root/radiance/ray/src/rt/colortab.c
Revision: 1.7
Committed: Thu Oct 12 11:12:48 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.6: +9 -12 lines
Changed tree arrangement (for the hell of it).
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * colortab.c - allocate and control dynamic color table.
9 *
10 * We start off with a uniform partition of color space.
11 * As pixels are sent to the frame buffer, a histogram is built.
12 * When a new color table is requested, the histogram is used
13 * to make a pseudo-optimal partition, after which the
14 * histogram is cleared. This algorithm
15 * performs only as well as the next drawing's color
16 * distribution is correlated to the last.
17 */
18
19 #include "color.h"
20
21 #define NULL 0
22 /* histogram resolution */
23 #define NRED 24
24 #define NGRN 32
25 #define NBLU 16
26 #define HMAX NGRN
27 /* minimum box count for adaptive partition */
28 #define MINSAMP 7
29 /* maximum distance^2 before color reassign */
30 #define MAXDST2 12
31 /* maximum frame buffer depth */
32 #define FBDEPTH 8
33 /* map a color */
34 #define map_col(c,p) clrmap[p][ colval(c,p)<1. ? \
35 (int)(colval(c,p)*256.) : 255 ]
36 /* color partition tree */
37 #define CNODE short
38 #define set_branch(p,c) ((c)<<2|(p))
39 #define set_pval(pv) ((pv)<<2|3)
40 #define is_branch(cn) (((cn)&3)!=3)
41 #define is_pval(cn) (((cn)&3)==3)
42 #define part(cn) ((cn)>>2)
43 #define prim(cn) ((cn)&3)
44 #define pval(cn) ((cn)>>2)
45 /* our color table */
46 static struct tabent {
47 long sum[3]; /* sum of colors using this entry */
48 long n; /* number of colors */
49 short ent[3]; /* current table value */
50 } clrtab[1<<FBDEPTH];
51 /* our color correction map */
52 static BYTE clrmap[3][256];
53 /* histogram of colors used */
54 static unsigned histo[NRED][NGRN][NBLU];
55 /* initial color cube boundaries */
56 static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
57 /* color cube partition */
58 static CNODE ctree[1<<(FBDEPTH+1)];
59
60
61 int
62 new_ctab(ncolors) /* start new color table with max ncolors */
63 int ncolors;
64 {
65 if (ncolors < 1)
66 return(0);
67 if (ncolors > 1<<FBDEPTH)
68 ncolors = 1<<FBDEPTH;
69 /* clear color table */
70 bzero(clrtab, sizeof(clrtab));
71 /* partition color space */
72 cut(ctree, 0, CLRCUBE, 0, ncolors);
73 /* clear histogram */
74 bzero(histo, sizeof(histo));
75 /* return number of colors used */
76 return(ncolors);
77 }
78
79
80 int
81 get_pixel(col, set_pixel) /* get pixel for color */
82 COLOR col;
83 int (*set_pixel)();
84 {
85 int r, g, b;
86 int cv[3];
87 register union { CNODE *t; struct tabent *e; } p;
88 register int h;
89 /* map color */
90 r = map_col(col,RED);
91 g = map_col(col,GRN);
92 b = map_col(col,BLU);
93 /* reduce resolution */
94 cv[RED] = (r*NRED)>>8;
95 cv[GRN] = (g*NGRN)>>8;
96 cv[BLU] = (b*NBLU)>>8;
97 /* add to histogram */
98 histo[cv[RED]][cv[GRN]][cv[BLU]]++;
99 /* find pixel in tree */
100 for (p.t = ctree, h = 0; is_branch(*p.t); h++)
101 if (cv[prim(*p.t)] < part(*p.t))
102 p.t += 1<<h; /* left branch */
103 else
104 p.t += 1<<(h+1); /* right branch */
105 h = pval(*p.t);
106 /* add to color table */
107 p.e = clrtab + h;
108 /* add to sum */
109 p.e->sum[RED] += r;
110 p.e->sum[GRN] += g;
111 p.e->sum[BLU] += b;
112 p.e->n++;
