--- ray/src/rt/colortab.c 1989/10/16 13:43:26 1.9 +++ ray/src/rt/colortab.c 1991/11/12 17:09:57 2.1 @@ -16,9 +16,9 @@ static char SCCSid[] = "$SunId$ LBL"; * distribution is correlated to the last. */ -#include "color.h" +#include "standard.h" -#define NULL 0 +#include "color.h" /* histogram resolution */ #define NRED 24 #define NGRN 32 @@ -43,8 +43,8 @@ static char SCCSid[] = "$SunId$ LBL"; /* our color table */ static struct tabent { long sum[3]; /* sum of colors using this entry */ - long n; /* number of colors */ - short ent[3]; /* current table value */ + int n; /* number of colors */ + BYTE ent[3]; /* current table value */ } *clrtab = NULL; /* color cube partition */ static CNODE *ctree = NULL; @@ -80,7 +80,7 @@ int ncolors; /* partition color space */ cut(ctree, 0, CLRCUBE, 0, ncolors); /* clear histogram */ - bzero(histo, sizeof(histo)); + bzero((char *)histo, sizeof(histo)); /* return number of colors used */ return(ncolors); } @@ -91,9 +91,10 @@ get_pixel(col, set_pixel) /* get pixel for color */ COLOR col; int (*set_pixel)(); { + extern char errmsg[]; int r, g, b; int cv[3]; - register union { CNODE *t; struct tabent *e; } p; + register CNODE *tp; register int h; /* map color */ r = map_col(col,RED); @@ -106,34 +107,33 @@ int (*set_pixel)(); /* add to histogram */ histo[cv[RED]][cv[GRN]][cv[BLU]]++; /* find pixel in tree */ - for (p.t = ctree, h = 0; is_branch(*p.t); h++) - if (cv[prim(*p.t)] < part(*p.t)) - p.t += 1<sum[RED] += r; - p.e->sum[GRN] += g; - p.e->sum[BLU] += b; - p.e->n++; + clrtab[h].sum[RED] += r; + clrtab[h].sum[GRN] += g; + clrtab[h].sum[BLU] += b; + clrtab[h].n++; /* recompute average */ - r = p.e->sum[RED] / p.e->n; - g = p.e->sum[GRN] / p.e->n; - b = p.e->sum[BLU] / p.e->n; + r = clrtab[h].sum[RED] / clrtab[h].n; + g = clrtab[h].sum[GRN] / clrtab[h].n; + b = clrtab[h].sum[BLU] / clrtab[h].n; /* check for movement */ - if (p.e->n == 1 || - (r-p.e->ent[RED])*(r-p.e->ent[RED]) + - (g-p.e->ent[GRN])*(g-p.e->ent[GRN]) + - (b-p.e->ent[BLU])*(b-p.e->ent[BLU]) > MAXDST2) { - p.e->ent[RED] = r; - p.e->ent[GRN] = g; /* reassign pixel */ - p.e->ent[BLU] = b; -#ifdef notdef - printf("pixel %d = (%d,%d,%d) (%d refs)\n", - h, r, g, b, p.e->n); + if (clrtab[h].n == 1 || + (r-clrtab[h].ent[RED])*(r-clrtab[h].ent[RED]) + + (g-clrtab[h].ent[GRN])*(g-clrtab[h].ent[GRN]) + + (b-clrtab[h].ent[BLU])*(b-clrtab[h].ent[BLU]) > MAXDST2) { + clrtab[h].ent[RED] = r; + clrtab[h].ent[GRN] = g; /* reassign pixel */ + clrtab[h].ent[BLU] = b; +#ifdef DEBUG + sprintf(errmsg, "pixel %d = (%d,%d,%d) (%d refs)\n", + h, r, g, b, clrtab[h].n); + eputs(errmsg); #endif (*set_pixel)(h, r, g, b); } @@ -150,19 +150,29 @@ double gam; for (i = 0; i < 256; i++) clrmap[RED][i] = clrmap[GRN][i] = - clrmap[BLU][i] = 256.0 * pow(i/256.0, 1.0/gam); + clrmap[BLU][i] = 256.0 * pow((i+0.5)/256.0, 1.0/gam); } set_cmap(rmap, gmap, bmap) /* set custom color correction map */ BYTE *rmap, *gmap, *bmap; { - bcopy(rmap, clrmap[RED], 256); - bcopy(gmap, clrmap[GRN], 256); - bcopy(bmap, clrmap[BLU], 256); + bcopy((char *)rmap, (char *)clrmap[RED], 256); + bcopy((char *)gmap, (char *)clrmap[GRN], 256); + bcopy((char *)bmap, (char *)clrmap[BLU], 256); } +map_color(rgb, col) /* map a color to a byte triplet */ +BYTE rgb[3]; +COLOR col; +{ + rgb[RED] = map_col(col,RED); + rgb[GRN] = map_col(col,GRN); + rgb[BLU] = map_col(col,BLU); +} + + static cut(tree, level, box, c0, c1) /* partition color space */ register CNODE *tree; @@ -178,7 +188,7 @@ int c0, c1; } /* split box */ *tree = split(box); - bcopy(box, kb, sizeof(kb)); + bcopy((char *)box, (char *)kb, sizeof(kb)); /* do left (lesser) branch */ kb[prim(*tree)][1] = part(*tree); cut(tree+(1<>1);
