrtab[h].n;
131     b = clrtab[h].sum[BLU] / clrtab[h].n;
132 greg 1.3 /* check for movement */
133 greg 1.10 if (clrtab[h].n == 1 ||
134     (r-clrtab[h].ent[RED])*(r-clrtab[h].ent[RED]) +
135     (g-clrtab[h].ent[GRN])*(g-clrtab[h].ent[GRN]) +
136     (b-clrtab[h].ent[BLU])*(b-clrtab[h].ent[BLU]) > MAXDST2) {
137     clrtab[h].ent[RED] = r;
138 greg 2.2 clrtab[h].ent[GRN] = g; /* reassign pixel */
139 greg 1.10 clrtab[h].ent[BLU] = b;
140 greg 1.12 #ifdef DEBUG
141     sprintf(errmsg, "pixel %d = (%d,%d,%d) (%d refs)\n",
142 greg 1.10 h, r, g, b, clrtab[h].n);
143 greg 1.12 eputs(errmsg);
144 greg 1.1 #endif
145 schorsch 2.9 (*newcolr)(h, r, g, b);
146 greg 1.3 }
147     return(h); /* return pixel value */
148 greg 1.1 }
149
150
151 greg 2.5 void
152 greg 1.4 make_gmap(gam) /* make gamma correction map */
153 greg 2.2 double gam;
154 greg 1.1 {
155 greg 2.11 int i;
156 greg 1.1
157 greg 1.4 for (i = 0; i < 256; i++)
158     clrmap[RED][i] =
159     clrmap[GRN][i] =
160 greg 1.15 clrmap[BLU][i] = 256.0 * pow((i+0.5)/256.0, 1.0/gam);
161 greg 1.4 }
162
163
164 greg 2.5 void
165 greg 1.4 set_cmap(rmap, gmap, bmap) /* set custom color correction map */
166 greg 2.10 uby8 *rmap, *gmap, *bmap;
167 greg 1.4 {
168 schorsch 2.8 memcpy((void *)clrmap[RED], (void *)rmap, 256);
169     memcpy((void *)clrmap[GRN], (void *)gmap, 256);
170     memcpy((void *)clrmap[BLU], (void *)bmap, 256);
171 greg 1.1 }
172
173
174 greg 2.5 void
175 greg 1.13 map_color(rgb, col) /* map a color to a byte triplet */
176 greg 2.10 uby8 rgb[3];
177 greg 1.13 COLOR col;
178     {
179     rgb[RED] = map_col(col,RED);
180     rgb[GRN] = map_col(col,GRN);
181     rgb[BLU] = map_col(col,BLU);
182     }
183
184
185 greg 2.5 static void
186 greg 1.7 cut(tree, level, box, c0, c1) /* partition color space */
187 greg 2.11 CNODE *tree;
188 greg 1.7 int level;
189 greg 2.11 int box[3][2];
190 greg 1.1 int c0, c1;
191     {
192     int kb[3][2];
193
194 greg 1.3 if (c1-c0 <= 1) { /* assign pixel */
195 greg 1.1 *tree = set_pval(c0);
196     return;
197     }
198     /* split box */
199     *tree = split(box);
200 schorsch 2.8 memcpy((void *)kb, (void *)box, sizeof(kb));
201 greg 1.3 /* do left (lesser) branch */
202 greg 1.1 kb[prim(*tree)][1] = part(*tree);
203 greg 1.7 cut(tree+(1<<level), level+1, kb, c0, (c0+c1)>>1);
204 greg 1.3 /* do right branch */
205 greg 1.1 kb[prim(*tree)][0] = part(*tree);
206     kb[prim(*tree)][1] = box[prim(*tree)][1];
207 greg 1.7 cut(tree+(1<<(level+1)), level+1, kb, (c0+c1)>>1, c1);
208 greg 1.1 }
209
210
211     static int
212     split(box) /* find median cut for box */
213 greg 2.11 int box[3][2];
214 greg 1.1 {
215     #define c0 r
216 greg 2.11 int r, g, b;
217 greg 1.1 int pri;
218 greg 2.4 long t[HMAX], med;
219 greg 1.1 /* find dominant axis */
220     pri = RED;
221     if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
222     pri = GRN;
223     if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
224     pri = BLU;
225     /* sum histogram over box */
226     med = 0;
227     switch (pri) {
228     case RED:
229     for (r = box[RED][0]; r < box[RED][1]; r++) {
230     t[r] = 0;
231     for (g = box[GRN][0]; g < box[GRN][1]; g++)
232     for (b = box[BLU][0]; b < box[BLU][1]; b++)
233     t[r] += histo[r][g][b];
234     med += t[r];
235     }
236     break;
237     case GRN:
238     for (g = box[GRN][0]; g < box[GRN][1]; g++) {
239     t[g] = 0;
240     for (b = box[BLU][0]; b < box[BLU][1]; b++)
241     for (r = box[RED][0]; r < box[RED][1]; r++)
242     t[g] += histo[r][g][b];
243     med += t[g];
244     }
245     break;
246     case BLU:
247     for (b = box[BLU][0]; b < box[BLU][1]; b++) {
248     t[b] = 0;
249     for (r = box[RED][0]; r < box[RED][1]; r++)
250     for (g = box[GRN][0]; g < box[GRN][1]; g++)
251     t[b] += histo[r][g][b];
252     med += t[b];
253     }
254     break;
255     }
256     if (med < MINSAMP) /* if too sparse, split at midpoint */
257     return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
258     /* find median position */
259     med >>= 1;
260     for (c0 = box[pri][0]; med > 0; c0++)
261     med -= t[c0];
262     if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
263     c0--; /* part left of median */
264     return(set_branch(pri,c0));
265     #undef c0
266     }