113 /* recompute average */
114 r = p.e->sum[RED] / p.e->n;
115 g = p.e->sum[GRN] / p.e->n;
116 b = p.e->sum[BLU] / p.e->n;
117 /* check for movement */
118 if (p.e->n == 1 ||
119 (r-p.e->ent[RED])*(r-p.e->ent[RED]) +
120 (g-p.e->ent[GRN])*(g-p.e->ent[GRN]) +
121 (b-p.e->ent[BLU])*(b-p.e->ent[BLU]) > MAXDST2) {
122 p.e->ent[RED] = r;
123 p.e->ent[GRN] = g; /* reassign pixel */
124 p.e->ent[BLU] = b;
125 #ifdef notdef
126 printf("pixel %d = (%d,%d,%d) (%d refs)\n",
127 h, r, g, b, p.e->n);
128 #endif
129 (*set_pixel)(h, r, g, b);
130 }
131 return(h); /* return pixel value */
132 }
133
134
135 make_gmap(gam) /* make gamma correction map */
136 double gam;
137 {
138 extern double pow();
139 register int i;
140
141 for (i = 0; i < 256; i++)
142 clrmap[RED][i] =
143 clrmap[GRN][i] =
144 clrmap[BLU][i] = 256.0 * pow(i/256.0, 1.0/gam);
145 }
146
147
148 set_cmap(rmap, gmap, bmap) /* set custom color correction map */
149 BYTE *rmap, *gmap, *bmap;
150 {
151 bcopy(rmap, clrmap[RED], 256);
152 bcopy(gmap, clrmap[GRN], 256);
153 bcopy(bmap, clrmap[BLU], 256);
154 }
155
156
157 static
158 cut(tree, level, box, c0, c1) /* partition color space */
159 register CNODE *tree;
160 int level;
161 register int box[3][2];
162 int c0, c1;
163 {
164 int kb[3][2];
165
166 if (c1-c0 <= 1) { /* assign pixel */
167 *tree = set_pval(c0);
168 return;
169 }
170 /* split box */
171 *tree = split(box);
172 bcopy(box, kb, sizeof(kb));
173 /* do left (lesser) branch */
174 kb[prim(*tree)][1] = part(*tree);
175 cut(tree+(1<<level), level+1, kb, c0, (c0+c1)>>1);
176 /* do right branch */
177 kb[prim(*tree)][0] = part(*tree);
178 kb[prim(*tree)][1] = box[prim(*tree)][1];
179 cut(tree+(1<<(level+1)), level+1, kb, (c0+c1)>>1, c1);
180 }
181
182
183 static int
184 split(box) /* find median cut for box */
185 register int box[3][2];
186 {
187 #define c0 r
188 register int r, g, b;
189 int pri;
190 int t[HMAX], med;
191 /* find dominant axis */
192 pri = RED;
193 if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
194 pri = GRN;
195 if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
196 pri = BLU;
197 /* sum histogram over box */
198 med = 0;
199 switch (pri) {
200 case RED:
201 for (r = box[RED][0]; r < box[RED][1]; r++) {
202 t[r] = 0;
203 for (g = box[GRN][0]; g < box[GRN][1]; g++)
204 for (b = box[BLU][0]; b < box[BLU][1]; b++)
205 t[r] += histo[r][g][b];
206 med += t[r];
207 }
208 break;
209 case GRN:
210 for (g = box[GRN][0]; g < box[GRN][1]; g++) {
211 t[g] = 0;
212 for (b = box[BLU][0]; b < box[BLU][1]; b++)
213 for (r = box[RED][0]; r < box[RED][1]; r++)
214 t[g] += histo[r][g][b];
215 med += t[g];
216 }
217 break;
218 case BLU:
219 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
220 t[b] = 0;
221 for (r = box[RED][0]; r < box[RED][1]; r++)
222 for (g = box[GRN][0]; g < box[GRN][1]; g++)
223 t[b] += histo[r][g][b];
224 med += t[b];
225 }
226 break;
227 }
228 if (med < MINSAMP) /* if too sparse, split at midpoint */
229 return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
230 /* find median position */
231 med >>= 1;
232 for (c0 = box[pri][0]; med > 0; c0++)
233 med -= t[c0];
234 if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
235 c0--; /* part left of median */
236 return(set_branch(pri,c0));
237 #undef c0
238 }
