root/radiance/ray/src/rt/colortab.c
Changes since 2.8: +8 -6 lines
Diff to previous 2.8 , to selected 1.3
Changes since 2.7: +9 -7 lines
Diff to previous 2.7 , to selected 1.3
Tue May 13 17:58:33 2003 UTC (21 years ago) by greg
Changes since 2.6: +5 -5 lines
Diff to previous 2.6 , to selected 1.3
Diff to previous 2.5 , to selected 1.3
Changes since 2.4: +69 -10 lines
Diff to previous 2.4 , to selected 1.3
Wed May 5 10:18:47 1993 UTC (31 years ago) by greg
Diff to previous 2.3 , to selected 1.3
changed int to long in split() (16-bit bug fix)
Mon Mar 8 12:37:21 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.2 , to selected 1.3
Tue Oct 6 12:13:48 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 1.3
removed redundant (and sometimes conflicting) math declarations
Tue Nov 12 17:09:57 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.15 , to selected 1.3
Wed Nov 7 17:16:58 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.14 , to selected 1.3
minor fixes to gamma correction
Thu Mar 29 12:43:07 1990 UTC (34 years, 2 months ago) by greg
Diff to previous 1.13 , to selected 1.3
added missing declaration of errmsg
Fri Feb 23 10:08:33 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.12: +10 -0 lines
Diff to previous 1.12 , to selected 1.3
added map_color function
Fri Feb 9 09:14:52 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.3
added debugging statements
Fri Jan 19 00:00:37 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 1.3
Tue Jan 16 16:00:00 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.9: +21 -23 lines
Diff to previous 1.9 , to selected 1.3
got rid of pointer nonsense that was confusing optimizer
Mon Oct 16 13:43:26 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.8 , to selected 1.3
Changed histogram type to short to save space.
Thu Oct 12 11:32:09 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.7: +19 -10 lines
Diff to previous 1.7 , to selected 1.3
Dynamic allocation to eliminate cap on color table size.
Thu Oct 12 11:12:48 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +9 -12 lines
Diff to previous 1.6 , to selected 1.3
Changed tree arrangement (for the hell of it).
Wed Oct 4 09:23:38 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.5: +4 -2 lines
Diff to previous 1.5 , to selected 1.3
Changed new_ctab() error handling
Tue Oct 3 16:15:52 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 1.3
Increased allowed color error before table update.
Tue Oct 3 14:06:58 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +21 -16 lines
Diff to previous 1.3
Changed calling conventions slightly and added custom color map.
Revision 1.3 - (view) (download) (annotate) - [selected]
Tue Oct 3 11:10:10 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +75 -50 lines
Diff to previous 1.2
Improved color table allocation, second cut.
Mon Oct 2 17:12:42 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.1 , to selected 1.3
Mon Oct 2 14:10:19 1989 UTC (34 years, 7 months ago) by greg
Diff to selected 1.3
